Official~Best offsets for running FAT tires!
Old Aug 26, 2013 | 04:41 PM
  #541
Robert_K's Avatar
Robert_K
Originally Posted by kdawg8526
but im plannin to go with 10 inch rim
The only difference will be a wider/deeper wheel on a 10.5. Otherwise the face spacing will be the same.
Attached Thumbnails Official~Best offsets for running FAT tires!-screen-shot-2013-08-26-at-3.39.21-pm.jpg
Old Aug 26, 2013 | 05:15 PM
  #542
kdawg8526's Avatar
kdawg8526
ohhhh makes sense thanks for clarifying that
Old Aug 26, 2013 | 05:18 PM
  #543
Robert_K's Avatar
Robert_K
No problem! When your ready to order please give Tony a call!
Old Sep 2, 2013 | 01:52 AM
  #544
Staples's Avatar
Staples
Does anyone know if you're able to run a 305/30/20 in the rear on our cars? I have the bumper bracket clipped down and relocated the rear bolt for extra clearance.
My current 285's look somewhat stretched.
Currently running a +39 rear offset
Old Sep 2, 2013 | 07:56 AM
  #545
Robert_K's Avatar
Robert_K
Staples; I just woke up so give me till later today to play with the calculator. However there are sedans running a 305.
Old Sep 2, 2013 | 03:59 PM
  #546
I'm on 295s w/ a 10" +45 and have about 3mm to the inner fender. I'm at zero gap and -1.1 camber. Be a tough fit w/ 305s on a +39 rim unless you plan on running heavy camber and even then probably need a fender pull.
If you had +48 offset I think you could run 305s without excess camber or pulling.
Old Sep 2, 2013 | 10:47 PM
  #547
Staples's Avatar
Staples
Would you happen to have any pics of your setup in the rear?
Thanks for the input.
Old Sep 3, 2013 | 12:23 AM
  #548
Would you happen to have any pics of your setup in the rear?Thanks for the input.
No problem,
Here you go~
Old Sep 3, 2013 | 04:45 AM
  #549
WARAT's Avatar
WARAT
Nice fitment Blnewt
Old Sep 4, 2013 | 10:14 PM
  #550
Staples's Avatar
Staples
Gorgeous... absolutely clean. I do know the Coupes allow you to run a little more aggressive setup than the Sedans. Maybe a 305 is possible on a Coupe? I'll have to measure the gap difference. I'm only running about -1.8 negative camber which is right inside spec.
Old Sep 5, 2013 | 12:57 AM
  #551
With the right offset 305s are definitely possible on a coupe or sedan, although the coupe with it's wider fender span allows for a bit more wiggle room. I know there's a couple sedan guys on 305s and even more coupes.
Old Sep 5, 2013 | 08:41 AM
  #552
Sython's Avatar
Sython
Guys I'm reposting this from the fitment thread, as the setups here are what I'm going for:
I was going to get Forgestars, but after doing some Googling (very poor customer service / bad quality control).
For other wheels, If I ran something with slighty more aggressive offsets, such as +3X F / +3X R, would I have any fitment / rubbing issues? The only lowering I MAY do is with Eibachs. However, I will be on stock for awhile.
Wheel/Tire sizes will be 19X8.5 F / 19X9.5 or 10" rear. Tire sizes would be 245/45/19 & 275/40/19 in the back.
Old Sep 5, 2013 | 08:49 AM
  #553
Coupe or sedan? For a sedan on stock or mild drop I'd go +35 to +40 front and +35 to +40 (on the 9.5") to +40 to +45 (on the 10") in rear. Coupe is best posted by one of the coupe guys
Old Sep 5, 2013 | 08:59 AM
  #554
Sython's Avatar
Sython
Coupe. Sorry I should have clarified.
I think this is the wheel setup I'm going for:
http://www.modbargains.com/avant-gar...niti-lexus.htm
19X8.5 F +35
19X9.5 R +40
Tire sizes are 245/45/19 F & 275/40/19 R.
Since the offsets are so close to stock I think I'm good even with the extra width in the rear. Thoughts? Thanks again everyone.
Old Sep 5, 2013 | 10:08 PM
  #555
Robert_K's Avatar
Robert_K
Just wanted to share another picture....
