The OFFICIAL "I have a wheel offset / tire fitment question!" thread
Old Jun 23, 2019 | 01:44 PM
  #2461
Originally Posted by Zack Sharp
Beautiful sedan you have. Amazing fitment and clean clean clean!!
So i went ahead and just pulled the trigger on some stance coilovers and I was curious what other parts I might as well upgrade when they go to do that work. Any idea what other parts I should do? I have seen ball joints, tie rod ends, new bushings, but I am still fairly new to the car and have never done suspension work nor what parts are good. I am going to try 245/40(45)/19's and 275(285)/35(40)/19's but I am just not sure how everything works still. It is extremely hard to not what will work/not work and looking online just runs me through the ringer in my head just trying to make sure everything fits,works, doesn't scrape etc etc. For sure not going to slam it but I will probably go fairly conservative on the drop just looking to get a more aggressive look. Any parts that are just a no-brainer?
You have been extremely helpful blnewt, thanks man! See your name all over.
Thanks for the kind words Zack
As far as coilovers and being slammed, most coilovers w/ the exception of Tein Basis drop pretty low even at the highest settings. It won't be slammed but not real conservative either. I would recommend at the minimum a rear camber/toe kit as you typically can't get rear toe in spec without it, and having toe out of spec is a tire killer. Ideally getting the complete F&R camber set is best (I've been running that way from the start). This will allow you to easily get your alignment proper and you can even set caster (I prefer it higher to eliminate or reduce any wander). Rear kits (SPC brand) run about $150, fronts about $400, the rear toe slot needs to be elongated to allow more travel from the new toe bolts, but this is pretty easy w/ a dremel & wafer wheel)
Old Jun 23, 2019 | 03:45 PM
  #2462
Zack's Work's Avatar
Zack's Work
https://www.z1motorsports.com/suspen...ts-p-5147.html
So I found this and price isn't awful but do you also need the toe arm? if so, what would be a good complete set that works?
Will 245/45/19 and 275/40/19 clear Sport Brakes and be able to be lowered on 19x9.5+22? with above arms ^?
Old Jun 23, 2019 | 06:41 PM
  #2463
That's a complete F&R kit, you won't need toe arms unless you remove the lower control arms (aka spring buckets) if your coilovers are the "true type", The toe bolts w/ the elongated slot will adjust toe back to spec. if you run the traditional OEM type rear suspension (springs separate from the shocks).
If you are getting the "true coilover" setup you can still use the OEM spring buckets w/ that toe bolt setup as well.
The tires on that width/offset won't be a problem but you MUST confirm brake clearance w/ wheel vendor, even some wheels w/ aggressive offsets still have clearance problems depending on design, backspacing, etc.
Old Jun 23, 2019 | 06:51 PM
  #2464
Zack's Work
Brand: ESR
Model: SR08
Partnumber: 99551422+SR08HB
Color: Machine Face
Backspacing: 6.12
Offset: +22
Wheelsize: 19
Wheelwidth: 9.5
Hubbore: 73.10
Wheel Exposed Lugs: Yes
Wheel Material: Alloy
Wheel Weight: 28.55 lbs
Wheel Structure: One Piece
Wheel Spoke Number: 5
Bolt Patterns: 5x114.3 (5x4.5) 5x114.3 (5x4.5)
These are the specs of the wheels from fitment industries. The guy from ESR said it was agains't policy for them to say whether they would fit or not but said it shoulnd't be a problem so I purchased them, but again still very new to all of this so I have no clue.
Old Jun 23, 2019 | 07:44 PM
  #2465
Originally Posted by Zack's Work
Brand: ESR
Model: SR08
Color: Machine Face
Backspacing: 6.12
Offset: +22
Wheelsize: 19
Wheelwidth: 9.5
Hubbore: 73.10
Here's a sedan w/ the same ESR wheels & specs and they clear the brakes so you're good to go!
https://www.fitmentindustries.com/wh...tein-coilovers
You should get hub adapter rings to eliminate or reduce possible vibration issues, here's a set on ebay
https://www.ebay.com/i/263431621462?chn=ps
And be sure to get new conical/tapered seat lug nuts, your OEM "mag-style" lug nuts won't work there. I like the Gorilla sets FWIW.
