Old Nov 29, 2018 | 02:06 PM
  #6031
RMB5190's Avatar
RMB5190
Thanks! I'd say they didn't turn out too bad for my first install . Bit of a learning curve though lol. I bought them brand new from a member on the forum for $1000 after shipping.
That's awesome! I just ordered mine for $150 and they were the cheapest I could find. Most I say were in the $170-180 range.
Old Dec 1, 2018 | 07:33 PM
  #6032
PNW_IPL's Avatar
PNW_IPL
Installed my z1 test pipes! Awesome product beside the gaskets. I took a chance and installed their header to test pipe gasket knowing theyre prone to leak and sure enough they leak very very badly.
going to place an order for fast intentions gaskets this week. Car sounds horrible.
there is a nice power pickup nonetheless and no cel so far as these utilize a j shape o2 bung.
they do smell bad.
broke both demon bolts but i knew i would.
Old Dec 1, 2018 | 09:12 PM
  #6033
luisf90s's Avatar
luisf90s
Just used the flame map, I haven’t used it in a while.
Old Dec 1, 2018 | 11:27 PM
  #6034
NW_6MT's Avatar
NW_6MT
Oil, trans (Redline MT85), and rear diff (Redline 75w90) changed.
All pretty straight forward. Used the motorvate Canadian fellow on YouTube for a preview of the job beforehand. Enjoyable since he's basically working on my car's doppelgänger in the videos.
Old Dec 4, 2018 | 04:12 PM
  #6035
G.AWD.zilla's Avatar
G.AWD.zilla
Installed Swift Springs, swapped brake fluid & upgraded to steel lines
Old Dec 13, 2018 | 03:24 PM
  #6036
slartibartfast's Avatar
slartibartfast
Someone asked awhile back for photos of my sedan dash cracking; I finally got them on my PC and uploaded here.
The notch in the middle is where I poked it with a fingernail to test hardness. Not hard! A third crack has appeared since I took these photos a few months ago.
Old Dec 13, 2018 | 03:34 PM
  #6037
PNW_IPL's Avatar
PNW_IPL
geez that looks terrible. Any plans to fix or replace?
Old Dec 13, 2018 | 03:48 PM
  #6038
Gabebapes's Avatar
Gabebapes
How do u fix this
Old Dec 13, 2018 | 06:52 PM
  #6039
slartibartfast
Buy a new car.
Old Dec 14, 2018 | 09:21 AM
  #6040
iCrap's Avatar
iCrap
Ran over an already dead deer yesterday... I think I got lucky and nothing seems damaged. It's all over the bottom of the car, wheel, rotor and my undertray is hanging from one corner. Oh, and the smell..
Old Dec 14, 2018 | 10:25 AM
  #6041
DrippDroppz's Avatar
DrippDroppz
Help with G37x Sedan No way through Firewall?
Hey guys I’m not sure if the pictures actually posted up yet but I’m trying to install a PA system in my 2013 G37x Sedan but I’m having trouble finding a way from the engine bay through the firewall and underneath my steering wheel.
•FYI there needs to be a 1/2” hole to fit the end of the cable through.
Does anyone have any ideas on this ?
PA System:
https://www.amazon.com/your-orders/pop/ref=oh_aui_i_d_old_o22?_encoding=UTF8&gen=canonical&lineItemId=kgkkoxjrskrwqny&orderId=111-5135360-7057010&packageId=1&returnSummaryId=&returnUnitIndices=&shipmentId=Dvcgwqmsy https://www.amazon.com/your-orders/pop/ref=oh_aui_i_d_old_o22?_encoding=UTF8&gen=canonical&lineItemId=kgkkoxjrskrwqny&orderId=111-5135360-7057010&packageId=1&returnSummaryId=&returnUnitIndices=&shipmentId=Dvcgwqmsy
Old Dec 14, 2018 | 05:10 PM
  #6042
pri.g's Avatar
pri.g
PA System: https://www.amazon.com/your-orders/p...ntId=Dvcgwqmsy
Check out page 14 from this installation manual.
https://www.infinitipartsdeal.com/installation/1tk3.pdf
Old Dec 15, 2018 | 02:22 PM
  #6043
slartibartfast
Replaced the Michelin PSS3 with new PSS3. Tires are only half-worn* but found a nail in the rear going through the shoulder at a tangent; I don't think it actually punctured the casing but I have a track event tomorrow and since I already had the tires waiting in the garage, better safe than sorry.
*Regular street wear. I could have gotten at least another year-and-a-half if I hadn't tracked them. Two full and two partial track days did significant wear. One of the fronts was a bit chunked and all had significant wear on the inside edge of the main water channels. One front and one rear had cord showing on the inside shoulder from too much negative camber and likely too much toe. I'll be getting the car corner-weighted and aligned this coming Wednesday.
Old Dec 17, 2018 | 03:06 PM
  #6044
2GoRNot2G's Avatar
2GoRNot2G
That's where I ran my wire for my Infiniti driving lights, but he said he needed a 1/2" hole, which isn't gonna happen using this location. There might be room in the hole that runs through the fire wall on the passenger's side foot-well (behind the battery compartment), but I think he's be better off pulling the connector off the end and just running the wire through on of the existing grommets on the fire wall (like the location in the above link).
Old Dec 18, 2018 | 08:40 AM
  #6045
BasicallyAG's Avatar
BasicallyAG
Originally Posted by RMB5190
Picture of the car lowered on the stock 17s - 26.5 at each corner from ground to top of fender.
The spoiler/RV for ants! Ive heard tell, but never seen it installed and paint matched.
