Help 19 inch wheels on g37x sedan
Hello everyone , I need some immediate help on a 19inch wheel set up. I've found a good deal for a 19inch rims with good tires. Now I need to know exactly what I should make sure as for the diameter of the rims and tire. The guy told me it's not a staggered set up. The rim and tires are mentioned as
5×112 Rim and 255 35 19 for tire. My car is g37x sedan. Hope someone can help me before the deal is gone..thank you
so basically I need to look for a 19inch rim with the same bolt pattern as in my g ?. Thank you for your reply on time..I appreciate that
I suggest a "squared" setup (all four of the same size) to benefit from tire rotation, something most Gs including myself can't do due to running a staggered setup.
I'm a little confused because diameter would mean the width of the rim which would be the same of course. All four being 19inch in diameter. I'm sorry , the entire tire thing is what I need to learn about in a car.
also , just found some other deal. It says this, 19x8 5x114.5. ?? Apparently its a good deal also
