DIY: Reset TPMS Warning by yourself for FREE
Old Jun 14, 2011 | 01:15 PM
  #211
Modme's Avatar
Modme
What makes you think that sensor is compatible with our car? Each car manufacture and model uses different sensors and are not universal. The one you need for G37s is: 699-SCA01B
Old Jun 14, 2011 | 01:25 PM
  #212
bukg37's Avatar
bukg37
yeah thats the one i got posted the wrong pic. SCA01b
Old Jun 14, 2011 | 01:55 PM
  #213
Modme's Avatar
Modme
Which part of the procedure did not work? Did you enter the learning mode?
Old Jun 14, 2011 | 03:58 PM
  #214
bukg37's Avatar
bukg37
i do not get the slow flashing light, after tapping to ground 6 times
Old Jun 14, 2011 | 05:16 PM
  #215
Modme's Avatar
Modme
All I can suggest is keep trying until you do.
1. Make sure the metal you are tapping the wire with is grounded.
2. Make sure you tapped into the right slot in the harness
3. If it didnt work the first time, you have to completely turn the car off. Wait a few seconds and turn it back to ON to try again.
4. If tapping 6 times doesnt work, try 5.
5. Vary the speed of your taps.
Some people have better luck with the engine on, instead of the key ON engine off position. If all else fails, unplug your battery for a few minutes and try again. Just keep trying, you will eventually get the rhythm. This is a built in feature for all Nissan made cars, so there is no reason for any G37 to not work. .
Old Jun 14, 2011 | 06:47 PM
  #216
RaiderSuby's Avatar
RaiderSuby
I think * even if you don't have any TPMS you can still enter into learning mode. So if you did get the light to slow flash, you are doing something wrong.
I actually used an ohm meter to test my line and make sure I have connectivity, and where are you tabbing to ground the wire? I used the mounting metal for the brake pedal.
As far as engine on/off, it shouldn't be related to you yet:
I can actually get the light to flash when engine is off key on, it would just goes solid when I start the car. So I just start the car first, then tab within 5 seconds to finally get it to work.
Old Jun 14, 2011 | 07:23 PM
  #217
bukg37's Avatar
bukg37
k thanks for all the help
Old Jun 19, 2011 | 05:26 PM
  #218
bukg37's Avatar
bukg37
alirte got it in learning mode but everytime on turn on the engine the light go steady like Graphiteg37s ,now just steady any idea what i need to do
Old Jun 22, 2011 | 04:08 PM
  #219
majikstic's Avatar
majikstic
You need to enter the learning process with the car started. What's happening here is that you are exiting the learning sequence by starting the engine. So start the car and then tap the connector to ground.
Old Jun 23, 2011 | 09:27 PM
  #220
borderline's Avatar
borderline
This is a very interesting thread. I tried this and it did not worked for me, maybe I did something wrong...
I have set the PSI in each tire like mentioned. But I noticed that driving the car for 10 minutes increase the tire pressure (caused by the tire heat)
so...should I set the PSI with warm tires instead?
Any inputs?
Old Jun 24, 2011 | 01:04 PM
  #221
RaiderSuby's Avatar
RaiderSuby
Any inputs?
I don't think you have given us enough information to give you any good inputs.
When you follow these steps, do you see everything that indicate you are indeed in learning mode?
you said after driving 10 minutes, what happened? TPMS light solid?
At what point you think this is not working? all these details would help us identify the problem for you
Warm tires make sense. When I did mine, I did it after work (45 minutes commute) so I decrease the PSI to what was suggested in the first post. If you are doing it cold, I would suggest you drive it a bit first, then go home then start the whole process.
Old Jun 24, 2011 | 01:33 PM
  #222
borderline's Avatar
borderline
I did this few months ago (before winter). From what I remember, I was able to enter the relearn mode (slow flash) But when driving, the light became solid and never came off. I tried to be as accurate as possible with the tire pressure. Maybe my tire gauge is not good.
Does it matter if I have to do some STOPS before driving constantly at >25MPH?
Old Jun 26, 2011 | 10:41 PM
  #223
bukg37's Avatar
bukg37
alrite guys good news light went off after driving about 5 to 7 min in learning mode, but light never came back on is this normal ? should i just go ahead and set it to the correct psi.(aftermarket wheels) thanks in advance to modme and majikstic
Old Jun 29, 2011 | 05:34 PM
  #224
majikstic's Avatar
majikstic
Sounds like you got it! As soon as the light goes out you, should get the tires pressures back to normal. Sometimes it takes a while for the car to sense the low tire pressure....perfectly normal. I didn't wait for my light to go back on...just topped up the tire pressure and it's been great!
Old Jul 28, 2011 | 01:37 AM
  #225
Emon Crew's Avatar
Emon Crew
I just read through 15 pages of this thread hoping to find a post by graphite saying he finally got it to work...but no luck. I'll try these out on the new wheels and see how it goes. Great write up btw
