The OFFICIAL "I have a wheel offset / tire fitment question!" thread
Old Dec 11, 2015 | 09:02 PM
  #961
Originally Posted by Solman88
Nice. Don't know if it's the appropriate place to ask but, what's your opinion on the Ground Force GF06 Gloss Black and Rohana RC10 All Matte Black? those two looks to be my pick for wheels as of now, or any other recommendation? I have a whole winter to decide. Thank you.
It looks like the GF06 come in 19x8.5 (not 8") that's actually better, a +35 will be another 6mm out for a nice fit at the fender and a 245 width tire is a better mount on an 8.5". That's what I found on this site anyhow~
http://www.elementwheels.com/proddet...rod=gf61995blk
I like those a lot better the the RC10s, those RC10s have spokes that tuck into the barrel rather than continuing all the way to the barrel edge, IMO that looks a bit off. I do like the Rohanna RC7 much better, those spokes go all the way to the edge.
Rohana RC7 Matte Graphite Wheels
Here's a couple more that you might like
19x8.5 Niche Form Matte Charcoal M157 Wheels
Niche Essen Matte Black M147 Wheels
Site Vendor Jason @Getyourwheels is a good source for most of these wheels.
Old Dec 11, 2015 | 09:14 PM
  #962
Solman88's Avatar
Solman88
19x9.5 Ground Force GF06 Gloss Black (Concave) Wheels
Bro, you're amazing. Many thanks for the help. I should have everything ready by Spring of next year (Just gotta get through MN winter). Will report back with pics!
Old Dec 11, 2015 | 09:58 PM
  #963
briang3794's Avatar
briang3794
Hi guys i have a 2012 G37xS sedan. I wanted to get the Niche M158 and can't decide between 19s or 20s. Thinking of the 9.5 all around. Will the 20s clear? Planning on driving even in the snow so on hills or weird angles will it clear or will i have problems?
Old Dec 12, 2015 | 12:42 AM
  #964
Copy of my reply in your newbie thread~
Welcome to the site.
The 19s come in 8.5 & 9.5" widths
The 20s only come in 8.5/10/10.5" widths
Niche Form Matte Bronze M158 Wheels
The offsets for the 19x9.5 are +35, these wheels will extend out 33mm from where your current OEM wheels are (your OEM wheels are 18x7.5 +43)
Use this calculator when trying new setups
That setup will look ok if you lower your G and run a bit more negative camber, At stock height the wheels will be right at the fender. This would be running 245/40/19 tires.
Check this thread for some various "square" setups.
https://www.myg37.com/forums/brakes-...post-here.html
Old Dec 12, 2015 | 02:02 AM
  #965
mrdacheek's Avatar
mrdacheek
So after a bit of research here, using the calculator, the calculator at willtheyfit.com, and looking at pics I went with 19x8.5 Miro 111 +35mm offset (buy 3 get 1 free deal) with Toyo Proxes 4 Plus 245/40r19 all around on my 2012 G37 non-sport.
I wanted something that looked better than stock, but not something that looked totally aftermarket, if that makes any sense.
Fitment is perfect, they fill out the wheel well nicely, sit perfectly flush with the fenders, tire is almost perfectly square on the wheel as I didn't want any stretch so I would have some protection from curbs, no rubbing or anything like that and my diameter decreased by less than .5mm overall. Car handles much better, rides a tad rougher, but the tires I had before were the most god awful things in the rain (Linglongs - from the dealer).
I know a lot of people ask questions and then never post the results. So here you go, maybe it'll help someone else down the road.
Thanks for the help guys!
Before
After
Old Dec 12, 2015 | 02:55 AM
  #966
evil-G-nius's Avatar
evil-G-nius
looks good...needs more low. LoL
Old Dec 12, 2015 | 03:28 AM
  #967
hotdawwgman's Avatar
hotdawwgman
I recently picked up some work t1s'... They are 8.5/9.5 35 offset... What size spacer would be ideal for my coupe with sport? I was think 25mm for the front and 20mm for the rear... I have Megan Coilovers I need to install to make it look better. What are thoughts guys?
Old Dec 12, 2015 | 05:42 AM
  #968
nguyenp1's Avatar
nguyenp1
Hey guys I'm a little new to this forum and haven't posted much in here. I recently purchased a set of Weds lxz for my 08 g37 coupe. Here are the specs: 19x9.5 +18 (3.5 inch lip) fronts and 19x10.5 +18 rears ( 4 inch lip ).
I'm trying to figure out what size tires would make my car have a perfect fitment look or flush. I wouldnt really want to stretch out my tires. I'd like the tire to have some meat for grip and have a flush look also. I'm currently tucked on bc coil overs also.
Any suggestion guys? (:
Old Dec 12, 2015 | 08:56 AM
  #969
Should be a nice setup
I'd get the wheels installed, the car dropped to the height you want, and then see exactly how much spacing you want. Spacers are simple to install later (at least the bolt on versions). Much better than buying spacers first then regretting it. What size tires are you planning to run?
Old Dec 12, 2015 | 08:59 AM
  #970
This is a question that's better in the hellaflush thread, no way around it, you're going to have to run stretched & cambered~
https://www.myg37.com/forums/wheels-...sh-thread.html
Old Dec 12, 2015 | 12:21 PM
  #971
hotdawwgman
Thanks! They only problem is I need spacers because the fronts won't clear the akebono's... I am pretty confident with all my research this will sit nice... Tire size, most likely 225/40 front and 245/40 rear
Old Dec 13, 2015 | 12:08 AM
  #972
nguyenp1's Avatar
nguyenp1
Thanks a lot buddy for showing me where to post.
Old Dec 17, 2015 | 08:42 PM
  #973
Alexis Rivera's Avatar
Alexis Rivera
Hi guys want to run 19/9.5 off 22 all around on my 2011 g37x sedan, will this setup work
Old Dec 17, 2015 | 10:03 PM
  #974
Be better w/ +30 all around, check pg 1 of this thread ***** Choy runs some pretty aggressive 9.5 sets
Old Dec 17, 2015 | 10:07 PM
  #975
Mr_Mer's Avatar
Mr_Mer
Those numbers apply for coupe as well (on stock height, for now)?
