Yeah, I liked the chrome on black theme of the Niches but I really wasn't purposely looking for an identical look, it just worked out that way. The 20 inch lexanis were a cheap, chance craigslist score--it just seemed like the thing to do. If I were spending new wheel money, I probably would have went a different route, but this was the right deal at the right time.
No plans to lower the suspension--I don't think there's that much wheel gap--at least not enough to spend the $$ to drop it. My #1 priority was to make the car better to drive. It was harsh on the rubber band tires and would weave back and forth in the ruts in the freeway on my daily commute like my old 74 square body chevy 4x4 used to. Drove me NUTS ;-)
I need your help - my friend just bought a set of wheels for his 2014 Jaguar XF AWD
What size tires does he need to run to make sure it dosent mess with any of his sensors.
Wheel size below
Front - 20x8.5 et 45
Rear - 20x10 et 45
Wheel size below
Rear - 20x10 et 45
Please let me know what you think.
Thank you
That'll be a question for me.
245/35/20 and 285/30/20. Tire rack recommends 255/35/20 but you'll have a better matching overall diameter with the 245/35/20 up front with the 285/30/20. Great for the AWD setup as that's the tire size we do for all G/Q AWD.
Sorry bro - Another noob question
I gave you the wrong offsets - His front are 35 and rear are 38 - Does it really matter? or can we do the same size for the tires you listed above.
Hey guys I just scored a square 19x9 set of Redsport wheels. The wheels are stamped 37 on the backside of the spokes.
I have a 12 Sport Sedan and wanted to make sure the fronts are going to fit without any rubbing. I will be dropped mildly on coilovers. No tires on the wheels at the moment so I can only test fit them while up on the lift. I am planning on running 245/40/19 unless I am persuaded otherwise.
I don't think the rears will be much trouble but after test fitting the fronts it appears that it's going to be close. But again tough to tell.
Definitely don't want to be worried about rubbing tires.
I did see another member running these wheels but his appear to be a staggered setup and I am not sure of the width and offset of those specific wheels.
Thanks for the input!
Pretty sure you will be fine. The wheels will tuck in naturally from being dropped on the coilovers. OEM wheels are not very aggressive in terms of offset and width.
Thanks guys. I ordered the tires and should be able to get them mounted this week. I'll report back once I can get them on the car regarding the fitment.
Can anyone help me out I have 2013 g37x sedan my car came with 225 55 17 and found rims that are 245 45 19 would it fit and not give me any problems with the awd ?
You should run 245/40/19s to be as close to OEM diameter, the 245/45s are almost an inch taller, you could run them for the short term but ideally getting the 245/40s should be the plan.
Will the wheels from the Q50 Red Sport fit my 2012 Sport Coupe?
I think the specs for the Q50 are:
19x9 and 47mm offset for the front
19x9.5 and 50mm offset for the rear
I don't want to have to do any mods to make the Q50 wheels to fit other than wheel spacers.
I currently have 235 front and 265 rear tires on 19x8.5 and 19x9 IPL wheels. Will these tires also fit the Q50 wheels?
Wheels & tires will fit fine, but your plan for spacers is good as you will probably want to flush them up a bit. I'd wait until you get them installed, then decide on the exact spacing you want.
