Fuel cap loose constantly
Old Oct 4, 2023 | 08:03 AM
Cuba's Avatar
Cuba
Hey everyone - looking for help I’ve replaced the fuel cap and recently a sensor that was recommended by mechanic but today my fuel cap loose warning comes on. Any suggestions?
Old Oct 4, 2023 | 06:45 PM
SkysG37's Avatar
SkysG37
What codes are accompanying the light?
could be a faulty filler neck
Charcoal canister
Purge valve (s)
could simply be a vaccum leak at the hoses
Or wiring
Old Oct 6, 2023 | 01:49 PM
BULL's Avatar
BULL
Moderador
So code is constant but has nothing to do with the cap unless it was a cheap cap( even cheap caps do a decent job)
The valve replaced means that you probably had a "large evap leak" and the mechanic changed the typical cap plus a visual check of a valve that showed possibly deterioration.
I see you are in Jersey which means rust. Quite possible you have a leak somewhere in your evaporation lines. Tell your mechanic he should smoke test the entire system to find that leak.
hip
Oct 24, 2020 06:32 PM
En Laret Mo
Jul 16, 2018 05:43 AM
sking
General Tech Questions
Sep 18, 2017 05:36 PM
Kirkster
Aug 29, 2011 12:20 PM
Graham
27
Jul 24, 2009 01:58 PM
