Rear Subframe Bushings Replacement Help
Old May 14, 2020 | 12:47 PM
Oakenfire's Avatar
Oakenfire
I've heard this is a common one for G owners. After my last oil change, Infiniti let me know my rear subframe bushings are broken and they wanted to charge me $1400 to do it. After a little bit or searching around I've found some kits I could buy for cheaper, though I'm not sure sure if I've found the correct ones.
https://www.z1motorsports.com/suspen...37-p-7516.html
https://conceptzperformance.com/whit...994_p_8189.php
If both work, I think I would prefer the solid ones for durability. This is for a 2011 g37x coupe. Thank you for taking the time to read this!
Edit: Moved to correct area.
Old May 22, 2020 | 12:03 PM
FreightTrain's Avatar
FreightTrain
Late reply so you may have already decided, but either will work. In general, the rears of coupes, sedans, and Z's are pretty interchangeable as far as parts go. Obviously there's some exceptions to that. Yes, either of those will work for your coupe. Solid bushing may cause some NVH though, so keep that in mind. I personally would go with the Poly. I believe our stocks are rubber for comfort, but obviously wear much quicker. Poly is a good middle ground, unless you're trying to go full racecar or don't mind the added NVH.
Old May 22, 2020 | 09:34 PM
Oakenfire's Avatar
Oakenfire
Yeah I just ended up getting the collars from z1 to put around the oem bushings.
Old May 22, 2020 | 09:46 PM
PNW_IPL's Avatar
PNW_IPL
The collars do not go into the main subframe/diff. Fyi
Old May 23, 2020 | 01:04 PM
Oakenfire's Avatar
Oakenfire
Yeah they are going on the rear subframe.
Old May 23, 2020 | 01:30 PM
PNW_IPL's Avatar
PNW_IPL
You blew the diff bushing no? Subframe collars do not address that. You'll need a new diff bushing separately.
Old May 23, 2020 | 09:44 PM
Oakenfire's Avatar
Oakenfire
This post has nothing to do with diff bushings.
Old May 23, 2020 | 09:47 PM
PNW_IPL's Avatar
PNW_IPL
The exterior subframe bushings don't go bad.
the main diff bushing that's in the subframe does commonly go bad. Its not sold from dealer separately thats why you got a 1400 dollar quote. Thats to replace the entire subframe.
so I believe you bought the collars thinking thats your problem but it's not going to fix your issue as the the problem lies in the main subframe bushing that holds the diff. Youll need to cut that out after dropping the diff and press in a new one or buy a new subframe
Old May 24, 2020 | 02:41 PM
Oakenfire's Avatar
Oakenfire
Yeah I have since just replaced them with new oem bushings and putting on the collars next week. I do want to replace the diff bushings as you are right, its a common point of weakness. I just need to do some research on brands, lifespan etc.
Old Jun 3, 2020 | 10:06 AM
Surfnazi's Avatar
Surfnazi
replace the trans diff and motor mounts. All old ones will start to go faster with newer ones you changed
Fuhox
Feb 18, 2020 06:23 PM
ezbme
42
Jan 25, 2018 10:23 PM
4DRZ
12
Mar 12, 2017 10:48 PM
patrickmcv
36
Apr 28, 2015 04:17 PM
WRX_to_G37
Oct 2, 2011 09:15 PM
