Old Mar 28, 2019 | 10:32 PM
  #6496
SupraOfDoom's Avatar
SupraOfDoom
Seems about right. Do you think those FI 2.25" piping is holding you back?
Old Mar 29, 2019 | 09:44 AM
  #6497
qmantran's Avatar
qmantran
Yeah I do but probably not by much. I would guess less than 10whp.
I do wish I had a 2.5" exhaust though.
Old Mar 29, 2019 | 10:41 AM
  #6498
SupraOfDoom
Not to late to get into that exhaust group buy... but that's 3".
Old Mar 29, 2019 | 01:07 PM
  #6499
2GoRNot2G's Avatar
2GoRNot2G
I'd try the dampers at the softest setting before giving up on them. I say this because my coil-overs are 10k/8k and I think them too soft. It's way too easy to slam the sway bar mounts when dealing with driveways.
I second this as well. Try softening up your dampers settings first. You may also want to confirm that the dampers you are using are '1' for the softest and '16' for the stiffest. I used to think all dampers started at the softest setting until I put a set of Intrax Racing coilovers on my Porsche and they start at '1' for the stiffest setting and get softer from there. Leave it to the Europeans to do something opposite from everyone else. LOL
I also agree that 10 kg/mm and 8 kg/mm for the front and rear respectively are a little on the soft side. I was an early adopter of the JIC coilovers for our cars which used 8kg/mm springs in the rear and they were way too soft and sagged considerably when I had someone in the back seat or anything in the trunk. I ended up having a custom set of 525 lb/in (~9.5 kg/mm) springs made for the rear, which ended up being a near perfect compromise.
Old Mar 29, 2019 | 01:13 PM
  #6500
PNW_IPL's Avatar
PNW_IPL
Thank you all. Will confirm damping adjustments and back them off. Appreciate yall.
Today I will be adjusting the parking brake and trimming the rear dust shield to look better.
Also installing a resonated Y pipe to tone down the megan 3inch single. Momma and baby dont approve of the cold starts before work lol. Also neighbor lady has mentioned elvis fell off her Mantle one morning i told her the car was all stock Mt Rainier must be waking up haha.
Old Mar 29, 2019 | 01:30 PM
  #6501
qmantran's Avatar
qmantran
Xyz y pipe?
Old Mar 29, 2019 | 01:31 PM
  #6502
PNW_IPL's Avatar
PNW_IPL
This one is made by circuit werks on ebay. Pretty close. Cant justify price on the Motordyne unit.
Old Mar 30, 2019 | 04:15 PM
  #6503
Dan Harris's Avatar
Dan Harris
Installed Fast Intentions Cat Back on my G37x
Old Mar 30, 2019 | 04:17 PM
  #6504
PNW_IPL's Avatar
PNW_IPL
Circuit werks resonated Y pipe installed. Toned things down just enough.
Old Mar 30, 2019 | 08:35 PM
  #6505
iCrap's Avatar
iCrap
Put my HFC on today. Installation was going GREAT until the last bolt which was stuck - then rounded off. Took 4 hours to get it off..... didn't expect that at all.
(Yea the bottom of my car is pretty rusty now )
Also replaced the driver side heater hose coupler. I literally touched it and it broke, If you have a higher mileage / older G CHANGE YOURS!
Old Mar 30, 2019 | 09:21 PM
  #6506
qmantran's Avatar
qmantran
can you share where you bought that metal coupler? Also what brand HFC are those?
Old Mar 30, 2019 | 09:25 PM
  #6507
doctorg37xs's Avatar
doctorg37xs
side questions:
1. how's the ride been for you on KYB / eibach springs?
2. so what exactly is your exhaust setup now? HFC with tanabe axleback but otherwise stock piping?
Old Mar 30, 2019 | 10:36 PM
  #6508
iCrap's Avatar
iCrap
Z1 Heater hose coupler
https://www.z1motorsports.com/coolin...e-p-11190.html
The ride is pretty good, it only starts to get annoying on really bad roads. But i've had these in for like 3 years now and I still like it.
Exhaust setup:
Kinetix HFC > stock midpipe with 12" vibrants welded in place > tanabe axleback
Old Mar 31, 2019 | 09:47 AM
  #6509
llebcire's Avatar
llebcire
Last Sunday - cup holder repair
Documented today.
-Eric
Old Mar 31, 2019 | 11:46 AM
  #6510
projectpanda13's Avatar
projectpanda13
Z1 diff cover, Z1 subframe, Bell Raceworks brace
