The OFFICIAL "I have a wheel offset / tire fitment question!" thread
Old Jul 9, 2017 | 10:44 AM
  #1996
Unfortunately Photobucket has ditched all their 3rd party photos, member jfisher runs them, might send him a PM and see if he can send you some pics. The wheels you posted are not the Z Nismos, but they are the Z sport wheels (the Nismos are 9.5/10.5" sets).
https://www.myg37.com/forums/build-t...cinnati-5.html
IIRC he was running a 275 in back but
Originally Posted by pledes23
Hello,
I'm currently looking into trading my 20" Rohana RC9's for a set of 370 Nismo Forged Rays (See attached pictures).
Wheels specs are as follows:
Front are 19x9 +47 offset and rear 19x10 +30 offset 5x114.3
I have a 2012 G37S Sedan 6MT. I'm currently lowered on Tein Z Flex Coilovers, roughly at about 1.5 F, 1.0 R drop.
I'm looking to see which tire sizes would work with these wheels where I wouldn't have to pull fender/ quarters or rub. Would love to do a meaty rear setup.
Thanks in advance for the help!!
Old Jul 11, 2017 | 03:54 PM
  #1997
LiTo's Avatar
LiTo
i have vossen cv7 staggered 9/ 10.5 20" F +20 R +25
tires are continental dws extreme contact 245/30/20 and 275/30/20
lowered on powertrix coilovers.
am i good on the front with that tire?
Old Jul 11, 2017 | 04:09 PM
  #1998
mliakira's Avatar
mliakira
Will VMR 710 19x9.5 +22 square fit my X sedan or would a 19x8.5 +35? Kw coils
Old Jul 11, 2017 | 09:53 PM
  #1999
front will be fine (fitment wise), rear will be tight, there's a couple other coupes running that rear spec but the rear fender bracket will probably need to be shaved back.
The fronts would be better w/ a 35 series, those 30 series in front will be almost 3/4" shorter than the rears.
Old Jul 11, 2017 | 09:55 PM
  #2000
the93owner was running 19x9.5 +35 on his X (also VMR wheels) and they fit well. The +22 is too aggressive and will be poking about a 3/4" outside the fender. The 8.5 +35 will be a conservative fit, but you won't have any issues.
Old Jul 12, 2017 | 01:33 AM
  #2001
LiTo's Avatar
LiTo
i have a camber kit for the rear.i'm pretty damn low right now with the stock 19's,and i get no rubbing in rear.if i have to shave the back bracket i'm fine with that.
Old Jul 12, 2017 | 09:54 PM
  #2002
saywat?'s Avatar
saywat?
of course ur not rubbing u have the stock wheels. theyre not aggressive at all
Old Jul 20, 2017 | 12:07 PM
  #2003
Infiniti G37x's Avatar
Infiniti G37x
Help with stock G37x Sedan
Hey everyone! Long time lurker, first time poster here. Hope someone can help me out with my stock 2012 G37x Sedan that's currently sitting on OEM 17's.
I found an ad on craigslist for a set of 18" OEM wheels off of a 2004 G35 coupe. These arent from the ad, but the pic below is what they look like. I searched for hours last night but could not find anything on this particular wheel/car model combo.
Can someone help me out?
- The seller (a younger girl who doesn't seem to know much about cars) told me they were staggered widths 8"F and 8.5"R. Does that sound accurate? Two of the wheels have tires mounted on them (225/45/18) and the other two do not, which would make it tough for me to determine. Does anyone know if these are truly staggered and/or what true wheel sizes are for this style/year/model?
#2 - Is there any chance these would be a direct fit on my stock 2012 G37x Sedan? What would be needed? What tires should I run to keep from damaging my VSD?
If it's any help, i will never lower the car or install the higher end sport brakes.
Old Jul 30, 2017 | 10:14 PM
  #2004
douby77's Avatar
douby77
The OFFICIAL "I have a wheel offset / tire fitment question!" thread-photo4294967081.jpgThe OFFICIAL "I have a wheel offset / tire fitment question!" thread-photo617.jpgThe OFFICIAL "I have a wheel offset / tire fitment question!" thread-photo368.jpgThe OFFICIAL "I have a wheel offset / tire fitment question!" thread-photo299.jpg lol
Old Jul 31, 2017 | 12:10 AM
  #2005
Sorry for the delay, missed this post (if that happens again just feel free to bump the thread w/ a fresh reply if it's been more than a day or two).
Those wheels did come in staggered sets, but it's possible they could all be the same width, if you check the inside of the wheel there will be sizes stamped on the inside, like 18x8.0 or 18x8.5 and also should have the offset stamped as well, I think these were like a +35 give or take, might also be listed as ET35. These will work on your X but if they are a staggered set just be sure to run the same 245/45/18 size tire all around and you'll be fine, just keep the wider wheels in back. Those are a pretty nice looking OEM wheel IMO, should look nice on your G.
Old Aug 10, 2017 | 11:38 AM
  #2006
ZGerard's Avatar
ZGerard
18x9 +27
Hi, I recently acquired a 2012 6MT Sedan and am looking at replacing the "duckfeet" wheels on it soon. I've been doing some research and have read that some people have reported good success with 9.5" wheels in the 35-40 offset range with decent tires. I found a potential wheel I like that will poke out a little more and was hoping on some insight from someone that may have a similar setup:
18x9 +27 with a 265 series tire all around
I will probably drop it a bit with Tein Basis COs, but won't be slamming it or anything too crazy.
Thanks in advance.
Old Aug 10, 2017 | 10:20 PM
  #2007
Thanks in advance.
Welcome to the site Gerard, pretty close by in Cruces too!
I'm running 18x9.5 +38 on 245s front 285s back, your wheel edge will be about 5mm further out from mine. If you were to run those wheels I'd go no wider than a 255/45 or 255/40.
Here's a link to how my wheels were when I was running 245s all around, you'd be about 10mm closer to the fender edge running 255s on those 9 +27s. I'm dropped to zero gap on coilovers FWIW.
https://www.myg37.com/forums/18/2765...ml#post4044919
And how I'm now set up running same tires in front but 285s out back~
https://www.myg37.com/forums/18/2765...ml#post4135181
Old Aug 11, 2017 | 09:21 PM
  #2008
Guccicoochie's Avatar
Guccicoochie
Im getting new rims for my g, either the AG m580 or niche surge directional rims. for the ag sizes are 19x8.5 front and 19x9.5 rears. and for the niche 20x8.5 front and 20x10 rears. whats a good offset to get flush fitment and will i run into clearance issues with any of these setups?
Old Aug 11, 2017 | 10:16 PM
  #2009
Sedan, Coupe, RWD, AWD, and do you have the big Sport calipers?
Old Aug 11, 2017 | 10:20 PM
  #2010
Guccicoochie
g37 coupe rwd non sport
