DIY: Reset TPMS Warning by yourself for FREE
Old Feb 8, 2012 | 01:17 PM
  #241
A_Palaroan's Avatar
A_Palaroan
i had my tpms light go off and i just added air to the tire that was low and drove around the block and the light turned off.
Old Feb 8, 2012 | 02:30 PM
  #242
Modme's Avatar
Modme
This is not for when your lights go off due to low air. This is for when you change wheels , sensors, or sometimes when you rotate wheels.
Old Feb 9, 2012 | 09:51 AM
  #243
TeeItHi's Avatar
TeeItHi
new sensor
thanks for this great diy.
just wanted clarify that this will also be like programming new tpms when you buy without dealer program?
thanks
Old Feb 9, 2012 | 01:11 PM
  #244
Modme's Avatar
Modme
Yes.......
Old Feb 9, 2012 | 02:35 PM
  #245
TeeItHi's Avatar
TeeItHi
thanks
Yes.......
thanks
one more post till 100. sorry made you look.
Old Feb 26, 2012 | 08:57 PM
  #246
Meglos's Avatar
Meglos
I just noticed that if you want a tool for this that has the proper connector and an easy-to-use trigger switch, the OTC 3831 is it.
Available at Amazon.com for $23.31 (at the time I'm posting this).
Rather big 'n' chunky for an SPST switch, but if you don't feel like fooling with pieces of wire and such, I guess it might be worth it.
Old Feb 27, 2012 | 06:56 PM
  #247
TeeItHi's Avatar
TeeItHi
Bought used tpms for my new rims. After install drove it for 20 mins or so without problem and then drove it again after 2 hrs then the light came on solid then 5 mins later it started flashing. So I'm trying to reset them but the light will not stay solid in ON position, it will only go solid after 1 min when in ON or start, it will not go into learning mode after this. It seems like it starts at learning mode
Old Feb 27, 2012 | 07:09 PM
  #248
Modme's Avatar
Modme
Do not wait for the tpms light to turn solid. As soon as you turn on the ignition, tap the wire 6 times to ground. Then you wait. If it goes solid after a min, it didnt work. If it keeps flashing for > 2 min, then it's in learning mode.
Old Feb 27, 2012 | 07:12 PM
  #249
mikaly's Avatar
mikaly
Haha, very nice. For those DIYers, I made a less fancy version of this for less than $2. Used some spare wire, a paperclip (to jam into the Infiniti connector), solder (optional), and a momentary spst button. My ground was to the cigarette lighter.
From my experience, the tire pressures didn't have to be exact. As you drive and the tires warm up, the PSI inside your tires change. They just have to be different enough for the tmps system to be able to differentiate between the four sensors.
Old Feb 27, 2012 | 07:34 PM
  #250
TeeItHi's Avatar
TeeItHi
Ok thanks
Thanks
Ok I'll try it again. Maybe I didn't ground it properly, I even tried few diff grounding spot. Or didn't insert my wire properly.
Old Feb 28, 2012 | 01:26 PM
  #251
TeeItHi's Avatar
TeeItHi
its now on solid
i just tried during lunch but still no luck. but now the light doesn't initially flash, it on solid.
i'll try again later.
Old Feb 28, 2012 | 02:20 PM
  #252
apexi350z's Avatar
apexi350z
interesting tool, anyone tried it here?
Old Feb 28, 2012 | 06:20 PM
  #253
TeeItHi's Avatar
TeeItHi
New issue that I havent read on this thread yet. I was finally able to get into learning mode n drive for about 8 mins till a long beep comes on n at same time the light will become solid. Anyone had this happen to them?
Old Feb 28, 2012 | 06:27 PM
  #254
Modme's Avatar
Modme
That means the car was not able to register all the sensors and programming has timed out. This is either due to the pressures not set correctly or if one of the sensors is bad.
Old Feb 28, 2012 | 10:05 PM
  #255
TeeItHi's Avatar
TeeItHi
Diagnostic mode
Can I go into diagnostic mode while tires have 4 diff pressure or this will just give me more codes and will not give me accurate reading as to which tpms is? Or do I have to put same pressure for all tires? Thanks for all your help.
