Water leak
Old Oct 10, 2023 | 04:13 PM
PlimmelJig's Avatar
PlimmelJig
Water leak
I have notice water leaking thru my passenger side tweeter in the corner. Do i need to change the speaker fluid.? And if so what kind of fluid do i use.
Hahah. Just kidding. But serious wheres the damn water coming from and if i buy the whole 400 dollar window weather seal is that gonna fix it. Or is it the windshield weatherstripping?.
the water also leaks onto passenger floor carpet and puddles up under the styrofoam floor cushion.
i drilled 2 hole under the styrofoam so it wouldnt puddle but its a significant leak to wet the carpet and cause it to smell.infinitely.
Can someone tell me if my theory is correct on the door seal or maybe its a grommet on the firewall.
Old Oct 10, 2023 | 05:53 PM
ILM-NC G37S's Avatar
ILM-NC G37S
You may want to read this thread as it a ton of info on the door seals/ leaks.
Also, some folks have had luck adjusting the glass so that it seals tighter against the seal. This thread is a sort-of DIY that might help.
In my case, I went ahead and replaced all three (3) seals just to be done with it.
Old Oct 11, 2023 | 01:52 AM
PlimmelJig's Avatar
PlimmelJig
thankx I'm already in purchase of the seal and we'll see what happens
zaid0808
Jul 23, 2023 06:46 PM
VQPTK
Nov 24, 2022 08:36 PM
rlb
Oct 23, 2021 05:58 PM
ctng37
31
Mar 11, 2021 03:55 PM
Huaniitoo
Apr 7, 2018 01:53 AM
