STUCK IN LIMP MODE (codes P0021, P0524, P0448)
Old Jul 21, 2023 | 04:08 PM
stcam's Avatar
stcam
2008 Infiniti G37S Coupe 5AT
Mods: Catless, Aftermarket Intakes
My Infiniti has been stuck in limp mode ever since I got it a few months back. If I reset ecu, the car will go to 3.5k rpm then limp mode activates. If I don't, the engine light comes on and I can't go past 2.5k rpm.
I've been to 2 different Nissan/Infiniti specialist shops and they both told me I need a new engine. One shop said I needed to replace the timing chain, and the other said gallery gasket, but he opened the engine and said it was already replaced beforehand so he deemed the engine unfixable and said I need a new engine.
Has anyone had a similar issue to me with these codes and what did you do to fix it going into limp mode? I am saving up to swap the engine but should I get a third opinion? What should I do from here?
Casey A. Coker
Mar 5, 2026 09:45 PM
digiera
31
Mar 6, 2024 10:06 PM
onealrk
May 29, 2023 02:15 PM
GariepyVQ
General Tech Questions
Jul 16, 2022 05:56 PM
Rod K
Mar 31, 2022 09:55 AM
