The OFFICIAL "I have a wheel offset / tire fitment question!" thread
Old Apr 13, 2017 | 03:46 PM
  #1936
slartibartfast's Avatar
slartibartfast
I bent two TSW Blades on my Sentra SE-R when I hit the Tar Strip From Hell while fitted with Euro-T/A tires. Very soft sidewalls and low-profile couldn't protect the wheels. That said, any wheel can be bent and most people don't have issues with wheels beyond curb rash.
Old Apr 18, 2017 | 08:04 PM
  #1937
Chillpyl's Avatar
Chillpyl
Hi all, just started to mod the wife's car (13 g37x sedan), i recently bought 20x10 +38 wheels, I was wondering what size tires i can put on them to avoid rubbing since i plan to lower the car on coils down the road? Any advice would be appreciated
Old Apr 18, 2017 | 11:52 PM
  #1938
Looks like we gotcha back in the newbie thread.
Old Apr 19, 2017 | 08:00 PM
  #1939
Itsnotaskyline's Avatar
Itsnotaskyline
Hello everybody, i just lowered my 09 g37x sedan on megan racing lowering springs. I am now looking at getting aftermarket wheels and don't know what size to get without rubbing. I am looking at getting 18 inch and i am guessing around 8 to 9 inches wide but do not know about offset or tire size. i am looking to avoid getting wheel spacers unless i have to. I would like a nice clean fitment.
Any help is appreciated
Old Apr 19, 2017 | 10:10 PM
  #1940
Welcome to the site, here's my RWD sedan lowered on Megan Street LP coilovers. I'm running 18x9.5 +38 Wedssport SA10R wheels on 245/45/18 tires. No rubbing and wheels are flush to the fenders, you could run 255/45/18s for an even tighter fit at the fender.
And here's a thread on more 18" wheels
https://www.myg37.com/forums/18/2765...ic-thread.html
And a great thread about running square setups, many sedans here~
https://www.myg37.com/forums/brakes-...post-here.html
And keep in mind, a 20" wheel setup w/ a 9.5 +38 and running 245/35/20 tires will have virtually the same fit at the fender as mine, just to keep in mind when you're seeing other setups with larger diameter wheels.
Oh, and welcome to the site!
Old Apr 20, 2017 | 12:37 PM
  #1941
iyaman's Avatar
iyaman
This is 19 x11 +18. It's poking 1.25 inches past the fender. What size tire should I put on this? I prefer stretch tire vs camber if possible. Thanks.
Old Apr 20, 2017 | 03:55 PM
  #1942
Blackedout11's Avatar
Blackedout11
Current set up:
08 coupe lowered on tein s tech
73.1 center bore
245/35/19 +35 in the front
275/35/19 +40 in the rear
Would i be able to run 285/35/19 in the rear without issues while keeping the 245/35/19 in the front?
Old Apr 20, 2017 | 04:08 PM
  #1943
What are your wheel widths?
Old Apr 20, 2017 | 04:34 PM
  #1944
Blackedout11
oops sorry forgot to put those in
8.5 in the front and 9.5 in the rear
Old Apr 20, 2017 | 05:51 PM
  #1945
JamesG37x's Avatar
JamesG37x
Hey all,
Trying to figure out if a set of 255/45/18s will be okay on the front without rubbing. Friend gave me a free set of them so I'm trying to run a squared set up of these on Work Emotion D9Rs.
Old Apr 24, 2017 | 09:21 AM
  #1946
Blackedout11
Old Apr 24, 2017 | 12:40 PM
  #1947
Originally Posted by Blackedout11
Current set up:
73.1 center bore
245/35/19x8.5 +35 in the front
275/35/19x9.5 +40 in the rear
Yes, you can run the 285 (it's the absolute widest tire you should run on a 9.5" width) but the 35 series is a bit of a problem, it's going to be 1.1" taller than your 245/35 (which would be best if it was a 245/40).
If you're in need of all new tires I'd run a 245/40 front and 285/35 rear, no issues at all then, your tires will be almost the exact diameter as your original factory tires and you will only have a 0.5% diameter difference front to back which is excellent
If you only need rear tires a 285/30/19 would be the best choice in that case as your front to back difference is virtually zero, but you will be almost 4% off from OEM sizes which may cause some issues w/ your ABS & traction control. You already have that situation w/ your current tires, so if you haven't had any issues in that area then you should be ok going on.
Old Apr 24, 2017 | 12:43 PM
  #1948
Originally Posted by JamesG37x
Hey all,
X coupe or Sedan? And what wheel width and offsets are the D9Rs?
Old Apr 24, 2017 | 01:17 PM
  #1949
Blackedout11
no current issues with traction control or abs so I might go with 285's as I only need rears
would it be possible to run 275/30/19 ?
thanks so much for your help
Old Apr 24, 2017 | 01:39 PM
  #1950
Yes, that will be better than your current 275/35 and the 275 is a better mount on a 9.5 vs. a 285
