Old Aug 21, 2021 | 07:22 PM
  #8746
ILM-NC G37S's Avatar
ILM-NC G37S
Originally Posted by hexotic
... the mechanism inside for the AT shifter. Once I get my big lathe next year, I may produce a limited run of billet ***** with my own custom mechanism. I have an idea...
Albeit seriously premature, but I'd definitely love to see what type of mechanism you come up with. Right now I'm using the shifter adapter from JDM Parts Ninja and, well, it definitely isn't perfect. Not worth the money for what it is, but at least I can run any type of knøb.
Nice work all the same...
Old Aug 21, 2021 | 07:27 PM
  #8747
hexotic's Avatar
hexotic
DIY Cheapskate/Mod
It's somewhat similar, just tighter tolerances and a more compact design. It may be a complete ****, not an adapter. I'll have to see how it goes. For now it's mostly all in my head
Old Aug 23, 2021 | 09:26 AM
  #8748
rotarymike's Avatar
rotarymike
Moderator in Moderation
Im also gearing up to make a limited run of billet aluminum radio *****. Similar to carsmo, but not stainless like his since my mini lathe cant handle steel lol. Maybe do some SS ones on the big lathe next year as well.
You know there will be a market for that. Hell, I think knurled aluminum would be neat.
Edited: The RX8 had one big **** in the center of the radio; one of the common mods (I did it too) was a rotor-shaped ****. Looked very neat but only rotorheads catch it. Not sure what a VQ-person could do with that - the skyline badge doesn't lend itself.
Old Aug 23, 2021 | 09:31 AM
  #8749
JSolo's Avatar
JSolo
Just say no!!!!!
This obsession with *****.... What happened to *****?
Old Aug 23, 2021 | 09:39 AM
  #8750
rotarymike's Avatar
rotarymike
I use a heavy RAZO leather-covered ball shifter, and have used round shifters since I started racing.
I shall otherwise ignore the layers of entendre in your post
Old Aug 23, 2021 | 09:45 AM
  #8751
hexotic's Avatar
hexotic
DIY Cheapskate/Mod
Not much there to work with. Can't turn a trombone into a **** design lol.
Old Aug 23, 2021 | 02:36 PM
  #8752
rotarymike's Avatar
rotarymike
You could put indents around the front face edge to look like the brake lights, I guess...
Old Aug 24, 2021 | 08:55 PM
  #8753
rotarymike's Avatar
rotarymike
Still chasing down a clunk in the new suspension. Strut tops are tight, tight to the car, lower bolts are tight, swaybar links are tight. Jacked the car and then put it on ramps to try to find the clunk but nada. Maybe I need to drive it more.
Old Aug 24, 2021 | 09:10 PM
  #8754
JSolo's Avatar
JSolo
Just say no!!!!!
I had a sticking replacement shock in my camaro. Everything was tight stationary, but when weight shifted one way then the other, the movement in the shock wasn't smooth, resulting in a clunk.This became evident when going F/R back and forth (rocking the car). Maybe something similar in your case?
This was some cheap monroe (or one of the other popular brand names from back in the day) shocks. Replaced with with bilsteins, no problems.
Old Aug 24, 2021 | 09:43 PM
  #8755
iCrap's Avatar
iCrap
Repaired this clock, and made it blue to match the rest of my interior. It might actually be too bright, hopefully it dims enough to look right in the car. We will see.
Old Aug 25, 2021 | 12:00 AM
  #8756
BULL's Avatar
BULL
Moderador
Almost positive it's the UCA. Everything else can be found by a simple visual inspection.
I thought top hats were the problem, switched to Z struts with newer strut mounts and still had the same noise.
Had a buddy tell me either strut mount or UCA for front clacking noises in G/Zs
Old Aug 25, 2021 | 06:09 AM
  #8757
rotarymike's Avatar
rotarymike
They're brand new Konis, so I hope they aren't defective. Didn't have a clunk before, so that tells me it is a part I touched when I changed the shocks/springs.
I got whiteline front swaybar links since I was replacing the shocks (for you X people, the swaybar link upper bolt is what holds the shock in) and the nuts provided don't seat all the way on the thicker Hotchkis sway. I think I'll revert to the OEM nut which is thinner, and re-do the length of them with the car on ramps again.
Old Aug 26, 2021 | 12:02 AM
  #8758
JC-RH's Avatar
JC-RH
Cleaned the engine bay, and then detailed her!!
Old Aug 29, 2021 | 02:30 PM
  #8759
2.2Lude's Avatar
2.2Lude
Tossed on the new track set up to drive on the street until Friday.
Old Aug 29, 2021 | 04:49 PM
  #8760
KImChee's Avatar
KImChee
What leds sis you use ?
