Old May 9, 2019 | 10:10 AM
  #6736
rotarymike's Avatar
rotarymike
Moderator in Moderation
Originally Posted by qmantran
The concept z performance kit is "Made from Syntheseal gasket material"
The EPS tuning kit is "Steel reinforced"
The OEM gasket is some type of paper material that breaks apart on its own over time. I have no experience with either kit, I just know those 2 are supposed to be alternative upgrades over the "OEM Paper gasket"
I thought the 2012-on use a metal gasket?
Old May 9, 2019 | 10:13 AM
  #6737
nonlinearedits's Avatar
nonlinearedits
It's models after 2013. 2013 models were found having the same issue as well. if you're fixing it out of warranty I'd def go with EPS. The OEM can still fail partially due to the fastener being unable to torque down correctly. EPS issues new fasteners in their kit.
Old May 9, 2019 | 10:20 AM
  #6738
rotarymike's Avatar
rotarymike
Mine is a 2013, no oil pressure problems (knock on wood) now. My understanding was that in late 2011/early 2012 they switched to a metal gasket design. I've seen some noise here and on the NICO forum about 2012+ warping and leaking too, but less common. Did they change it again for the Q40/50 models?
Old May 9, 2019 | 10:50 AM
  #6739
SupraOfDoom's Avatar
SupraOfDoom
Originally Posted by iCrap
Im not really a fan of those. Too many different colors going on there. Also whats up with the alignment? the right reverse light is like angled inwards, the gap is totally off
I need to adjust the trunk to fit better. It was fitting better on my G35X when it was on there, so it's either a matter of lining it up better or I may have to use my dremel a little.
Originally Posted by saywat?
those tail lights gotta go. do u really like them ?
I do like them but I don't think they are perfect. For me, they are a place holder until I can modify them. What I'd want to do to them is have the tails blacked out GTR style, so only the clear light sections are showing, black out the chrome, and have the lights replaced by a halo's. To me they are more exciting than stocks even currently. I still have an extra set of stocks in my garage. MAYBE I'd swap them out for JDM versions.
Old May 9, 2019 | 02:51 PM
  #6740
Conboss's Avatar
Conboss
The other day I cleaned up my headlights! Sadly I can’t find the pictures... but I also cleaned my throttle bodies!
Side note, what’s this box in the last picture? Is it a baffle?
Old May 9, 2019 | 03:34 PM
  #6741
Selym's Avatar
Selym
It's probably a crude oil (no pun intended) mist separator, to minimize the amount of oil mist that enters the intake tract.
Old May 9, 2019 | 03:36 PM
  #6742
Pretty sure that's a helmholtz resonator, designed to dampen intake noise.
Old May 9, 2019 | 03:39 PM
  #6743
Conboss's Avatar
Conboss
Correct, it is a resonator. Thinking I might delete it, free the intake up a bit
Old May 9, 2019 | 03:51 PM
  #6744
RMB5190's Avatar
RMB5190
You're correct. While the models featuring the new gasket aren't completely immune, the chances of experiencing a low oil pressure problem due to a gasket rupture is minuscule. No knowledge of a change for the Q lineup.
Old May 9, 2019 | 05:33 PM
  #6745
deepblue3's Avatar
deepblue3
Thanks Hashim. The shop is Austin Z Clinic. Austin Z Clinic LLC - Austin Nissan Performance Headquarters
They specialize in Z cars and also work in G35/37s. I see a ton of 240 and 280Zs there. The owner Kevin's wife drives a G37 as well.
My car has been running well since I got it back. I would recommend him.
Old May 9, 2019 | 05:37 PM
  #6746
deepblue3's Avatar
deepblue3
Re the 2012 and 2013s, because the oem fasteners can still loosen and backout causing an oil leak but not a complete gasket blowout, I got the allen head fasteners from CZP that could be torqued down. That's also why I felt like buying an 09 wasn't such a huge disadvantage.
Old May 13, 2019 | 04:35 PM
  #6747
-ZS-Carpenter's Avatar
-ZS-Carpenter
Took it to North Carolina. Left the Z at the hotel yesterday and took the sedan up part of the Blue Ridge Parkway from Asheville to Lineville Falls and back.Then from Asheville to here today. Let the fun and games begin!
Old May 13, 2019 | 04:46 PM
  #6748
rotarymike's Avatar
rotarymike
I'm surprised the factory doesn't stake the bolts like the bolt carrier allen-key bolts on an AR. I'm sure there are tons of other examples too - we used to stake or safety wire almost all bolts in aerospace.
Personal G37 content: I installed the black ebay grille and the Z1 after-maf silicone this weekend. Grille: looks purty. Silicone - I didn't expect any huge gains or anything, but it does whistle loudly above 7000 rpm. Not sure if the resonator on the passenger side handled that before.
Old May 13, 2019 | 04:48 PM
  #6749
rotarymike's Avatar
rotarymike
Look up NC215 where it descends from the BRP. If passable, you will be entertained.
Old May 14, 2019 | 07:40 PM
  #6750
hexotic's Avatar
hexotic
DIY Cheapskate/Mod
I'm not dead, I've been lurking
Finally had time to take care of the G a little. Put on the metal undertray. Such a drastic improvement.
