Old Jan 30, 2020 | 09:47 AM
  #7531
llebcire's Avatar
llebcire
Today I hit 90k miles.
I'm actively looking to trade back to an Accord EXL and am seeing trade value around $6,500. Fuel economy and lower miles are the primary reasons plus with the performance of the G I'm lucky I haven't lost my license (also part of fuel economy).
-Eric
Old Jan 30, 2020 | 11:35 AM
  #7532
RobC7's Avatar
RobC7
Took it to the local Infiniti dealership for an oil change and had them pull the maintenance records. What a ghost town, I don't blame consumers. There is absolutely no reason to walk into an Infiniti showroom.
Old Jan 30, 2020 | 11:35 PM
  #7533
ryanwhite74115's Avatar
ryanwhite74115
While in the Philippines my brother has my car and is building an exhaust: z1 cats, borla and magnaflow equipment. Final weld will be done off the car so don't freak at the tack welds.
Really interested to hear it with custom hemholtz resonators.
Attached Thumbnails What did you do to your Sedan today?-photo580.jpg   What did you do to your Sedan today?-photo175.jpg   What did you do to your Sedan today?-photo378.jpg   What did you do to your Sedan today?-photo918.jpg
Old Jan 31, 2020 | 01:02 AM
  #7534
fillup's Avatar
fillup
Originally Posted by OldG2NewG
Picked up a sport bumper
How much?
Old Jan 31, 2020 | 08:00 AM
  #7535
OldG2NewG's Avatar
OldG2NewG
100 bucks
Old Feb 2, 2020 | 01:53 PM
  #7536
RobC7's Avatar
RobC7
Installed LED parking lights, fog lights, and switchback turn signals. It was hard capturing a picture but they look very clear/white and match very well.
Old Feb 5, 2020 | 10:26 AM
  #7537
BULL's Avatar
BULL
Moderador
Originally Posted by hexotic
Was sick and tired of having to boost the car every time temp dropped below -10C. Splurged a bit, got an Optima Yellow top.
It's possible your problems might be contributed to additional grounds not passing by the current sensor. I read multiple people who did ground kits on these cars having these issues.
I ended up making my own grounds from engine to bay but left the OEM one for the battery as it needs to go through the current sensor.
Old Feb 5, 2020 | 10:47 AM
  #7538
hexotic's Avatar
hexotic
DIY Cheapskate/Mod
Yep, that's exactly what's causing it. I'm still trying to figure out a way to hook the grounding cable up right before the sensor. Taking some of the engine bay apart this summer, planning to add an alternator ground and fix the issue.
Old Feb 5, 2020 | 11:12 AM
  #7539
BULL's Avatar
BULL
Moderador
I think you might be overthinking your grounds.
You should not need an additional battery to bay ground. If worried, you could always buy a brand new one to give you peace of mind.
As far as engine goes I used the two 14mm long bolts in the timing covers to the frame as grounds and the two 10mm holes in the lower oil pan to the frame as well as grounds.
I get 13.8 -14.3 volts depending on operations. The reason I did not ad an additional ground to the ALT is in the past I've had some cars burn these grounds for some reason.
Sanding/cleaning of alternator brackets/mounts will provide grounding cables will never be able to.
Old Feb 5, 2020 | 11:19 AM
  #7540
BULL's Avatar
BULL
Moderador
I decided to tackle the PCV system to a more incognito one. I hate the clutter these systems can produce as far as looks go and PCV location on the VQs make it difficult to make it look decent.
I re routed the system to use the EVAP vacuum source, since the EVAP system has a solenoid right by that area this acts as a check valve so oil does not go into the EVAP.
Pretty satisfied with the looks of it especially when it just was done under $30
Old Feb 5, 2020 | 11:44 AM
  #7541
hexotic's Avatar
hexotic
DIY Cheapskate/Mod
Cool, thanks for the info. As you can see, I've only started researching the topic.
Old Feb 6, 2020 | 11:59 AM
  #7542
fillup's Avatar
fillup
Finally had time to install the Hotchkis sway bars. Was going to replace the endlinks with Moog, but one of the boots was torn.
Old Feb 12, 2020 | 11:13 AM
  #7543
steveng37's Avatar
steveng37
I love my G again!
It wasn't today, but on Saturday, I swapped out my top speed muffler delete and replaced it with the top speed y back, which I picked up for $200. This was also paired with a motordyne resonated y pipe, which has been on my car. Needless to say, I love my G again! It is so nice driving without insane amounts of drone. Honestly I'm so used to the booming drone for the past 6 months, that sometimes I am anticipating it and imagining it. Couldn't be happier now. Oh, and here's a few pictures of the old setup vs. new. The muffler delete made the G look terrible.
Old Feb 12, 2020 | 11:32 AM
  #7544
projectpanda13's Avatar
projectpanda13
I've also had this setup on my sedan. The Top Speed y back is subtle with stock cats and y pipe. With the Motordyne Y pipe, it deepens the sound and raises the volume to just the right amount. I also added Circuit Werks test pipes and it was still very good. I am glad you are enjoying the car more with this setup.
Old Feb 13, 2020 | 03:58 AM
  #7545
Hunter Dietzman's Avatar
Hunter Dietzman
https://www.youtube.com/watch?v=jqyvG9bxprc
wow, that sounds awesome, perfect sound. I’ve been looking for the proper setup for my G for awhile now, and I’m really liking that.
