Old Mar 25, 2019 | 03:12 PM
  #6481
markyo0o's Avatar
markyo0o
Originally Posted by PiperPerk
You can check it out now.
It looks pretty good. Not as aggressive looking as the Sports front lip but I like it. Where did you order yours?
Old Mar 25, 2019 | 03:16 PM
  #6482
saywat?'s Avatar
saywat?
sucks u guys dont have anything to go on the sides to match the front lips. all the action is in the front and thats it lol
Old Mar 25, 2019 | 03:18 PM
  #6483
markyo0o's Avatar
markyo0o
Lol try having an X model.
I think I have like 5 options for coilovers to add on top of the lack of other mod options.
Old Mar 26, 2019 | 07:47 PM
  #6484
2GoRNot2G's Avatar
2GoRNot2G
We actually have quite a few options for side skirts on our cars. I have Carbon Signal Side Skirts on mine, but there are many other options out there.
Old Mar 26, 2019 | 07:54 PM
  #6485
2GoRNot2G's Avatar
2GoRNot2G
Originally Posted by PNW_IPL
Say no to plastidip.
function> form
Lowered pass side and raised driver side to match at 25 7/8.
rears are 26 in from ground to fender.
hit a huge pothole on the way to work and the 12k spring rates have no give. I thought for sure i broke something. Going to order some 10k swifts to replace asap.
Are your running the 12 kg/mm springs up front or in the rear? That's about right for the front, but probably too heavy for the rear. I've found anywhere between 9 kg/mm to 10 kg/mm rates seems to work the best for the rear.
Old Mar 27, 2019 | 08:35 AM
  #6486
RMB5190's Avatar
RMB5190
C-C-C-Clean!
Can you offer any info on the front grille or is it custom?
Old Mar 27, 2019 | 09:00 AM
  #6487
hexotic's Avatar
hexotic
DIY Cheapskate/Mod
Originally Posted by RMB5190
C-C-C-Clean!
I believe Oneeighty makes them. I made one myself as well.
Old Mar 27, 2019 | 09:11 AM
  #6488
SupraOfDoom's Avatar
SupraOfDoom
C-C-C-Clean!
I have a real CF grill I got off ebay, but I'm still trying to make it fit! The fitment was terrible. Luckily I got it for free.
Old Mar 27, 2019 | 01:34 PM
  #6489
slartibartfast's Avatar
slartibartfast
Are your coil-overs adjustable for damping? If so, what settings are you using.
Old Mar 27, 2019 | 02:38 PM
  #6490
PNW_IPL's Avatar
PNW_IPL
Yes.
16 way. Was on 5.
Video
Made the car jump
Idk how nothing broke or bent. No leaks on the coil yet.
https://youtu.be/L7eIzG5OfIw
Old Mar 28, 2019 | 03:07 PM
  #6491
2GoRNot2G's Avatar
2GoRNot2G
C-C-C-Clean!
It's a custom one off full carbon fiber grill from Carbon Signal. Fitment isn't perfect like the OEM grill, but it's not too bad. It is starting to fade a little bit so it will probably need to be sanded and re-clear-coated sometime in the near future. I have a another grill I am working on so I may end up selling this one.
Old Mar 28, 2019 | 04:36 PM
  #6492
slartibartfast
Yes.
16 way. Was on 5.
Video
Made the car jump
I'd try the dampers at the softest setting before giving up on them. I say this because my coil-overs are 10k/8k and I think them too soft. It's way too easy to slam the sway bar mounts when dealing with driveways.
Old Mar 28, 2019 | 06:58 PM
  #6493
SupraOfDoom
Got my new hubs yesterday, so today I:
  • Installed the Stillen brake duct baffles
  • Installed the hubs
  • Installed the Z1 10mm studs (no impact)
  • Installed the Z1 front 2 piece rotors
  • Installed the front reman Akebono's
  • Installed the brake pads
  • Installed my SPC cambers arms from my X to my RWD
  • Installed new SPC balljoints for my camber arms. Only one was bad but I wanted to start fresh
  • Had to buy a 27mm socket for the SPC camber adjustment @ Harbor Freight
Tomorrow I'll have to get a 1/2" torque wrench since I currently only have a 3/8's and it only goes up to like 80 ft lbs. Tired. Good news is most of the non-body work is done. The body work I'm more worried or dreading more.
https://imgur.com/a/8RnEfEy#mdV6qw3
Old Mar 28, 2019 | 09:55 PM
  #6494
slartibartfast
Congrats on buying new tools. I always liked doing that.
Old Mar 28, 2019 | 10:30 PM
  #6495
qmantran's Avatar
qmantran
Here's the results of my before (stock intake & stock tune) and after (admin intake & remote tune)
3.692 FD
Admin 3" intake
ISR test pipes
Fast intentions 2.25 cat back exhaust
Dynod on a 5000lb drum dynojet
Other shops use a 3000lb drum.
+22whp peak
Max gain +27whp @ approx 6800rpm
