Old Sep 1, 2021 | 12:34 PM
  #8761
AnotherVQ's Avatar
AnotherVQ
Z1 Undershroud finally installed
Old Sep 1, 2021 | 01:54 PM
  #8762
EcstaticG37XS's Avatar
EcstaticG37XS
Slowly starting to mod after 6 years of ownership.
Starting with chrome window trim delete. Pre cut out vinyl purchased from blue bat overlay.
Old Sep 2, 2021 | 12:53 PM
  #8763
2GoRNot2G's Avatar
2GoRNot2G
Looks good. Did you get it powder-coated green or it that just the lighting making it look that way?
Old Sep 2, 2021 | 02:57 PM
  #8764
RobC7's Avatar
RobC7
Looks sharp, I like it!
Old Sep 11, 2021 | 07:34 AM
  #8765
hexotic's Avatar
hexotic
DIY Cheapskate/Mod
Awesome. I recommend adding a cherry on top.
https://www.ebay.ca/itm/152094536238
https://www.ebay.ca/itm/154246276530
Old Sep 11, 2021 | 07:41 AM
  #8766
AnotherVQ's Avatar
AnotherVQ
Lightning/reflections
Originally Posted by hexotic
What's the purpose?
Old Sep 11, 2021 | 07:57 AM
  #8767
hexotic's Avatar
hexotic
DIY Cheapskate/Mod
What's the purpose?
Won't rust, strong steel, looks good if you take care of down there
Old Sep 11, 2021 | 09:03 AM
  #8768
No argument from me about SS nuts & bolts. But my TBW tray is black, so I just bought a bag of black replacement bolts. I think it was $10 or something.
It's been a year, and my OCI is coming up, so it will be interesting to eyeball the undertray in a few weeks and see how its held up.
This will also be my first OC with the quick-release drain plug.
Old Sep 11, 2021 | 01:25 PM
  #8769
AnotherVQ's Avatar
AnotherVQ
I hope z1 didn't fail and include inferior hardware. I shouldn't need to upgrade that stuff. I'll see how it lasts I guess.
Old Sep 11, 2021 | 02:04 PM
  #8770
hexotic's Avatar
hexotic
DIY Cheapskate/Mod
True, I just like upgrading little stuff noone will ever see lol.
Old Sep 12, 2021 | 09:35 PM
  #8771
rotarymike's Avatar
rotarymike
Moderator in Moderation
Chased down my rough road/transition surface clunk.
TL;DR: Front swaybar links came loose.
These are Whiteline front sway bar links / shock mount bolts, with Hotchkis sway bars. The Hotchkis bar is thick enough that there's no extra thread through the nut... On close exam, it looks like the threads are fully engaged, but just. Both sides loosened up from 45 ft/lbs, so I put blue loctite on them to see if they hold. I don't see that the stud length on the OEM link is any different, and the OEM nut is the same height as the replacement - I thought I had several threads showing on the stock links though. This might not be tenable - not sure if Whiteline makes different links (I got the proper ones for the car) with longer lower half studs, or if I'll have to pony up for the SPLs.
Old Sep 12, 2021 | 10:30 PM
  #8772
iCrap's Avatar
iCrap
Mine has come loose multiple times, super annoying. Last time I cranked it down and loc-tited it. Been fine for a few years now.
Old Sep 13, 2021 | 09:24 AM
  #8773
jlh81's Avatar
jlh81
Picked up my all stock, one owner 2012 G37x last week and starting on a few small things before I dive into some bigger mods. Love this car so far!
Painted the grill black.
Polished the lights.
Old Sep 13, 2021 | 08:20 PM
  #8774
ngolbuff's Avatar
ngolbuff
I had a passenger side headlight go out on my '13x sedan. I have a feeling they were OEM anyway and its probably time. I had a lot of good info from other spots in this forum about lights/temps and settled on a 6k HID. I replaced both so they match and I cant tell much difference besides maybe a "little" bit brighter white over OEM. While doing light stuff, I replaced parking lights with LED as well as replaced the turn signals with LED. The parking lights are nothing to write home about, but I tested RockAuto LED (Phillips brand) turn signals vs. a brand from Amazon and Phillips (RockAuto) didn't stand a chance. SiriusLED from Amazon lit up my garage brighter than the ceiling LED lights. I am currently looking to see if they have better parking LED lights for me as well as backup lights.
Best part???? NO HYPERFLASH.
Amazon Amazon
Old Sep 14, 2021 | 06:54 PM
  #8775
2GoRNot2G's Avatar
2GoRNot2G
I had this same problem several times with the SPL end links on my G, especially in the front. I even tried using blue loctite on them and they still eventually worked their way loose. I ended up replacing the nuts with Grade 8 Stover style locking nuts and never had them come loose again.
Something like these, although I was able to source them locally so I didn't use this company: https://www.fastenright.com/general-...-din-980v/sl18
