DIY: Cup holder fix - G37 Sedan (2011)
Fixed my cup holder that wouldn't stay closed in my 2011 G37x Sedan.
This is the same procedure others have mentioned (inserting screw) and while I didn't take pictures or videos while inserting the screw, I do have a video of what failed and pictures of where I inserted the screw. I consider this repair to be permanent as a broken piece of plastic is replaced with a screw.
Time:
First, here's a video showing what fails with the cup holder. Initially it failed while detailing a few weeks ago however when I removed the trim around the shifter the lid started closing so I put it back together (after installing felt to eliminate the center console creaking). What I found is the lid doesn't totally fail, but it does fail enough that removing the center console trim corrects the issue.
What I did to resolve the issue was drill a small pilot hole (to prevent splitting the plastic) and insert a screw to replace the plastic piece that broke off.
Pictures and removal instructions from FSM.
-Eric
Plastic part that fails.
Where the part used to site to keep the closing mechanism secure.
Where I drilled
Finished
Took time to completely dismantle and clean the center console while it was out.
Cleaned.
Time:
- Less than 60 minutes
- Small screw
- Small drill bit
- Drill
- Plastic pry tool (trim removal)
- Phillips screw driver
- Easy DIY. Most difficult part (for me) was removing the center console and specifically the trim retaining the console 12v and USB connectors
-Eric
Where I drilled
Finished
Cleaned.
codeflux (04-01-2019)
Fsm
Factory Service Manual for 2011 G37 showing center console components and removal.
Removal is very straight forward and quite easy. Once I go to step 6 I was in the back seat with both front seats moved to their forward positions for additional room.
The only issue I had was with step 6 removing the finisher holding the 12v power supply and USB connection (have Navi) as the finisher didn't want to release and I didn't want to break it. There was enough slack in the wiring that I was able to get under the center console and release the "pawls" holding it in place. I did remove the console lid to better facilitate getting under the console for this step and later to clean.
-Eric
-Eric
llebcire (04-01-2019)
NeoNz
25
05-12-2017 07:34 AM
10Gee37exeS
12-30-2013 04:24 PM
