The OFFICIAL "I have a wheel offset / tire fitment question!" thread
Old Feb 28, 2018 | 08:50 AM
  #2206
Have to tell your buddy to pass on those, offsets should be in the +35 to 40 range in front and a +45 on that 10.5, they will be poking like a skateboard on a sedan
Old Feb 28, 2018 | 11:41 AM
  #2207
GetYourWheels's Avatar
GetYourWheels
Originally Posted by Vizard_87
Asking for a friend
19x9.5+22, 10.5+22
2011 awd sedan
Stock height
Does that work and what tire size is recommended?
tell your buddy he'll be better off with these that come in sizes he needs.
https://www.getyourwheels.com/view-w...h-machined-lip
Old Mar 1, 2018 | 04:21 AM
  #2208
neoMWH's Avatar
neoMWH
Got a crazy good deal on a set of vfs-1's. 20x9.5/10.5 +25 all around, 2012 XS coupe on eibachs, would 245/35, 275/30 work or should I go 255 up front? Pretty sure I'm gonna need to trim my bumper bracket huh?
Old Mar 1, 2018 | 09:17 AM
  #2209
The best AWD tire combos are~
235/35 & 275/30 0.07%
245/35 & 285/30 -0.07%
Virtually no difference in diameter front to back.
A 245/35 & 275/30 is -.97% which may cause issues since the rears wear faster, this would put the variance over 1% over time, this is the value that you should be under so no issues w/ your AWD system will result.
A 245/275 set IS much better than a 255/275 set, this is over 2% difference.
If you don't mind the slight stretch of the 235 on a 9.5 that would be the best bet, and the 275 in back should tuck ok without a trim.
Old Mar 1, 2018 | 10:31 PM
  #2210
neoMWH's Avatar
neoMWH
Thanks a bunch, think I may stick with the 245/275 and just keep an eye on the wear as I definitely don't want to stretch. Going more for the look of Simpson's or Chrispyy's G unless the 285 out back would fit with the trim, I don't mind doing it, just don't want to be running to much neg camber just to make it fit.
Old Mar 1, 2018 | 10:49 PM
  #2211
285s would require some work to get them to clear the fenders IMO, the 245/275 should be fine as long as you're prepared to change the 275s out a bit sooner, or if your AWD light comes on at speed when getting worn.
Old Mar 11, 2018 | 08:27 PM
  #2212
wyog37x's Avatar
wyog37x
Car- 2013 g37x Sedan
Wheels- 18x9 +30
Suspension- swift springs
Trying to decide on tires, what would your suggestions be?
245/45
255/45
255/40
265/40
Old Mar 11, 2018 | 10:25 PM
  #2213
I'd run the 245/45, the wheel edge will be about 5mm outside the fenders so 245s would tuck without problems, the 255s might rub the inside of the front fender under heavy compression since the fender isn't rolled like the rear fender.
Old Mar 13, 2018 | 01:00 AM
  #2214
DR23's Avatar
DR23
Volk te37sl
Car: 2013 G37 IPL
wheels: Volk te37sl 19x9.5 +22
19x10.5 +22
OR
19x10.5 +22 all around
Suspension: stock (but would like to possibly move to airlift 3h if possible)
looking for tire suggestions without rubbing, or having to fender pull.
Is air suspension even possible with this aggressive of a setup? Will there be extreme negative camber? Im not interested in slamming the car. Really want to use air to get in and out of parking lots/driveways and have a close fender gap ride height without looking like monster truck.
Old Mar 13, 2018 | 09:16 AM
  #2215
Here's a 10.5 +25 running 275s so running the same 275 width you'd be 3mm further out than this~
If you aren't opposed to running a stretched tire setup a 255/40/19 would get you 7mm more room at the fender from the above setup.
Old Mar 15, 2018 | 01:40 AM
  #2216
grailedmund's Avatar
grailedmund
G37X coupe lowered on swift springs. What offsets should I get for a flush look for these options?
Option A:
20x9 235/35
20x10.5 275/30
Option B:
20x9.5 245/35
20x10.5 285/30
Old Mar 15, 2018 | 09:48 AM
  #2217
Option A:
20x9 235/35 +10 to +15
20x10.5 275/30 +25 to +30
Option B:
20x9.5 245/35 +20 to +25
20x10.5 285/30 +30 to +35
With those offsets wheels will be poking outside the fenders but tires will tuck, may have to trim rear fender bracket and run a bit more camber depending on how wide the tires run (different tire brands run wider/narrower even w/ same tire sizes), if you want wheel edge flush to the fender you'd have to select offsets 10mm more positive all around.
Old Mar 15, 2018 | 10:10 AM
  #2218
turbo_dreams's Avatar
turbo_dreams
I came across a decent craigslist deal on Vossen VSF1's that I'm considering making an offer on. Wheels are 20 x 9.5 and +25mm all around. Car is a 2012 G37xS on the stock suspension. What would the fitment be like on these? I'm also planning on getting springs in the near future, would this setup still work lowered?
Old Mar 15, 2018 | 11:11 AM
  #2219
An XS coupe will fit well, an XS sedan will be poking about 15mm outside the fender well. Lowering will be a good plan , so in short, if you have a coupe go ahead and make that offer, if you have a sedan keep looking (an offset of +35 to +40 would be good for a sedan w/ that wheel width).
A 255/35/20 would be a good tire size to run w/ those.
Old Mar 15, 2018 | 11:12 AM
  #2220
turbo_dreams
Yeah, it's a sedan. Thanks for the reply, you just saved me a ton of cash. I'll keep looking.