Old Jun 29, 2019 | 12:51 PM
  #2466
G3SIETE's Avatar
G3SIETE
Would be a more flush fit but still tuck well inside the fenders, should be happy w/ that setup.
What about a 305/25 on the rear? Would that be pushing it? Ive seen some guys running vossens with similar setups run that.
Old Jun 29, 2019 | 01:12 PM
  #2467
305/30 would be better, only 0.18" taller than a 255/35 in front, the 305/25 will be over an inch shorter than the front tire.
Old Jun 29, 2019 | 01:19 PM
  #2468
G3SIETE's Avatar
G3SIETE
Ok yea i see it now on the tire calculator. 295s are a little harder to source so I may just have to order them online.
Old Jul 9, 2019 | 04:17 PM
  #2469
RJ's_G37's Avatar
RJ's_G37
Hey guys (Brad), 20x9 +38 all around wrapped in 245/35..gonna be going on a sedan on coils,is that a good tire setup for it?
Old Jul 9, 2019 | 09:03 PM
  #2470
Those will work fine, could run 255/35s if you want a bit more tire. Nice width & offset for a good sedan fitment.
Old Jul 9, 2019 | 09:14 PM
  #2471
RJ's_G37's Avatar
RJ's_G37
Great thank you I'll keep that in mind when new tires are due
Old Aug 12, 2019 | 01:32 PM
  #2472
RosaP-37S-G's Avatar
RosaP-37S-G
Raises hand from back of class
About to go 18x10 +38 all square on a sport sedan. Should I go square on the tires too or do something like 255/40 275/40 ?? I'm lowered on stance coilovers, (spl camber too). I'm hoping theres no awkward gap going with a 40 series tire, but wasn't sure if 45's would be too bulky. Appreciate you guys!
Old Aug 12, 2019 | 07:53 PM
  #2473
fastrx7man's Avatar
fastrx7man
Picked up an 08 coupe for my son. Want to make sure the wheels I am about to buy are going to work. They are coming off a sedan.
Wheels are 19x8.5 +25 with 245/40/19 tires up front and 19x10 +40 with 275/35/19 in back.
Am I going to have any rubbing issues? Thanks for your help...
Old Sep 6, 2019 | 12:22 PM
  #2474
jthibodeau89's Avatar
jthibodeau89
American Racing AR924 Wheels on a 2010 Coupe Sport
I'm finally getting around to working on my 2012 G37xS Coupe. Time for tires, so instead of bumping the upgrade out, I've decided to take the plunge. Will be putting on the full coilovers that are sitting on the shelf soon with SPL arms and links FR and RR. Tires will be 255/35 FR and 295/30 RR. I prefer the split 5 spoke style and came across the AR924 in 20 x 9 +35 FR and 20 x10.5 +45 RR. I know that the offsets will work, but American Racing advised my local tire shop that the fronts will not clear my OEM sport brakes. I find that hard to believe since I went up to 20" wheel diameter. Does anyone have experience with these wheels in 20" on a sport brake setup? Thanks for any help that can be provided.
My longer term plan is to install the full set of GTR calipers and rotors I have sitting in the garage, but this will probably require new hats along with the caliper adapters, and I just don't have the time right now.
Old Sep 12, 2019 | 02:28 PM
  #2475
gord27's Avatar
gord27
Read several pages back but couldn't find my exact setup so hopefully, this is a quick answer. I've got a squared setup on my xS sedan of 19x8.5 +43 with 255/40 tires as I like a meatier look. +43 is obviously a bit tucked so the plan was for a 20mm spacer. After seeing the car lowered (BCs), I figured that might be a bit aggressive so I traded for 15mm. Will it look OK with 15mm squared? Or should I go back to 20mm for the rear? I assume I won't have any rubbing issues given I'm running -2 to -3 camber all around. TIA!
