The OFFICIAL "I have a wheel offset / tire fitment question!" thread
Old Apr 9, 2016 | 09:40 AM
  #1321
pledes23's Avatar
pledes23
Hey folks got a steal of a deal on some wheels and wanted to see how much of a clearance issue will I have in the rear. I'm currently dropped on Swifts.
Wheel Specs:
19x8.5 +38 5x114.3 255/36
19x10.5 +45 5x114.3 295/30
Any guidance is appreciated. Thanks in advance.
Old Apr 9, 2016 | 10:14 AM
  #1322
dessidee90's Avatar
dessidee90
Thanks I do see it displayed a message saying it doesn't fit with the oem tire specifications but they gave me a set of square tires 245/35r20. Does a square set up matter for a rwd? What's the pros and cons , my current set up is staggered
Old Apr 9, 2016 | 12:01 PM
  #1323
VenomGT9's Avatar
VenomGT9
Wheel Specs:
I'm going to guess this is for a coupe. Fronts will be fine, may have some rubbing in the rear with those tires depending on your camber.
Square on a RWD will cause oversteer, if that sort of thing matters to you. Personally, I'd keep with the stagger if you can.
Old Apr 9, 2016 | 02:05 PM
  #1324
pledes23's Avatar
pledes23
Originally Posted by VenomGT9
I'm going to guess this is for a coupe. Fronts will be fine, may have some rubbing in the rear with those tires depending on your camber.Square on a RWD will cause oversteer, if that sort of thing matters to you. Personally, I'd keep with the stagger if you can.
I have a 2012 G37S Sedan, currently in natural camber. Was hoping I didn't have to upgrade once I install the wheels.
Old Apr 9, 2016 | 04:11 PM
  #1325
Originally Posted by MNfiniti
Ok, well after hearing from you guys and doing more research, I think I'm going to pull the trigger... Plus I saw this and : 0
This car is gorgeous
Old Apr 9, 2016 | 06:14 PM
  #1326
Here's Dagons Sedan on those spec wheels/tire, it's tight but he made it work
https://www.myg37.com/forums/brakes-...-my-sedan.html
And pics w/ a drop
https://www.myg37.com/forums/private...ugs-tires.html
Old Apr 9, 2016 | 09:12 PM
  #1327
evil-G-nius's Avatar
evil-G-nius
Is this really a thing? Does that only count for the sedan?
Old Apr 10, 2016 | 03:11 AM
  #1328
MNfiniti's Avatar
MNfiniti
I swear I hate offset questions but here we go again...
370z Sport Wheels
F: P245/40R19 19x9 +47
R: P275/35R19 19x10 +30
Will they fit G37x Sedan? I plugged in the numbers, +1.8 inches of poke in the rear, so not sure...
Took me a minute to get the swift springs installed (pain in the A) and wheels on... but after a bunch of hours of work... Nom Nom Nom...! Rear poke a tad bit more then I would like, but they are growing on me, and fronts deff need spacers, going to try the 20mm spacers people have recommended for the fronts, but part of me says I should get 10mm's...
Swift Springs and 370z's.... '12 G37x
Old Apr 10, 2016 | 08:55 AM
  #1329
pledes23's Avatar
pledes23
And pics w/ a drop
Thank you! My cousin has a fender roller so if push come to shove I'd roll them a bit to make sure the tuck. If the weather clears up I'll have them on by the end of the week.
Old Apr 10, 2016 | 09:27 AM
  #1330
Nice job! Do you have a pic running down the side? If the rear poke doesn't completely grow on you you could always go w/a 235/40 265/35 tire combo to give you a little relief back there when those tires are ready to be replaced.
Hard to argue w/ the quality and weight savings of those Forged Z wheels, glad you took the leap
Old Apr 10, 2016 | 10:22 PM
  #1331
MNfiniti's Avatar
MNfiniti
Here's the poke of the 370z in the rear... Everyone i've talked to love it, but i'm still unsure.
12 G37x Sedan w/ 370z Sport Rays 275/35/19 +30
Old Apr 11, 2016 | 09:44 AM
  #1332
What camber spec are you at back there? Might want to go .5 degrees more negative, should get that tire right at the fender line. IMO that would be a better look.
Old Apr 11, 2016 | 11:40 AM
  #1333
VenomGT9's Avatar
VenomGT9
Looks good man, much better pick than aftermarket.
Old Apr 11, 2016 | 12:35 PM
  #1334
MNfiniti's Avatar
MNfiniti
It's still the OEM camber, this was about an hour after dropping her on swift springs. I slapped the Rays on to see fitment and stuff, put the oem 17's back on for now. Haven't been in for an alignment yet, going to wait a week for the springs to settle. Also, the Rays rears need replacement and the prior owner spray painted / rattle canned the wheels black, so need to clean those up. I think I'm going to keep them black, but his paint job was terribad...
Old Apr 11, 2016 | 01:57 PM
  #1335
VIVID's Avatar
VIVID
Pyroclastic Flow
MNfiniti -
Thought I would post this here rather than our PM thread:
275/35 Michelin PSS, rear camber -1.7, FA 500 coils, 26.75" from fender arch to floor on the rear, 1/4 tank of gas (this makes a BIG difference)
That's me in the reflection, zipping around on my shop stool, lots of fun!!!
Sean
