The OFFICIAL "I have a wheel offset / tire fitment question!" thread
Old Sep 6, 2017 | 04:42 PM
  #2026
Originally Posted by mliakira
Will I have to do any fender modifications for a square 19x9.5 +25 WORK Kiwami on a G37x sedan? I'm obviously going to drop..
I have used the search function and even Google dork commands for the entire internet!
Thanks
Run 19x9.5 +35, it will be a much easier fit. If you're set on the +25 it will poke outside the fender about 12mm so you'll need camber and stretched tires to tuck.
I run 18x9.5 +38 and my outside wheel edge is just a bit outside the fender.
Old Sep 8, 2017 | 08:54 AM
  #2027
mliakira's Avatar
mliakira
I have seen a user here pull off a +25 at it doesn't look too bad. The only other option would be a +38 and I'm afraid if it comes out to be a fitment I hate after spending that much on wheels
Old Sep 8, 2017 | 09:18 AM
  #2028
Here's my 9.5 +38 looking down the side~
Old Sep 8, 2017 | 09:22 AM
  #2029
mliakira's Avatar
mliakira
I wonder how many times I've seen your car on these forums lol, you must be tired of it. I didn't realize your wheels were that dimension! They look nice man, appreciate the help
Old Sep 8, 2017 | 10:38 AM
  #2030
Z97's Avatar
Z97
Quick question, I did filter thru this thread and ready to order some forgestar f14s
So what I have is a 245/40 front tire on a 9.5 et 27
Rear as 275/35 on a 10 et 33
Just wanna make sure I'm not poking out like crazy if anyone could help
I am lowered however I don't mind adjusting
Old Sep 8, 2017 | 02:10 PM
  #2031
Coupe will be fine, Sedan will be poking about 10-12mm outside the fender edge.
Old Sep 9, 2017 | 08:05 PM
  #2032
55Drake66's Avatar
55Drake66
Hey everyone,
I have a question about a set of vossens i found locally and I'm not entirely sure if they'll fit or not. They're staggered 19x8.5/10 and are 32,38 offset. I have a Journey coupe, so I'm not worried about BBK fitment. I plan to drop on Eibach springs at some point too.
I'm just trying to get close to flush, but i don't want any poke. As long as these won't poke i will probably pick them up.
My clueless self is also not entirely sure what to do for tire sizes either. I think 245/40/19 and 275/40/19 should fit, but i wanted to get your opinion on what may fit better, or give a better ride.
Sorry if both of those are noob questions, but I am most certainly a noob when it comes to this. Thanks in advance for any help or information you can give me!
Old Sep 9, 2017 | 08:40 PM
  #2033
Originally Posted by 55Drake66
Hey everyone,
I'd run a 255/40 front 285/35 rear with those offsets, you can run the narrower sizes but be sure the back is a series smaller to keep diameter similar, so a 40 front 35 rear series.
Old Sep 9, 2017 | 08:49 PM
  #2034
55Drake66's Avatar
55Drake66
Thanks for the reply!
I appreciate the advice.
Do you think the wheels will fit alright and look decent?
Old Sep 10, 2017 | 03:01 AM
  #2035
Those are good offsets for a fairly flush fit, which is much easier to deal with then one that's too aggressive. Best part about that setup is it allows you to run more tire.
Old Sep 16, 2017 | 06:28 PM
  #2036
RJ's_G37's Avatar
RJ's_G37
Hey guys i got some wheels 19x9.5 +40 i was wondering what tire size should i go with? Lowered on tein coils..thanks
Old Sep 16, 2017 | 10:45 PM
  #2037
255/40/19 would be the safe fit, 265/40 or 265/35 if you want to get them tight to the fender but may rub in front under compression. If you really want to push it you could flat roll the front fender edge to gain a few mm, then the 265s would easily fit, and with a little camber the 275/35s could enter the discussion
Old Sep 17, 2017 | 01:16 AM
  #2038
RJ's_G37's Avatar
RJ's_G37
Ok thanks brad gonna see which one comes out cheapest and go from there
Old Sep 17, 2017 | 11:48 AM
  #2039
Zahy is running 19x9.5 +40 w/255/40s square on his G and can't argue how good it fits
https://www.myg37.com/forums/build-t...ml#post4149096
Old Sep 17, 2017 | 07:41 PM
  #2040
RJ's_G37's Avatar
RJ's_G37
Yeah looks damn good..i think that might be the way to go..just gonna polish up the wheels and hopefully be on by the end of the week
