Who has a Stillen G37 Supercharger? Numbers, pics, vids!
Old Apr 16, 2015 | 11:56 AM
  #496
Team_STILLEN's Avatar
Team_STILLEN
Originally Posted by purez33
Car leaned out and threw a rod. Going back to NA.
Also interested in finding out what happened. Injectors fail, bad pump, post MAF + pre blower leak, etc?
Old Apr 16, 2015 | 12:05 PM
  #497
purez33's Avatar
purez33
I'll have more info in the days to come. I'll have the engine out and able to investigate a little more.
Old Apr 16, 2015 | 12:12 PM
  #498
Team_STILLEN
PM'd you. We want to work with you on figuring this out.
Old Apr 17, 2015 | 06:10 PM
  #499
purez33's Avatar
purez33
Took half the kit off. No signs of anything being loose or damaged. Might have the engine completely out tomorrow night for inspection. If anyone has stillen gen 3 intakes or knows someone who does, let me know...Im going to need them here shortly.
Attached Thumbnails Who has a Stillen G37 Supercharger? Numbers, pics, vids!-image.jpg
Old Apr 19, 2015 | 09:04 AM
  #500
purez33's Avatar
purez33
Found where all my oil was draining out from.
Old Apr 20, 2015 | 08:20 AM
  #501
ANMVQ's Avatar
ANMVQ
WOW :/, Detonation FTL
Old Apr 20, 2015 | 02:31 PM
  #502
RadioFlyer's Avatar
RadioFlyer
Wow, I'm really sorry to see that. It never feels good to pop a motor. And I realize it's hard to track down cause after the fact, but do you have any idea if it was bad gas, fuel pump/injector, tune, just a general glitch in the electrical system, etc? Do these cars have inline fuel filters? Was it clogged? Something happen with the VVTL that gave you crazy timing? Any thoughts?
Old Apr 22, 2015 | 11:31 AM
  #503
Team_STILLEN
Wow...that rod litterally punched through the oil pan.
I'm not an expert in this area, but I've only seen rods get thrown (quickly at least) from over revving. This is definitely something new to me for this motor. The few motors I've seen blown are usually ring landings breaking.
Old Apr 22, 2015 | 12:45 PM
  #504
Ryne's Avatar
Ryne
The Steering Wheel Guy
Subarus lol
Old Apr 22, 2015 | 01:28 PM
  #505
ANMVQ's Avatar
ANMVQ
Mine did the same thing, I threw cylinder 3
Old Apr 22, 2015 | 05:52 PM
  #506
RadioFlyer's Avatar
RadioFlyer
Bad enough det will do this. Higher RPM's but not necessarily over-revving. If the detonation is bad enough over 5,000ish RPM, you can window a block.
Old Apr 23, 2015 | 08:28 AM
  #507
ANMVQ's Avatar
ANMVQ
You said high RPM isnt needed mine started knocking under 5k also, and it tossed itself out or the motor while the car was in reverse and at idle.
Old Apr 23, 2015 | 02:53 PM
  #508
RadioFlyer's Avatar
RadioFlyer
^ Knocking as in, broken parts rattling around in the motor? Or Knocking as in detonation while the motor was still running 'fine'? If it was the latter, then the tune (detonation) is what broke the rod, and then piston velocity (even at idle) is what threw it through the block.
Sorry for prying, I'm just very seriously considering going FI, and want to get all the info out on the table as far as what I'm getting myself into. I have experience with superchargers on other NA cars, but the boost was always kept under 5-7psi. Tons of experience with larger turbos on factory turbo'd cars, but that doesn't apply here. Thanks for your insight!
Old Apr 23, 2015 | 03:03 PM
  #509
ANMVQ's Avatar
ANMVQ
Not prying at all, It was Knock, not broken parts, But rod knock, An the tune needs to be 100% for sure, Probably one of the reasons I haven't been back to them for a NA tune :/.
I was running 12 PSI on the Stillen kit, I think at the 8-9 PSI (Stock) version and a great tuner you should be all set.
Old May 5, 2015 | 02:05 AM
  #510
willstophe's Avatar
willstophe
Originally Posted by GRG37
Thanks, it is running the 8psi
I hope to see those numbers. Installing my kit wednesday.
Got the kit plus pulley upgrade and oil cooler.
Current mods: swift springs, MRR GT5 wheels, Motordyne catback exhaust, 35/5 front/rear tint, custom headlights (gunmetal painted housings and plasma LED angel rings).
I'm wondering how the exhaust will sound with the s/c cuz nobody has my exhaust with the stillen kit (to my knowledge). At least not on myg. I'll be running 8 psi (the out of the box tune). nice numbers man. That's really solid.
