My RB Project, going all in!
Old Aug 18, 2013 | 07:26 AM
  #556
G37Sam's Avatar
G37Sam
Meanwhile, project get the RPM signal to work has commenced, I made a dedicated thread for it as it may help others who plan to engine/ECU swap.
https://www.myg37.com/forums/body-in...ml#post3667729
Old Aug 18, 2013 | 03:29 PM
  #557
timp's Avatar
timp
Great idea Sam for those not too faint of heart to take the plunge.
Old Aug 28, 2013 | 03:33 AM
  #558
G37Sam's Avatar
G37Sam
I was hoping to update this thread with a dyno sheet but unfortunately, that didn't happen. What did happen though was that the ECU kept cutting at full boost at around 5000rpm. My AFRs and fuel pressure looked fine. I hooked up the laptop to try and figure out what was causing the cut but without any luck. The ECU cut one last time and the engine died. Deja vu. Parked on the side of the road in the middle of nowhere, I start the car praying in every religion there is out there that the engine is fine but no luck, there was a party in my crankcase. An episode of Top Gear later, my flatbed shows up.
The car goes back to the shop. My mechanic, cussing in every Asian dialect, had a full diagnosis report for me 24 hours later. Poor fella's pulled out my engine so many times I bet he could do it blindfolded now.
The damage:
1 Damaged rod
Damaged crankshaft
Main bearings drilled through the block when the crank was out of balance
Toasted bearings
Cracked (red) exhaust manifold
I'll get pics when I head down later on tonight.
Analysis:
ECU kept cutting harshly creating lean spots and at 19psi that threw insane EGTs that must've cracked the manifold. RB bearings also don't enjoy harsh cuts like that, that must've spun a few that ended up damaging my crank.
So far, I'm not 100% sure what was causing the ECU to cut. I'm in touch with Adaptronic ECU's support (and designer) who has been nothing but helpful. I was stupid enough not to log any of the boost runs, a log file would've been very helpful.
Raw Brokerage magically managed to secure all the required parts for me and are already on the way to Dubai for me. I figured while the engine was out, I may as well take advantage. So I may have ordered an extra part or two. What doesn't kill you only makes you stronger right?
On a positive note though, that 6266 turbo is one hell of a beast! I saw positive boost almost instantaneously, and at around 4k rpm, 19psi! Don't get me started on how awesome it sounded too! Can't wait to get it up and running.
Old Aug 28, 2013 | 08:17 AM
  #559
Can'tGme's Avatar
Can'tGme
OH NO! That really sucks man I hope she goes back together all right.
Old Aug 28, 2013 | 08:45 AM
  #560
Sorry to hear of your setbacks
I guess you're living the "no pain, no gain" to the letter, but the gain will be worth it
Old Aug 28, 2013 | 09:16 AM
  #561
ashmostro's Avatar
ashmostro
Sh*!. And yet awesome, I imagine the outcome will be!
Old Aug 28, 2013 | 09:56 AM
  #562
Elperuano's Avatar
Elperuano
Wow........
Old Aug 28, 2013 | 10:13 AM
  #563
SharpByCoop's Avatar
SharpByCoop
Sorry Sam. This is unfair, for all the good you've delivered.
Coop
Old Aug 28, 2013 | 05:55 PM
  #564
G37Sam's Avatar
G37Sam
Tell me about it man, the view of an engine-less bay was no fun earlier today.
Luckily, the pistons had no sign of detonation on them. There were signs of a lean mix on the exhaust valves, now I'm starting to worry that my AFR gauge is not calibrated well. I'm not sure lean spots from an overboost was enough to cause that.
Old Aug 29, 2013 | 11:45 PM
  #565
Staples's Avatar
Staples
Dammit, Sam! I was reluctant to read your post. I'm really sorry to hear the sh*tty news. I know how much this build has meant to you and the rest of us - this is such a one off rarity.
Godspeed in getting the car up and running, sir - GODSPEED!
Old Aug 31, 2013 | 09:24 AM
  #566
Buckeye G's Avatar
Buckeye G
Sorry Sam this is painfull to all of us I can only imagine how you feel!
Old Aug 31, 2013 | 06:06 PM
  #567
G37Sam's Avatar
G37Sam
Thanks guys. My bearings and rod arrived this morning and my mechanic is already on it. I'm also fitting a head drain to drain all the oil back from the cylinder head. I'm also looking into a surge tank setup with external pumps. Debating if I should do it under the body or in the trunk.
Old Sep 1, 2013 | 02:58 AM
  #568
ashmostro's Avatar
ashmostro
I say trunk
Old Sep 1, 2013 | 03:12 AM
  #569
G37Sam's Avatar
G37Sam
Originally Posted by ashmostro
I say trunk
But then I'd have to seal it (to avoid driving under the influence of petrol lol), drill through carpets and have fuel lines running in the trunk which limits trunk space big time. This is still my daily driver
Old Sep 1, 2013 | 03:26 AM
  #570
G37Sam's Avatar
G37Sam
Meanwhile, figured while the engine is open:
