Old Feb 5, 2026 | 02:02 PM
  #10741
ILM-NC G37S's Avatar
ILM-NC G37S
Curious, Mike. Does that show oil pressure or just temperature? Apparently AUTOOL doesn't have anything remotely similar anymore. After exhaustive searching the only units that come close- from China- measure in mP and not PSI. Go figure.
Never would have thought that finding a (non-round/ digital) oil pressure gauge would prove so challenging.
Old Feb 5, 2026 | 02:10 PM
  #10742
rotarymike's Avatar
rotarymike
Moderator in Moderation
the center-dash gauge is OBD2 - so any OBD sensor. For our cars obviously not oil pressure. What you're seeing in the pics is WATER temp.
My oil pressure gauge is a discrete prosport 2 1/16 round deal that I'm putting on the a-pillar. Don't want to have to look down to see pressure.
Since I'm now using carplay in the G, I can't connect to an OBD dongle to show that data any more (Carplay and iOS OBD dongles both use Wifi so are mutually exclusive, apparently)
It's all compromises, all the way down LOL.
Old Feb 5, 2026 | 02:36 PM
  #10743
socketz67's Avatar
socketz67
Community Builder
If interested, Eugene has a sensor that plugs into the existing pressure switch and can then be mapped into Ecutek ROM and be used to manage pressure at a more granular level. You can then map this into an Ecutek dashboard running on your phone.
Old Feb 16, 2026 | 08:39 PM
  #10744
JZ39's Avatar
JZ39
20 Year Member
Rear wheels getting stripped for powder coating
File Type: mov
Old Feb 17, 2026 | 08:42 PM
  #10745
JZ39's Avatar
JZ39
20 Year Member
And once again we powder coat….Ready for this project to be done…
Old Feb 18, 2026 | 01:31 PM
  #10746
MotorvateDIY's Avatar
MotorvateDIY
Originally Posted by hexotic
99% sure Frank shelved that project and put the knowledge towards this new endeavor.
Heck no!
With the new rules, I have no idea how to sell into the US.
I'll figure it out, but until then, I've decided to use the last year to develop a wireless oil pressure gauge and a "mini GTR gauges" for cars without navigation.
Watching your oil pressure takes away all the worry of low oil pressure due to failing oil gallery gaskets.
In fact, when I unplug the GTR gauges to data log the CAN bus, I feel anxious, as I don't know the oil pressure that moment. Silly, but true!
The oil pressure gauge above isn't an Apple watch. It is this nice display: https://www.waveshare.com/wiki/ESP32...uch-AMOLED-1.8
I will also be looking into getting them manufactured in the US and selling the firmware via a download.
BUT I need to make sure everything is done by the book with regards to tax & duties.
I'm also in the process of redesigning the GTR gauges hardware to be much smaller.
The v1 board is about 1" x 7" and the new one will be about 1" x 1".
Also, the GTR gauges have been running on my G37 for over 3 years and I've caught a few minor items and fixed them.
The firmware has proven to be reliable and not cause any other issues. After all, we are kind of doing things that the G/Z wasn't designed for.
Lastly, I need to apologize for dropping off forums and social media and not replying to messages / posts.
In the beginning of 2025, I started a new full time job, which left me with evening and weekends for devlopment work.
Anyways,
That's all for now.
Frank
Old Feb 18, 2026 | 01:35 PM
  #10747
Very happy to hear you're still engaged with your projects, Frank.
Having seen them in person, your GTR gauges in the main screen are amazing.
I'd be very interested in seeing what comes of your oil pressure project.
Old Feb 18, 2026 | 04:47 PM
  #10748
2GoRNot2G's Avatar
2GoRNot2G
Those turned out great! Should look amazing on your car.
Old Feb 18, 2026 | 06:36 PM
  #10749
MotorvateDIY
According to a Mazda engineer I talked to in the early aughts, all the Japanese companies went away from those and from linear temperature gauges since any time the needle moved the customer would bring the car in to be 'fixed'.
Same on the G37 and 370... The temperature gauges doesn't move between 70-115C / 158-239F
The GTR gauges show the actual temp and it does go up and down depending on outside temp and vehicle speed.
Old Feb 18, 2026 | 09:34 PM
  #10750
JZ39's Avatar
JZ39
20 Year Member
Thanks. Hoping to get 15mm spacers put on next week and then I will take a proper picture of the car with the new wheels.
I received my final piece of trim molding today to block out the trim and the darn thing was bent. Second time I’ve received this part bent. Ugh. Only time I’ve ever had a problem with Amayama and this came from their UAE site that does not pack things nearly as well as their Japan site. Hoping they make it right. Really want to wrap up this project.
Old Feb 19, 2026 | 10:58 AM
  #10751
socketz67's Avatar
socketz67
Community Builder
Media blasted, black base coat, then color and clear as the final coat? Looks great. What is the name of the color you are using? Is it metallic (appears to be the case in the last pic)?
Old Feb 19, 2026 | 11:00 AM
  #10752
socketz67's Avatar
socketz67
Community Builder
I'm comparing the oil temp from the digital gauge I installed with the OBD PID reading I am monitoring on my Ecutek dashboard and the two seem to track pretty closely to one another.
Old Feb 19, 2026 | 03:16 PM
  #10753
JZ39's Avatar
JZ39
20 Year Member
It's 1G3 Magnetic Gray Metallic. It's a Toyota color and just a generally good gray. I will say, due to the black base coat, it comes out a bit darker looking than if you were to use paint. I have my FX50 wheels painted the same color and they are a good shade lighter.
They look great on the white car. I like them because they are not black. The white car needs some color other than just white and black IMO. My emblems are painted the same color.
I pasted a satisfying movie a few posts up of them getting lowered into the chemical dunk tank for 2 hours - no blasting.
Old Feb 21, 2026 | 04:08 PM
  #10754
JZ39's Avatar
JZ39
20 Year Member
Mirror caps and trim will be black with OEM white spoiler going on soon. Could really use some nice, red calipers for some color.
Old Feb 25, 2026 | 10:58 AM
  #10755
2010sedanS's Avatar
2010sedanS
Swapped my front midbass speakers from JL Audio to Hertz. And I hit 150K this weekend. I need to wipe off my gauge cluster asap!
