Who has a Stillen G37 Supercharger? Numbers, pics, vids!
Old Apr 1, 2015 | 12:36 PM
  #466
Team_STILLEN's Avatar
Team_STILLEN
Originally Posted by purez33
It's a custom dual 2.5 with just a magnaflow 2.5 resonated xpipe. My power curve looks pretty healthy imo, actually looks like a few more hp @ 5,000rpm but still only like 5hp less up top than the new exhaust on that 370. I'm honestly happy with the safe tune you guys did with CARB and octane restrictions but I'm moving to the east coast and like everyone else, just looking to safely squeeze every last pony out of her. I plan on doing the frozenboost heat exchanger, 660cc injectors, turbosmart dual port bov, stillen oil cooler, and retuned for higher octane/flow.
Oil Cooler will definitely help. I'm not opposed to the heat exchanger either. The 660cc injectors are okay, but it depends on what brand you are going to use. I would personally select an injector with the best atomization as possible (maybe ID725's). The 93 octane will be a huge boost in your performance gains. Where on the east coast are you moving?
Old Apr 2, 2015 | 08:05 AM
  #467
RadioFlyer's Avatar
RadioFlyer
This dyno sheet you posted shows 340 as the baseline run. What did the car have on it when you went in for the tune?
Old Apr 2, 2015 | 09:02 AM
  #468
purez33's Avatar
purez33
I'm moving to Philadelphia. It had all the same stuff just the baseline tune that came with the kit.
Old Apr 2, 2015 | 09:12 AM
  #469
RadioFlyer's Avatar
RadioFlyer
So the canned tune that comes with the kit got you 340 on a Dynojet, then you got custom tuned, and they got another 48whp out of it?
Old Apr 2, 2015 | 11:00 AM
  #470
purez33's Avatar
purez33
Precisely
Old Apr 2, 2015 | 12:05 PM
  #471
Team_STILLEN
When did you get the original tune and what year is your car again? I can probably offer and explanation given that info.
Old Apr 2, 2015 | 12:32 PM
  #472
purez33's Avatar
purez33
It's a 2009 g37 I put that tune on when I installed the kit...the day before I got it dyno tuned.
Old Apr 2, 2015 | 12:36 PM
  #473
Team_STILLEN
Which was when? May 2011, June 2014???
Old Apr 2, 2015 | 02:01 PM
  #474
purez33's Avatar
purez33
Feb 2015
Old Apr 2, 2015 | 02:11 PM
  #475
ANMVQ's Avatar
ANMVQ
Almost sounds like mine, I made 300 WHP bolt ons, Made 342 with the Stillen SC and their "can" Tune, had a custom tune done and made 412, pick up 80 WHP, Only thing changed was the tune. That was in Jan-Feb 2012.
Old Apr 3, 2015 | 11:10 AM
  #476
Team_STILLEN
I know some of the old ROM's are still running the R10 tunes from the past. The new R11 tunes have been getting much better results. I'll ask Dave about his one and see which "canned" tune you were running after install.
Old Apr 6, 2015 | 11:35 AM
  #477
purez33's Avatar
purez33
Any of you guys do the frozen boost heat exchanger upgrade? What fittings did you guys use?
NOS Sniper St. 5/8" ID Hose to 1/2" NPT 21728331
Old Apr 6, 2015 | 11:44 AM
  #478
ANMVQ's Avatar
ANMVQ
NOS Sniper St. 5/8" ID Hose to 1/2" NPT*21728331
To too see what I stared is still going . Best mod for the kit you can get!
https://www.frozenboost.com/index.ph...b8c28b40bccf77
Water inlet and outlet are 1/2" NPT female threads, just like most air to water intercoolers
https://www.frozenboost.com/liquid-a...b8c28b40bccf77
Old Apr 6, 2015 | 11:57 AM
  #479
purez33's Avatar
purez33
Yeah I just ordered that heat exchanger! Do I need the 90° fittings? I wanna get anodized red, blue, or gold though to make sure it's as baller as humanly possible.
Old Apr 6, 2015 | 12:25 PM
  #480
ANMVQ's Avatar
ANMVQ
You do, you don't have to get them from them but you'll need them
