The OFFICIAL "I have a wheel offset / tire fitment question!" thread
Old Dec 29, 2022 | 06:26 AM
  #2521
StockG37S's Avatar
StockG37S
Need help :(
Ordered 18x9.5 + 30 wheels (stock suspension) but don’t really know if they’ll fit according to these forums, suggestions to get a nice flush
Old Dec 29, 2022 | 09:24 AM
  #2522
projectpanda13's Avatar
projectpanda13
that’s a great size you picked. It’ll be nice and flush.
mare you afraid it will be sunken in?
Old Dec 29, 2022 | 02:37 PM
  #2523
StockG37S's Avatar
StockG37S
Honestly i’m scared of having to modify my fenders, thats why i reached out to this thread.Any recommendations on tire sizes? i had an idea of
245 40 Front 255 40 Rear
Old Dec 30, 2022 | 08:27 AM
  #2524
garrett23rd's Avatar
garrett23rd
I have a 2009 g37s with Akebono brakes. Will 4 18x9 +15 370z rears fit without sticking out too much and will they clear the brakes?
Old Feb 4, 2023 | 07:06 AM
  #2525
atl.jacob's Avatar
atl.jacob
2012 Coupe wheel/tire help!!
looking to get a set of Aodhan DS02 wheels, F: 19x9.5 R: 19x11 they come in offsets of +15 and +22 and i’m not sure what to choose. i want to run DSW06 245/35 in the font and 275/35 rear..i will be lower on Tein Flex Z coilovers with spc rear camber arms if that matters. i want to make sure i pick the right size. thank u!
Old Feb 16, 2023 | 08:52 AM
  #2526
Angel246837's Avatar
Angel246837
Stretched tire setup help
What tire sizes would I need to get a mild stretch on 19 x 9 rims and 19 x 10 rims with +28 offset? Don’t wanna go to crazy but want that mild stretch look. I have a 2008 g35 sedan and lowered so it not trying to rub either
Old Mar 25, 2023 | 06:28 PM
  #2527
TrintCole's Avatar
TrintCole
I have a 2013 ipl coupe. Stocks suspension. I found some feradda fr4 wheels.
fronts are 19x9.5 +40 with 245/35 tires
rears are 19x10.5 +43 with 275/40 tires.
i think i will need a spacer in the front to clear the big brakes. 15-20mm
Should i get a spacer in the rear? I want as flush of a look as possible without needing fenders rolled/pulled. No rubbing if possible.
will these fit? I’m getting the whole set for less than the cost of the wheels. I was about to buy new wheels and tires but these came up. I could still get different tires if needed. Open for suggestions.
Old Aug 24, 2024 | 09:28 AM
  #2528
slproq's Avatar
slproq
19x9.5 Wheels that clear akebobo
If you have a question about wheel offsets on your coupe, sedan, or convertible post it here. But before posting, please do a little research on your own. Check with another member who you are aware has a similar offset as yours and ask them. Check this thread thoroughly to see if it's already been asked/answered. Use the tire/wheel calculator at the top of this page in orange to see if it answers your question. Search the entire forum to see if it has been addressed somewhere besides the Wheels & Tires forum. Ask a trusted wheel vendor that you are considering buying from to see if they might already have dealt with your situation and have an answer. If you still haven't found what you are looking for, post your question here so that these questions are all in one place that's easy to find for those wheel fitment gurus who are willing and able to help answer your questions.
If you are replying to a question with an answer, please make sure you are knowledgeable and have the correct answer. Double check that you are right before posting and giving someone the wrong answer or subjecting yourself to the scorn and ridicule of your peers.
Lastly, we will attempt to consolidate existing offset question threads into this thread so that they are easy to find and the thread can serve as something of a reference. Please help by reporting stray offset question threads (by clicking the "Report Post" button in the first post of the thread) so that the staff can do our best to try to move them all here.
Thanks and happy modding!
Got a 2014 Q60 IPL with Advan Gts & Micks on rear. Wanted to match up front but Advan isnt keen on breaking sets. Anyway, I know 19x9.5 29mm GTs fit, but until I track them down I need a bridge pair of wheels. There aren't many viable options. I found some Vors tr37s that might fit the bill (22mm). Anybody run this setup with akebobos? I wanna know if the wheels will clear the breaks.
