DIY: Reset TPMS Warning by yourself for FREE
Old May 4, 2011 | 03:30 PM
  #196
tberrian's Avatar
tberrian
Originally Posted by gqgeos
at what point do you plug the connector back in?
also my light keeps coming on after about 10- 20 miles. The place i got my tires put on told me i was on my own to get the light reset.
I got this same issue happening. What did you do to get it fixed? I'm assuming you got it fixed.
Old May 4, 2011 | 05:27 PM
  #197
Modme's Avatar
Modme
What codes are you running? The code 53 can only be reset by Consult III or TPMS service tools.
Old May 4, 2011 | 09:02 PM
  #198
TomsG37's Avatar
TomsG37
Originally Posted by xyz
So I finally had the time to do this again after I got my broken tpms replaced. This time, I had to drive around for 15~20 mins, and the light went from blinking to solid (did not turn off in between) accompanied by a beep that lasted maybe 3~5 secs. I filled the tires up, and drove around for another 5~10 mins w/ the light staying lid. Any ideas? I also looked thought the owner's manual w/ no mentions of the beep . . .
I had the beep too. Tried a couple of times driving in the city with no luck. Then tried it on the highway after getting it into learn mode, and it worked! I wonder if some sensors need the high speed to wake them up and send a signal. I think if there is no signal for more than ten minutes then the learn mode times out and beeps to warn you it has timed out.
Old May 5, 2011 | 11:35 AM
  #199
tberrian's Avatar
tberrian
MODME, I got several codes. If I'm reading them correctly they are as follows,
15, 16, 17, 18, 32, 44, 46 and 52. I tried to clear them out, but they keep appearing. I don't understand it. Any help would be greatly appreciated. I believe, I'm getting close.
Thanks
Old May 5, 2011 | 11:40 AM
  #200
Modme's Avatar
Modme
I would take it into the dealership. It sounds like there's at least 1 broken sensor and maybe something wrong with your BCM. Do you have any aftermarket electronics installed?
Old May 5, 2011 | 12:38 PM
  #201
tberrian's Avatar
tberrian
I don't have any aftermarket electronics installed. I had to swap out my cd changer, but I put another oem in. I can't see myself taking it to the dealer. Everything is working fine except the TPMS waring light comes on after 20 minutes of driving. My thoughts was to clear the stored codes and see if that did it. If there was a problem with the BCM, would this be the only side effect or would there be something else?
Old May 5, 2011 | 12:47 PM
  #202
Modme's Avatar
Modme
The problem is that some codes cannot be erased by the diagnostic mode. You would need a Consult III to erase.
Old May 5, 2011 | 01:09 PM
  #203
tberrian's Avatar
tberrian
Ok, I understand. I really appreciate all you efforts and willingness to help others resolve their TPMS issues. Thanks!!!
Old May 13, 2011 | 04:43 AM
  #204
SANTOS29's Avatar
SANTOS29
Finally got to try this method today and it worked on the first try , Thanks Modme for the info.
Old Jun 1, 2011 | 09:42 PM
  #205
RaiderSuby's Avatar
RaiderSuby
Finally got this to work
I am on the same boat with some of the people here that my light stay solid if I do the step when the car is at the ON position. I am able to make the light start blinking, but as soon as I start the car, it will go solid within 2 seconds.
So I finally started the car, and do the tab 6 times, and it started blinking and stayed that way. Went for a drive 45 mph cruise control within 2 miles, my light is off. So I turn around a drive back to the house, and just before I got there the light came on solid. Pump all the tires up back to 35 psi, and wentfor the same drive. within 1 mile, light when off and I think it is going to stay off.
thanks again for all the help, especially Modme. Where can I paypal you? PM me.
Old Jun 1, 2011 | 09:54 PM
  #206
Modme's Avatar
Modme
You got it! Glad it worked out!
You guys are not going to believe it. So apparently this post has been passed around and around. I got an email from Directed, the manufacture for aftermarket alarms and remote starts. They are distributing the exact information that i posted on the first page to people that have TPMS problems.
I got plagiarized by Directed!
Old Jun 2, 2011 | 12:08 AM
  #207
4drScreamer's Avatar
4drScreamer
That's awesome. You should get sponsored by them or royalties!
Old Jun 14, 2011 | 12:20 PM
  #208
bukg37's Avatar
bukg37
will this work with aftermarket tpms
Old Jun 14, 2011 | 12:25 PM
  #209
Modme's Avatar
Modme
What's an aftermarket tpms? As long as you are using the car's OEM receiver and TPMS light, then this will work.
Old Jun 14, 2011 | 12:46 PM
  #210
bukg37's Avatar
bukg37
just had a shop installed them but seem like the car is not recognizing it, tired to reset it but didnt work any advice ????
Orange Electronic 402P409S00 Retro Kit Spare Sensor
