Old Jan 19, 2022 | 06:05 PM
  #8896
rotarymike's Avatar
rotarymike
Moderator in Moderation
The other thing is that a pulley by nature doesn't have a very long moment-arm - so even a heavy one (with damping) would not take that much horsepower once spinning. Longer moment-arm stuff like the flywheel - and more importantly, the wheels themselves - will affect HP loss and engine spool time much more.
On the other hand, it's a shiny, so folks will still buy it.
Old Jan 22, 2022 | 12:40 PM
  #8897
hexotic's Avatar
hexotic
DIY Cheapskate/Mod
Originally Posted by BULL
I'm working on a plug and play full VDC kit for those wanting to experience full control without cutting any wires. I have the 370z option almost fully complete. With the G I'm trying to find the best spot to mount the switch. It would be a Nissan factory latching switch.
Definitely interested. You and Frank are my heroes lol. Which reminds me, I have to get in touch with him for some more testing of his gauges.
Old Jan 28, 2022 | 06:57 PM
  #8898
AnotherVQ's Avatar
AnotherVQ
I switched out the FI RHFC to the FI RTP today. Asked them to lift it so I can take pictures and apparently they took pictures already.
Turns out they also took pictures and videos when I had the rotors, brake lines, brake pads and fluid installed...
https://i.imgur.com/eahdW0q.mp4
https://i.imgur.com/sMmEpXe.mp4
Old Jan 29, 2022 | 04:12 AM
  #8899
thescreensavers's Avatar
thescreensavers
Those rotors are sex! I am slapping on new stockers this weekend and I keep forgetting they weigh 30lbs (Akebonos)
Old Jan 29, 2022 | 10:58 PM
  #8900
thescreensavers
Got some FI HFCs installed, So I have an eBay Y
-pipe OEM sedan midpipe to HKS mufflers. I think that's where I'll stop for the exhaust as it sounds perfect now. A bit higher pitched than with stock cats and a few Db louder. Only negative is there is a little bit more idle vibrations, which I suppose was related to removing the Cat brace.
Slapped on some Raybestos Specialty Rotors 980663/980664 Amazon had them for $230 shipped which was $100 less than rockauto! Not sure if the material is better or not being "Specialty" but they pretty much look identical to the OEM rotors.
I was having issues with the OEM rotors "juddering" after getting wet, never had that issue before on any of my cars so I figured I'd swap the rotors and double check if run out was <.002" with the new rotors (it was)
Side note, the spring Wire diameter for sport springs is
F: .580" R:.600". I think I'll eventually get my springs characterized since there is no data on their spring rate.
Old Jan 30, 2022 | 08:18 AM
  #8901
https://www.myg37.com/forums/g37-sed...tions-hfc.html
Old Jan 30, 2022 | 11:30 AM
  #8902
thescreensavers
Thanks for linking that! Thats exactly what I was looking at doing.
I don't understand FIs comment. I'm pretty sure the brace is attached to the trans not the body so relative movement not an issue. It most definitely removes the natural frequency away from being at idle so I think that's a miss from FI.
Old Jan 31, 2022 | 05:35 PM
  #8903
kim99jung's Avatar
kim99jung
ah the duck feet
19" forge rays with 15mm spacers
Old Feb 3, 2022 | 10:11 AM
  #8904
afrayedknot's Avatar
afrayedknot
What's your exhaust setup? How do you like the RTP compared to the RHFC? I have the RHFC and have been yearning a for a little more ever since it was installed..
Old Feb 3, 2022 | 12:22 PM
  #8905
rotarymike's Avatar
rotarymike
I'm not sure y'alls hearing is OK... I've got FI RHFCs and the FI catback and if I get on it, it's ridiculously loud. At idle, still loud - had neighbors 'comment' both good and bad.
Old Feb 3, 2022 | 12:31 PM
  #8906
AnotherVQ's Avatar
AnotherVQ
Missing some of the bass but like how much louder it is under even moderate throttle. Burbles are better too.
Ofc my catback is known to be tame (stillen). I plan on doing a couple more things to the setup.
A little rasp too around 3k somewhere but I know it's temporary because of pending changes.
Old Feb 4, 2022 | 11:57 AM
  #8907
Aeroneer1's Avatar
Aeroneer1
Just put FI RTP, onto existing 3" FI catback. It's definitely much louder than just with stock cats to catback, but power and throttle were major change that its worth it. I could go for quieter, but such is life.
Old Feb 4, 2022 | 10:08 PM
  #8908
thescreensavers
AFF7 19x9.5 / 5x114.3 +35
I weighed all 4, 19.875lbs +/- 1 oz
5mm spacer is basically 0 clearance with the caliper hah, well then 7mm spacer it is.
I wanted to go 275 square but I'll prob run 255s for now to see how it fits.
Old Feb 5, 2022 | 11:16 PM
  #8909
AnotherVQ's Avatar
AnotherVQ
I put in the GT-R Map Light Lenses. In the close-up they look a little yellow but in person they aren't.
Old Feb 5, 2022 | 11:42 PM
  #8910
JSolo's Avatar
JSolo
Just say no!!!!!
That's one big garmin! Which model is that, DS86?
