Old Jun 15, 2022 | 05:30 PM
  #9076
ILM-NC G37S's Avatar
ILM-NC G37S
Originally Posted by iCrap
...you need to have a lot of patience.
The one skill I do not have, lol... I looked into having redline do my Q60 wheel but $190 just for the install!!!
Makes me really wish Ryne was still active on the forum.
Old Jun 15, 2022 | 06:28 PM
  #9077
iCrap's Avatar
iCrap
Yeah that price doesn't surprise me. It's a lot of work. I'm sure a pro can do it much faster though.
Old Jun 16, 2022 | 09:24 AM
  #9078
BULL's Avatar
BULL
Moderador
Originally Posted by hexotic
​​​​​​I've done 4, 2 with fake chinese "leather" and 2 with redlinegoods real leather. All went over the top of the original leather. The redlinegoods is a perfect fit. Use a bit of contact cement to hold everything into place. After a out 10-15 stitches, tightly wrap a piece of masking tape and keep moving around the wheel. The thumb areas should even and stretch themselves out once the tension is even across the board. I highly recommend redlinegoods. You can also get padding and slightly larger leather I'd you want to bulk it up, they also sell the kit that adds the thumb groves. You can also have them do the wheel for you, even make it flat bottom.
P.S. heating it with a steamer at the end helps the leather relax a bit and sit into place.
Thank you for the picture.
My reasoning behind removing the old leather was to avoid this areas here. After taking off the old leather you're left with a rubber wheel with cuts in these sections to accommodate the stich which is why on an OEM wheel you can barely notice these. I also was not a fan of the perforation once it's all put together.
Because I took the old leather we did not have such a crazy issues making it cooperate however the thumb areas looked like we had put it on backwards so after trying it out a couple of times we decided to leave it alone and try another.
I actually dislike the look of a "thicky" wheel and though these companies try their best at this, unless you cut grooves in these spots they will always appear as humps.
We will see in the future if this theory will work on a bare wheel.
Thanks again guys!
Old Jun 16, 2022 | 09:52 AM
  #9079
I wish JP were still around painting calipers. The man had the mad skills to back up the hubris. Guy was a freaking artist.
Old Jun 17, 2022 | 03:59 PM
  #9080
iCrap's Avatar
iCrap
I ended up 3D printing a bracket for my floppy Z1 intakes. I don't understand how they expect it to just flop around in there, expected better for $500. Anyways. They don't move now, just a simple L bracket and i tapped an m6 hole and thread into the bumper bar.
Then I reassembled everything again and gave it a clean. not bad looking for 16 years old engine bay I guess lol.
Old Jun 17, 2022 | 04:01 PM
  #9081
AnotherVQ's Avatar
AnotherVQ
You're always making nice custom things.
It's also interesting.. I can see the steel bar that this shop was talking about which they said they removed when installing my intakes... Of course without even asking me or letting me know what's going on they just remove that steel bar.
Old Jun 17, 2022 | 04:17 PM
  #9082
iCrap's Avatar
iCrap
Thanks I like coming up with custom solutions to stuff, but I feel like in this case Z1 should have thought of something lol.
Also, kinda weird that they removed the bar. That's the actual low speed crash bumper, you def want to keep that installed if you can. I would be surprised if the Gen 3 require it to be removed...
Old Jun 17, 2022 | 04:18 PM
  #9083
AnotherVQ's Avatar
AnotherVQ
Well I am using different filters than what came with it. I have some injen filters.
Old Jun 18, 2022 | 10:35 PM
  #9084
iCrap's Avatar
iCrap
Rear diff bushings day 1. What an absolutely miserable job. Doesn't help that my diff looks like it came out of the titanic. Ended up getting the bushings out by cutting out the centers of the bushing with an air hammer, then sawzalling slits on the outer sleeve. Worked, but took a while. the subframe bushing was a huge PITA.
I was kinda hoping i could get the big bushing out mostly intact so i could see the condition of the epoxy fix, but that didn't happen. When I was drilling the bushing though chunks of broken down epoxy were pouring out of it, so clearly it didn't hold up over the 4-5 years since I did it.
Did the oil while it was out, but with only 20k since the last change it was probably pointless.
Diff is back in the car but I was too tired to finish bolting the driveshaft / halfshaft / swaybars etc.. Onto day 2 tomorrow....
Old Jun 19, 2022 | 08:38 AM
  #9085
rotarymike's Avatar
rotarymike
Moderator in Moderation
Agreed this is a PITA job. I think getting the demon bolts was easier.
Old Jun 19, 2022 | 10:29 AM
  #9086
iCrap's Avatar
iCrap
Oh I 100% agree, that was easy by comparison. This sucks 😭
Old Jun 20, 2022 | 10:50 PM
  #9087
iCrap's Avatar
iCrap
Finished my bushing install today, went for a drive. It's a nice difference, not to stiff or anything crazy. I don't really feel much difference in NVH. Shifting seems a little firmer, but most importantly the big CLUNK and hop from 1-2 shift is gone, so overall I'd say it was worth the pain and suffering to install them lol.
Old Jun 21, 2022 | 11:50 AM
  #9088
BULL's Avatar
BULL
Moderador
Great Job at this Icrap. I suspect in the future they will include it as someone might pick this up and start making 100% fitting intakes since it seems that it's what folks are after.
Old Jun 21, 2022 | 12:01 PM
  #9089
rotarymike's Avatar
rotarymike
So... car is parked for probably a few months, gas down to almost-push-it-home, and I'm getting ready to do some suspension mods/remods.
I'd like to tackle the gas tank vent issue (where when below 1/4 tank, you can only put in 5 gallons at a time and that very very slowly). How bad is it to drop the tank?
Old Jun 22, 2022 | 08:30 AM
  #9090
BULL's Avatar
BULL
Moderador
Diff, drive shaft, exhaust, shields have to come out. Decent amount of a pain in the azz to take the whole day + some.
