The OFFICIAL "I have a wheel offset / tire fitment question!" thread
Old Oct 8, 2017 | 05:21 PM
  #2056
BrianHasAg37's Avatar
BrianHasAg37
Hi there.
I want to get 19" Forgestar CF5V on my 2008 G37 Coupe Journey. I'm unsure of what wheel depth and offset to get it flush with fender. Also, should I do 245/40/19 275/35/19 tire setup or is there a better setup? Thanks
Old Oct 8, 2017 | 11:32 PM
  #2057
Originally Posted by BrianHasAg37
Hi there.
Welcome to the site.
Is your G lowered or planning to lower? Are you going to run in-spec camber?
Do you want to run even more tire there?
Since Forgestar lets you select exact offsets you could run up to a 305 width tire in back and 255s or 265s in front depending on the width & offsets you select.
For a lowered G you could run a 19x9.5 super deep concave in a +25 offset running a 255/40 tire in front, and a 19x11 Super deep concave in a +40 w/ a 285/35 tire in back for a nice flush setup. As far as brake clearance, this is something that must be confirmed w/ vendor. If the brakes won't clear you may have to go to a deep concave instead of a super deep concave.
Old Oct 10, 2017 | 10:30 AM
  #2058
BrianHasAg37
Thanks blnewt
I plan on lowering about an inch or two to get less fender gap. I want go with in spec camber, so no negative. I am going to go with deep concave rather than super deep. Is there any difference on offset between the two? I don't want to do any trimming if the wheels are rubbing so will these for sure fit? Will there be little room or plenty?
19x9.5 +25mm 255/40 deep concave
19x11 +40mm 285/35 deep concave
Also, are the tires long enough to protect the wheels? Or will they stretch, leaving the wheels exposed. I would prefer having the tires protect the wheels. Thanks again
Old Oct 10, 2017 | 11:27 AM
  #2059
Thanks blnewt
Those will fit well, as far as tire protection, both front & rear tire widths are a bit stretched on those wheel widths. Not excessive, but the sidewalls will be angled in to the road rather than vertical. Some tires have a protection rib in the sidewall so depending on tire model you may or may not get much protection there. FWIW I just avoid curbs like grim death, even avoid those great parking spots on the end w/ a curb on one side, and take wider turns around curbed areas.
This would work well at in spec camber (camber around -1.2 give or take) and have more brake clearance since they wouldn't be super deep concave.
But I would check & see if super deep concave will clear as this is a great look and would set your G apart IMO vs. deep concave face.
Old Oct 12, 2017 | 12:03 AM
  #2060
BrianHasAg37
I got an email from a vendor saying that the Super Deep Concave will clear a BBK if the rear offset is set to +35mm. I would have liked to do this setup, but I don't like the look or the cons of having stretched tires. Would going with smaller width wheels fix this? How about 19x9 19x10 and 255/40 285/35 both deep concave with in spec camber and lowered an inch or 2? Would they still be stretched? What offset to get them flush? I have some other questions. Do wheels tuck in when you lower your car with coilovers without a camber kit? Does a camber kit fix this or lessen the tuck? Do you have to take into account how much you are going to lower your car when choosing the offset? Man, this is a lot more complicated than I thought it was going to be. Almost makes me want to keep my G stock. Almost.
Old Oct 12, 2017 | 11:05 AM
  #2061
If you went with that last combo you could run a wider tire set. FWIW I ran 245/285 (and even 295s for a while) on a 8.5/10" wheel width. Running 255/285 on the 9/10" set would give you a more standard mount. A +25 front offset and +35 offset in back will get you pretty flush without running into any rubbing issues.
Camber goes in an arc as you lower, so the lower you go the more tuck you will get. The camber arms will pull the lower section of the wheel in or out depending how they are adjusted. It's a bit hard to explain, but this arm is offset so the bottom will swing in or out more than the top of the tire.
Camber & toe are related so you need a rear toe kit as well as the rear camber arms to keep everything in spec when you drop. The SPC rear set includes the camber & toe parts but the toe bolts require that you elongate the toe slot w/ a dremel tool.
If you just drop without any camber/toe help your tires will wear very poorly.
And yes, it is a PITA to do all of this the right way, but better that you know this first
Old Oct 12, 2017 | 07:34 PM
  #2062
the93owner's Avatar
the93owner
Just got new wheels, and I'm looking at running a 285/30/20 in the rear on a 10.5 +45 wheel. Should fit based on what blnewt is running, yes? My camber is in spec at about -1.5
Old Oct 12, 2017 | 08:00 PM
  #2063
StarKiller's Avatar
StarKiller
Got a question, running a str 607 rim 19x8.5 +30 with 10mm spacers and 2454019 all the way around. looking for a taller and wider tire would a 2554019 work? or should i buy a different wheel?
Old Oct 12, 2017 | 08:10 PM
  #2064
the93owner's Avatar
the93owner
That should be fine.
Old Oct 13, 2017 | 01:03 PM
  #2065
BrianHasAg37
Looks like I am going to go with deep concave 19x9 25mm 255/40 front and 19x10 35mm 285/35 rear. Last question I promise How come you suggested the same 25mm offset for the 19x9.5 as the 19x9? Is one closer to flush than the other?
Thank you for clarifying about camber and lowering. I can visualize the camber moving like an arc when lowering. You have been a big help
Old Oct 13, 2017 | 01:56 PM
  #2066
The 19x9.5 with the same offset would be an additional 6mm further out. But giving you that extra wiggle room in front is a good plan, the front fender edges aren't flat rolled like the rear so having a bit more room inside the fender works well. I suggested the +25 on those 9.5s because they were a super deep concave that we were talking about, and with those you need a bit more offset for caliper clearance.
Old Oct 13, 2017 | 02:39 PM
  #2067
BrianHasAg37
Old Oct 13, 2017 | 09:45 PM
  #2068
EcstaticG37XS's Avatar
EcstaticG37XS
Opinions on this setup?
18x9.5 +38 275/40/18 all around on a AWD sedan lowered to 26.5" ground to fender.
Are the 275/40/18 too much for the front fenders or can this work?
Old Oct 13, 2017 | 10:22 PM
  #2069
I've got the same wheel specs, 275/40s will work in back, to fit in front you'd probably need to flat roll the fenders and possibly run a bit more camber. If you really want to try them I'd roll the fenders first (the rears are already rolled from the factory) and only run extra camber as a last resort.
I currently run 245/45s in front (285/40 in back) and when the time comes I'll bump the fronts up to at least a 255/45 and possibly a 265/40 if they have that size in the tire I want. Not quite sure I'd go up to a 275 there.
Old Oct 15, 2017 | 08:26 PM
  #2070
RJ's_G37's Avatar
RJ's_G37
So im running a 19x9.5 setup square with 255/40..im planning to run 265 35 but i feel like the rim is too close to my brakes..maybe im paranoid but it bugs me..question is can i run a 255/35 setup and maybe buy 3-5 mm spacers for the front?
Attached Thumbnails The OFFICIAL "I have a wheel offset / tire fitment question!" thread-20171015_125048.jpg