Thanks in advance... complete noob here.
Old Sep 16, 2024 | 11:23 AM
  #2529
projectpanda13
I couldn't find much on the Vors TR37 but the ESR SR07 is the same style (TE37 replica) and in 19x9.5 +22 does clear Akebono up front.
https://www.fitmentindustries.com/wh...s-accelera-phi
https://www.customwheeloffset.com/wh...xani-lx-twenty
https://www.fitmentindustries.com/wh...eral-595-rs-rr
Old Mar 11, 2025 | 11:06 AM
  #2530
Black_G's Avatar
Black_G
I've been here before, hoping to get more feedback. I'm almost ready to pull the trigger.
https://www.myg37.com/forums/wheels-...-anyone-2.html Here's my thread with pics and some back and forth.
Front-
Looking to do
285/30R18 on a 18x10ET27 wheel
Rear-
Looking to do
305/30R19 on a 19x11ET35 wheel
Front I test fit a 285/30R20 on a 20 x 10 ET30 and it fit without issue, pulling it in 3mm I hope to keep it flush with the fender.
Rear currently is 285/30R20 on a 20x10ET30. Sits close to flush and i have about 2 inches of room between tire and shock.
Any feedback before I move ahead with custom forged wheels would be greatly appreciated.
Old Mar 30, 2025 | 11:16 AM
  #2531
jayr0am's Avatar
jayr0am
Originally Posted by AnoviaG37coupe
Fitment Question for tire specs!
I was lucky enough to win a set of anovia 3 piece wheels.
Gels at Fitment industries helped out with the wheel specs.
Front 19x9.5 +22
Rear 19x10.5 +22
i found a vehicle with the same wheel specs and they were running 245/40 in the front and 275/35 in the rear. From a little research I found that this is a slight stretch.
I will be on coilovers and the z1 suspension arm kit shortly.
I'm assuming that stretch probably isn't a good thing if I ever plan to drive the car hard but I also don't want any rubbing in the rear or a ton of camber either.
What specs would you guys recommend?
What did you end up going with? Any rubbing, or did you need to trim anything?
Old Mar 30, 2025 | 11:49 AM
  #2532
jayr0am's Avatar
jayr0am
Smile Tire fitment for 19x9.5 +27 and 19x10.5 +28 on sport coupe
I've been scouring forums for a tire setup for Leon Hardiritt Bugel wheels - 19x9.5 +27 and 19x10.5 +28 on my 2014 sport coupe (Akebono brakes) that's lowered on coilovers, and won't need any fender rolling or fender stretching. I'm ok with some fender liner trimming/removal if needed. I just don't want to rub on metal. I'm currently on Rohana RFX11 front: 20x9 +35 255/35 rear: 20x10 +40 285/30 with zero fender clearance issues (rubs slightly on rear fender liner), but as you can see below, everything looks sunken.
I've seen some setups with 19x9.5 +22 on 245/40 and 19.10.5 on 275/35 , but they never say if they're rubbing or if any modifications were needed.
Thanks, in advance!
Old Jun 20, 2025 | 03:22 PM
  #2533
LMR's Avatar
LMR
Rays Gram Lights 57cr
So I just pulled the trigger on a set of Gram Lights 57CR wheels 19x8.5 / 19x9.5 +35. I currently have 10 mm spacers which I plan to leave on. I'm on stock suspension now except for 370z struts in the front. I plan to go 245/40 in front and 275/35 in the rear. Any opinions on my tire choice? Everything I read so far says they will fit fine. Thank you.
Old Jun 20, 2025 | 11:03 PM
  #2534
Muck_Man's Avatar
Muck_Man
Coupe or sedan? Either way, the wheel dimensions and offsets are pretty close to the 10 spoke coupe 19's. I run the coupe 19's with the same tire setup with the 245 in front and 275 in back on a sedan with Swifts and 15mm spacers, which is a pretty popular setup. I think your overall more agressive offsets than the coupe 19's with the smaller spacers will work just fine.
Old Jun 21, 2025 | 08:47 AM
  #2535
LMR's Avatar
LMR
Sorry, it's a coupe sport with the 19s you're referring to
