Official~Best offsets for running FAT tires!
Old Aug 24, 2013 | 12:29 AM
  #526
Originally Posted by Bota36
Hey Guys, this isn't 285's or 295's but I'm working my way there...baby steps.
20x9 +35 255/35
20x10 +42 275/30
I remember a while back you were asking about some Stance wheels, but not the SC-6 that you have, I think they were the ST-1s. You made the right choice Bota, those look awesome (as does the rest of your ride).
And 275s are the cutoff point for the FAT club so you just squeezed in
Gotta shoot your pics over to Rochester, he's been wanting to see these wheels, this might seal the deal
Old Aug 24, 2013 | 02:55 AM
  #527
Emillion45's Avatar
Emillion45
Agreed^^ Even w/ some fender gap those 285s up front would probably mangle that front fender. I'd just go staggered wheels or stretch the front tires a bit if you're set on all 4 wheels the same.
How would that work with the AWD system?
I hate the "miss match" concave look of staggered wheels. Unless I played with the offset to make the front concave match the rear?
Maybe I'm just over-thinking it.
Old Aug 24, 2013 | 04:05 AM
  #528
Bota36's Avatar
Bota36
Yeah, I must admit the SC-6 are clean and look real good...even better in person. I feel i made the right choice as well. If Rochester is reads this thread, I endorse these wheels. I'll post some clean shots of the set up soon. Thanks Brad. You, Dagon, Robert, Dustin, Rochester, Zoster and so many more had a big influence with my decision and set up, It's greatly appreciated.
The networking on this forum is top notch and I'm glad to be a part of it. I hope some of my posts are helpful as well...to the newbies of course.
Next stop...my next Mod.
Old Aug 24, 2013 | 09:19 AM
  #529
I understand your wanting the dual-concave setup, it's a hot look, just takes a bit more compromise. You could go 9.5" +45 all around w/ 255s, then you could add a small spacer in the back if you weren't quite flush. The main thing was the big wide tires in front on a 10.5" rim. You could also have different offsets front & rear. That was one of the reasons I went w/ my Nutek Bavaria concaves, even though they're staggered the concavity of the spokes are the same
Old Aug 25, 2013 | 02:59 PM
  #530
Robert_K's Avatar
Robert_K
'12 G37S Blue Slate
Swift Springs
Forgeline MD3P; Polished lip, Gunmetal center, Gloss Black inner, Exposed ARP hardware
19x9.5 +40 w/ 5mm spacer (+35 netted offset) w/ 245/40
19x10.5 +45 w/ 285/35
Old Aug 25, 2013 | 09:16 PM
  #531
Bota36's Avatar
Bota36
Damn! Ditto Robert on my previous compliment on the other thread.
Old Aug 25, 2013 | 09:22 PM
  #532
Robert_K's Avatar
Robert_K
Thanks!
Old Aug 26, 2013 | 01:51 PM
  #533
Emillion45's Avatar
Emillion45
If I could get away with 10+40 offsetx20 in the front and 11+25offsetx20 in rear it would be a god send if I could make a 285/35 fit.
This calculator is more useful,
http://www.1010tires.com/Tools/Tire-...5R20/285-35R20
Old Aug 26, 2013 | 01:55 PM
  #534
Robert_K's Avatar
Robert_K
What?!?!
Are you trying to say; 20x10 +40 and 20x11 +25?
Old Aug 26, 2013 | 02:31 PM
  #535
I prefer the calculator on this site, simple but gives all the info you need
You can't run 285/35/20s but 285/30/20s will be fine. Your rear offset is way off, you'll be another 20mm further out than you would be w/ a +45.
But if you decide to go staggered it'll be much easier to make things work. My setup is a 245/35/20 on 8.5x20 +40 but could go out a bit so a 9.5" +45 would work. My rear is 295/30/20 on a 10" +45 and it's flush, but a 285/30/20 on a 10.5" +45 would squeeze in.
Run the calculator numbers w/ the offsets compared to your current setup and you'll be able to compare to your G.
Old Aug 26, 2013 | 03:17 PM
  #536
kdawg8526's Avatar
kdawg8526
planning to get some forgestars f14's what you guys suggest for offsets for 19x9.5 front 19x10 rear if i wanna run 255 front and 295 rear i want it to be as flush as possible
Old Aug 26, 2013 | 03:30 PM
  #537
Robert_K's Avatar
Robert_K
+35/+45.
EDIT: BTW, Hit up DV8Motoring.com for those ForgeStars. Tell Tony, Robert sent ya!
Old Aug 26, 2013 | 03:51 PM
  #538
kdawg8526's Avatar
kdawg8526
sounds good bro thanks for the hookup
u think i can get away with a +40 rear?
Old Aug 26, 2013 | 03:55 PM
  #539
Robert_K's Avatar
Robert_K
sounds good bro will do
Did you see my pic above? I'm running a 285/35-19x10.5 +45 and its flush with the rear fender. A +40 will really poke it out.
Old Aug 26, 2013 | 04:36 PM
  #540
kdawg8526's Avatar
kdawg8526
but im plannin to go with 10 inch rim
