2010 g37 code p1089! SOS
Old Jul 9, 2023 | 11:05 PM
Ahmadzeee's Avatar
Ahmadzeee
Hi guys I have code p1089 and car goes limp no throttle until code reset. But then same code comes back. Does anyone know what this is?
Old Jul 10, 2023 | 04:04 PM
beefychicken's Avatar
beefychicken
From the FSM:
P1089, P1092 VVEL CONTROL SHAFT POSITION SENSOR Description
VVEL control shaft position sensor (1) is placed on VVEL actuator sub assembly and detects the control shaft position angle. A magnet is pressed into the arm on the edge of control shaft. The magnetic field changes as the magnet rotates together with the arm resulting in the output voltage change of the sensor. VVEL control module detects the actual position angle through the voltage change and sends the signal to ECM
Mzb3d
16
Mar 24, 2025 02:07 PM
leplix
May 7, 2024 03:56 PM
Lsoul
Apr 27, 2024 11:54 PM
jaimelokz
Intake and Exhaust
Nov 11, 2015 04:08 PM
