Old Oct 15, 2019 | 04:33 PM
  #7246
Mak34's Avatar
Mak34
Looks great! I'm a big fan of the OEM DRL's as well!
Nice!
I'm putting on the OEM sport lip this weekend so it should finish up my front end.
Old Oct 15, 2019 | 06:24 PM
  #7247
2GoRNot2G's Avatar
2GoRNot2G
Originally Posted by Mak34
Nice!
Very cool. The Sport lip will definitely give the front end a more aggressive look. Just make sure you properly prep the surface before installing the lip. I highly suggest cleaning the surface with something like Wurth Clean Solve and also use 3M Adhesion Promoter to the mating surface for the 3M tape before securing the lip. This will give you the best bond possible. 2 or 3 packs of the Adhesion Promoter should be enough for the front lip, but here are Amazon links for both the 3 pack and the 5 pack. Good luck with the install!
Amazon Amazon
Amazon Amazon
Old Oct 15, 2019 | 06:30 PM
  #7248
Mak34's Avatar
Mak34
https://www.amazon.com/dp/B07MVK1PG6...iglink20432-20
https://www.amazon.com/dp/B01G2BHLG6...iglink20432-20
Awesome thanks!
Old Oct 19, 2019 | 02:41 AM
  #7249
SupraOfDoom's Avatar
SupraOfDoom
Pretty bad picture but swapped my old depot tail lights with new ones lol. The old ones had chrome inner housings around the lights, the new ones are all black. Look almost identical from the back, but from the side its a big upgrade for me.
Old Oct 19, 2019 | 08:10 AM
  #7250
RMB5190's Avatar
RMB5190
I think those compliment your car much more than the previous tail lights. In my opinion, the previous pair was too '90's' while these have a more modern look.
Old Oct 19, 2019 | 12:40 PM
  #7251
PNW_IPL's Avatar
PNW_IPL
Ooooh DAS nice!!
Old Oct 19, 2019 | 05:35 PM
  #7252
Mak34's Avatar
Mak34
Finally got the lip installed
Old Oct 19, 2019 | 06:30 PM
  #7253
QuinnDEskimo's Avatar
QuinnDEskimo
Not quite sure if this is the place to post but got rear ended today. The area in the spare wheel area looks like a crumpled soda can on one side. Is this repairable or will it get totaled? It was a pretty hard smack. 2012 sedan with 85K miles.
While trunk
Crumpled up pretty good.
Old Oct 19, 2019 | 06:54 PM
  #7254
iCrap's Avatar
iCrap
Yeah it's probably totaled due to that crumple damage. that sucks. I'd be very surprised if they fix it.
Old Oct 19, 2019 | 11:30 PM
  #7255
martik00173's Avatar
martik00173
Talking
Had a awesome ride in the NC mountains!
318 curves in 11miles
Old Oct 20, 2019 | 08:21 AM
  #7256
QuinnDEskimo
I guess the good news is I’ve already seen a lot of 50K mile g sedans for sale in the 11-12K range on Craigslist/autotrader. Stock unmolested ones mostly one owner too.
Old Oct 23, 2019 | 08:17 AM
  #7257
BeeW's Avatar
BeeW
Cleaned up the throttle bodies! Idk if this is Dirty for 65k mi, but it really launches off the line now!
Old Oct 23, 2019 | 08:40 AM
  #7258
hexotic's Avatar
hexotic
DIY Cheapskate/Mod
Make sure you do the idle relearn, accelerator pedal released position learning, and the throttle valve closed position learning. Check out Motivate DIY on YouTube if unsure how. I think the video is called after throttle body cleaning or something along those lines.
Old Oct 23, 2019 | 09:53 AM
  #7259
BeeW's Avatar
BeeW
All good! Wierdly, idle was completely unchanged without the relearn. But I ran the whole process anyway.
His much less publicized video shows an idle relearn that uses the NDSIII android app and Bluetooth odb2 kicks the pedal dance's butt.
Old Oct 23, 2019 | 09:57 AM
  #7260
hexotic's Avatar
hexotic
DIY Cheapskate/Mod
https://youtu.be/OiB9txECWB0
Awesome, just making sure lol. A lot of people for they about this step and then have issues. Yeah I use NDSIII as well. Also use it for my tire pressure monitoring with PSI for each wheel. Amazing how much data our cars produce that is just hidden.
