Old Mar 5, 2022 | 12:21 AM
  #8941
thescreensavers's Avatar
thescreensavers
Yes that gap, the exhaust isnt sitting in the hanger but floating in it because the mufflers are holding them up so just adjust your mufflers to sit a tiny bit lower and it should solve your issues.
Old Mar 5, 2022 | 12:25 AM
  #8942
AnotherVQ's Avatar
AnotherVQ
Thanks a lot. I'm a little unsure where you're saying to put washers or spacers.
Old Mar 5, 2022 | 12:31 AM
  #8943
iCrap's Avatar
iCrap
Went to go drive today, and my blower motor is making a horrible noise. Time for my FOURTH blower!
At least the advance auto warranty keeps em coming for free.....
Old Mar 5, 2022 | 12:42 AM
  #8944
thescreensavers
You see the bracket floating in the air to the right of the exhaust tip? There are two studs that go through them, you can put some washers in-between the bracket and the car to lower the mufflers which will in turn lower your midpipes away from the swaybar. It may not be 100% the solution but that and some other massaging of the flanges will likely get you there.
Old Mar 5, 2022 | 12:44 AM
  #8945
thescreensavers
Are they easy to swap? Iirc after 3rd replacement you might be able to get store credit.
Old Mar 5, 2022 | 02:46 AM
  #8946
AnotherVQ's Avatar
AnotherVQ
I think I got it. Between the chassis and the circled part, space it out.
What about the left tip coming out further past the bumper than the right tip? Any ideas on that?
Old Mar 5, 2022 | 09:46 AM
  #8947
thescreensavers
Yup! It's an aftermarket exhaust so fitment can vary and from your pic the left tip isn't that much further out, there really isn't a way to adjust that. You can try loosen all the flanges and see if any adjustment helps that but nothing really directly to tweak it.
The exhaust will expand when hot, see what the tips look like once you drive it for a bit.
Old Mar 5, 2022 | 10:32 AM
  #8948
AnotherVQ's Avatar
AnotherVQ
Thanks again
Old Mar 5, 2022 | 12:35 PM
  #8949
iCrap's Avatar
iCrap
Its easy... like 3 screws and a clip. I got it from advance auto, so far they have all been covered by warranty.
I think water is coming in from the fresh air vent, but i'm not sure why or how to stop it, other than just cover that vent up when i don't use the car
Old Mar 7, 2022 | 06:08 AM
  #8950
rotarymike's Avatar
rotarymike
Moderator in Moderation
Put some sort of sealant on the windshield cowl piece above the vent. Otherwise, water runs right down into the blower when it rains or you wash the car. The felt on the bottom of the cowl piece probably lasted a year max.
Old Mar 7, 2022 | 10:05 AM
  #8951
iCrap's Avatar
iCrap
That was my thought. I have that Butyl rubber stuff used for sealing headlights... might use that.
Old Mar 7, 2022 | 10:52 AM
  #8952
rotarymike's Avatar
rotarymike
Given your 3d printing expertise, you could make a drip shield that snaps onto the fresh air duct.
Old Mar 7, 2022 | 11:41 AM
  #8953
iCrap's Avatar
iCrap
lol, that was my other idea as well! I will probably do both. I don't want to replace the blower yet again.....
Old Mar 7, 2022 | 11:45 AM
  #8954
rotarymike's Avatar
rotarymike
Rock on then
Old Mar 7, 2022 | 03:30 PM
  #8955
backman_66's Avatar
backman_66
Replaced my battery today and shed about 40-45lbs in the process. I put in an Antigravity ATX-30 RS that weighs about 6lbs and made myself a cheapo box with some spare wood to fit it in there snug. The stock battery holder actually worked pretty well.
So my weight savings mods are:
RHFCs: 10.4lbs
Spare + tools: 35lbs I think (I'd have to look it up to confirm)
Engine cover, hood liner, trunk liner: 5lbs
Lightweight wheels: 25lbs rotational + unsprung
Battery: 40-45lbs
Still planning to get 2 piece F+R rotors very soon which will save another 20lbs up front and 8-10 in the rear, and also going to get a 12.5lb flywheel for another 20~lbs weight loss.
