The OFFICIAL "I have a wheel offset / tire fitment question!" thread
Old Mar 2, 2015 | 09:17 PM
  #601
Originally Posted by Xcalibur
Thanks blnewt! I had my wheel guy work it out with Lexani. I got them with flush offsets at front = +22 and rear +37. I test fitted and they clear the BB calipers by at least half inch(front). I'll post up photos in 3 weeks once i order tires and put them on
What tire sizes have you settled on?
Glad the Lexanis worked out and you have plenty of clearance at the caliper.
Look forward to pics!
Old Mar 3, 2015 | 12:52 PM
  #602
DawsonSkalsky's Avatar
DawsonSkalsky
Would 20x10.5 +25 rear with a 245/30 work in the front for a coupe?
Old Mar 3, 2015 | 03:42 PM
  #603
Not sure what you're wanting~
Coupe or Sedan, and are you wanting to run a square 10.5 +25 setup, just need more info.
Old Mar 3, 2015 | 04:19 PM
  #604
DawsonSkalsky
G37 rwd coupe
Front - 20x10.5 +25 wrapped in a 255/30
Rear - 20x10.5 +20 wrapped in a 265/35
Old Mar 3, 2015 | 04:20 PM
  #605
DawsonSkalsky
G37 rwd coupe
I know the rears should be fine but I'm wondering if I would be able to be lowered in the front with this sort of setup
Old Mar 3, 2015 | 05:13 PM
  #606
Are you going to run more camber? I think the front is going to be too close at in-spec camber. What setup are you running right now, because if you have all your current specs you can run them in the calculator to give you a better idea
Old Mar 3, 2015 | 11:13 PM
  #607
DawsonSkalsky
Completely stock as of right now. I'm just trying to get everything put together at the same time. I will most likely be lowered on stance coilovers
Old Mar 4, 2015 | 12:08 AM
  #608
Ok, assuming you have a non-S coupe your OEM setup is 18x8 +43 offset 225/50/18, go to the calculator and you'll get~
Front wheels will extend out 49.7mm (almost 2 inches)
Rear Wheels will extend out 54.7mm from your current setup.
If you have an S model it will be a bit different, but still very aggressive.
Old Mar 4, 2015 | 11:55 AM
  #609
DawsonSkalsky
I do have the s model but thank you for your help
Old Mar 4, 2015 | 12:19 PM
  #610
Mulatto's Avatar
Mulatto
Hey Blnewt, I tried ordering my new wheels in the specs you suggested, 20x9 +22 and 20x10 +25, but Discount Tire doesn't currently have the tire I want in 275's. Will I be able to run a 285 rear on that 20x10 +25 rear and still clear the fender? Would there be any rubbing issues?
Thanks in advance.
Old Mar 4, 2015 | 02:05 PM
  #611
araaadi's Avatar
araaadi
It's now spring and I am getting a pretty descent tax return so I am looking to do some rim shopping. I have a 2011 g37s coupe lowered on stance super sport coils. I am looking to do a fairly aggressive set up and I don't mind rolling/pulling rear fenders. I am currently looking at the new TSW Bathurst rims in 19x9.5 for front and 19x10.5 for rear. What kind of offsets do you guys think I can fit on there? I am looking to either run my stock size rubbers (they're 2months old) or if possible to get a meaty tire look I don't mind getting new tires, what sizing would fit? I haven't done too much research on wheels so all the help I can get would be great.
Old Mar 4, 2015 | 03:41 PM
  #612
Xcalibur's Avatar
Xcalibur
Im getting the same sizes i had before. 275/30/20 rear and 245/30/20 front. I went down in front from 35 profile to 30 to eliminate rubbing on fender liner. Thanks again!
Old Mar 4, 2015 | 04:26 PM
  #613
Thanks in advance.
I think I'd try another vendor, I think the 285s would be cutting it too close. If possible maybe Discount tire can try a test fit w/ a 285?
Old Mar 4, 2015 | 04:29 PM
  #614
Your stock tires will be too stretched for those rim widths, so I'd scratch that plan. Do you have the list of offsets for those rims? I can check a bit tonight when I have some time.
Brad
Old Mar 4, 2015 | 06:36 PM
  #615
araaadi's Avatar
araaadi
I wasn't able to find much information on their website, but according to one retailer, the 19x10.5 is 27 offset, and if i go 19x9 offset is 30, and 19x9.5 offset is 39
