Ask a Professional Detailer... Brought to you by Detailed Image
Old Jun 2, 2009 | 11:29 AM
  #811
jnguyen's Avatar
jnguyen
aaaaaaaaaaaaaaaaaaaaa
Old Jun 2, 2009 | 12:16 PM
  #812
Michelangelo's Avatar
Michelangelo
I've seen a few methods discussed, but what is really the best way to remove all the wax, sealant, glaze, etc. that's currently on my car? I want to take it down to the clearcoat so I can clay it and then re-glaze, re-seal, and re-wax.
Old Jun 3, 2009 | 12:43 PM
  #813
Detailed Image's Avatar
Detailed Image
Auto Detailing Expert
jnguyen - Personally, I'd go over to Autopia.org and post up in the regional section to get a recommendation for a detailer in your area. Chances are you could get as good of service if not better for less.
I either wash with a high concentrated shampoo mixture such as Chemical Guys Citrus Wash & Gloss or Citrus Wash & Clear or use some Isopropyl Alcohol and water like a quick detailer. Either of those methods will remove previous coats of protection effectively and leave you with just your clear coat ready for your detail.
Let me know if there's anything else I can give you a hand with.
George
Old Jun 3, 2009 | 01:54 PM
  #814
WhosUrBuddiee's Avatar
WhosUrBuddiee
What is better for applying the supernatural. Black, Blue or Red pad?
Old Jun 4, 2009 | 01:04 PM
  #815
Detailed Image
I personally use a red foam applicator pad by hand and remove with a plush microfiber towel. You want to avoid using a buffer when applying or removing a wax.
George
Old Jun 4, 2009 | 01:24 PM
  #816
WhosUrBuddiee
Just ordered some red pads and supernatural. I hope it looks good on my vibrant red.
Old Jun 6, 2009 | 11:04 AM
  #817
Detailed Image
I'm sure it'll look stunning once your done. Post up some pics of your work after, I'd love to see it.
George
Old Jun 8, 2009 | 06:22 PM
  #818
Waxing exterior glass surfaces?
Is there any harm in waxing all of the exterior glass?
Old Jun 8, 2009 | 07:16 PM
  #819
Detailed Image
Nope, I do it myself. You just want to ensure that you remove it all so that it doesn't streak and impair your vision.
An all in one product that cleans and protects is another great option as it can remove some mineral deposits that may have accumulated.
Cheers,
George
Old Jun 9, 2009 | 01:19 PM
  #820
pyctici's Avatar
pyctici
im pretty sure this has been answered all ready but 55 pages are alot to go thru....for swirlies on my finish whats the best way to get that out? wetsand?, compound? or wax?
if wax would be the way to go, what brand in your professional opnion works the best?
Old Jun 9, 2009 | 08:53 PM
  #821
jdub1107's Avatar
jdub1107
Let's say a car has been clayed and sealed. The next time that I want to clay it, do I need to remove the seal? It seems like a good idea to clay without removing the sealant since there would an extra layer of protection from micro-marring. Is this line of thought correct?
Old Jun 10, 2009 | 07:19 AM
  #822
WhosUrBuddiee
I just clayed, polished, sealed my car 2 days ago. Now my Supernatural just came in. (I couldnt wait, it was a beautiful day.
Anyways, can I just spray the car down with a 50/50 alcohol solution and apply the wax or should I do a full wash? I don't want to remove the FMJ I just applied.
Old Jun 10, 2009 | 06:14 PM
  #823
Detailed Image
You're going to need to polish your paint. For detailed reading on how to remove the most swirls and properly polish your paint, read through our polishing guide. Ideally, you'll want to invest in a quality buffer, otherwise your results will be pretty limited. After reading the guide, if you have any questions on anything, please do not hesitate to ask.
Using a clay bar in general will remove most of the protection. You can opt to remove the protection prior to claying to ensure you get a completely fresh start, or you can wash, clay, then re-protect. The problem lies that if the clay doesn't remove all of the sealant and say there is some remaining, the new coat your applying is bonding on the old coat, which will have minimum durability. The reason for stripping the old coat in its entirety is so that you achieve maximum durability with the new coat.
You don't want to use alcohol solution to prep the surface, that would remove the coat of FMJ. If you only have a light dusting on your vehicle, you could opt for a quick detailer and a plush microfiber towel. If your vehicle is dirtier than a light dusting, then I'd recommend a full wash, then you can apply your coat of Supernatural. Be sure to keep us posted on how things turn out once you get a chance to use SN!
All the best,
George
Old Jun 11, 2009 | 09:41 AM
  #824
pyctici's Avatar
pyctici
^^^ thanks for the info
Old Jun 13, 2009 | 05:11 PM
  #825
jnguyen's Avatar
jnguyen
I recently Join Autopia after ya said I should try it and someone message me from my location. I need your opinion on him since I know Rotary buffering and wetsanding is bad if isnt done right and he uses them alot but he say he is really experience with it. It looks like he is very good with it.
here is his gallery
http://www.ajautodetail.com/gallery.htm
also here is a few post of his from autopia.
CL55
http://autopia.org/forum/pro-details...ll-detail.html
645Ci
http://autopia.org/forum/pro-details...bmw-645ci.html
ford Cobra
http://autopia.org/forum/pro-details...svt-cobra.html
What do ya think? Should I pull the trigger and schedule a detail from him? He seems very legit from all his post on Autopia. I am veery **** when it comes to my car so usually only I can drive or touch it so I figure i ask the pro before I make my decision
