The OFFICIAL "I have a wheel offset / tire fitment question!" thread
Old Mar 31, 2016 | 10:13 PM
  #1306
PNW_IPL's Avatar
PNW_IPL
Unfortunately the previous generation G35 coupe can handle much more aggressive offsets, the 265s on those wheels you plan on getting would be the best plan, you still may need additional camber but you'll have 5mm more to work with vs. the 275s.
Thanks man appreciate the help!
Old Apr 1, 2016 | 11:58 AM
  #1307
Infiniti+Beyond's Avatar
Infiniti+Beyond
Looking to grab a set of wheels for my 2011 G37X Sedan: 20x9 et38 with 245/35/20 tires. Will I have any issues with fitment based on the offsets? I see alot of guys running 20x9 et32 but havnt found anyone running 20x9 et38 all around.
If it's been answered (probably has) I apologize! I swear I searched but probably skipped over it by mistake.
Thanks in advance!
Edit: Will be going with Swift Springs
Old Apr 1, 2016 | 07:40 PM
  #1308
Thanks in advance!
Those will be fine, keep in mind the 19" coupe wheels that a lot of sedan guys run are 8.5+43 & 9"+45 staggered, so yours would be 7mm further out than those rear coupe wheels, this will be a better fit at the fender and will still have some room w/ those 245s, so no rubbing there
Old Apr 7, 2016 | 02:28 AM
  #1309
MNfiniti's Avatar
MNfiniti
I swear I hate offset questions but here we go again...
370z Sport Wheels
F: P245/40R19 19x9 +47
R: P275/35R19 19x10 +30
Will they fit G37x Sedan? I plugged in the numbers, +1.8 inches of poke in the rear, so not sure...
Old Apr 7, 2016 | 02:36 AM
  #1310
I don't see a problem with those sizes and offset fitting but I could be wrong.
Old Apr 7, 2016 | 07:44 AM
  #1311
VenomGT9's Avatar
VenomGT9
You're sure you want to run that much stagger on an AWD...?
And by poke, do you mean 1.8in past the fender OR just 1.8 further out than what you are now
Old Apr 7, 2016 | 08:41 AM
  #1312
the93owner's Avatar
the93owner
370z Sport Wheels
There's no issue with running a staggered setup per se, as long as you keep overall diameters the same (which with those tire sizes looks okay). The only thing about that specific spec is the rear which will be a pretty aggressive fit. It's been done on a sedan before but not sure what kind of modifications were necessary.
Old Apr 7, 2016 | 09:00 AM
  #1313
Yeah, the main problem w/ that is since it's so tight in back it really limits your tire selection, and w/ AWD you really MUST be within 1% Front to back diameter variance. Something like a 235/40 & 265/35 combo possibly. The 245/275 setup may need some camber help in back.
Old Apr 7, 2016 | 09:42 AM
  #1314
G37xhibeet's Avatar
G37xhibeet
A shot in the dark here but what's the lowest offset anyone here has run in the rear of a coupe with 285/30 on a 20x10 and still stayed in spec?
Old Apr 7, 2016 | 11:50 AM
  #1315
MNfiniti's Avatar
MNfiniti
Ok, well after hearing from you guys and doing more research, I think I'm going to pull the trigger... Plus I saw this and : 0
Old Apr 7, 2016 | 01:56 PM
  #1316
MaQG37's Avatar
MaQG37
absolutely 0 modification with the 370z wheels. However, you want to run a 20mm spacer up front to make thinks look even.
Old Apr 7, 2016 | 02:21 PM
  #1317
PNW_IPL's Avatar
PNW_IPL
19x10 +30 re30 clears oem akenbono
Update to my situation. Wheels and tires arrived so i decided to see if the front 19x10 +30 clears our oem akenbono. It does with ease 2-3 mm clearance. I found a website that says it does and its face type L1 which gives the most bbk clearance as opposed to L2 which has the most concavity of the re30 lineup.
Thought id share since people run gtr wheels it might help since these are gtr sizes.
Size:  221.8 KBName:  20160407_104517_zpsxltofwvp.jpg
Size:  192.4 KBName:  20160407_104544_zpswar6hfn3.jpg
Old Apr 7, 2016 | 08:17 PM
  #1318
Yummy^^^
Old Apr 9, 2016 | 06:26 AM
  #1319
dessidee90's Avatar
dessidee90
Will these wheels clear the sport brakes? I really want these wheels
Old Apr 9, 2016 | 08:49 AM
  #1320
You'd have to contact the vendor on that one^^^^Tirerack is good about that.
