DIY: Reset TPMS Warning by yourself for FREE
Old Apr 22, 2010 | 10:16 PM
  #61
Modme's Avatar
Modme
Lets try erasing the diagnostic information:
Turn the car to ON and ground the wire. Leave it grounded for a few seconds and then turn the car off with the wire still grounded.
See if you can get the light to flash after that.
Old Apr 22, 2010 | 11:34 PM
  #62
Modme's Avatar
Modme
Originally Posted by terrycs
Modme ... you haven't figured out how to display the actual tire pressure at each corner using your onboard PC yet?!
Ohhhh, thats a good idea! I'll have to research that.
Old Apr 23, 2010 | 12:38 AM
  #63
GraphiteG37S's Avatar
GraphiteG37S
I tried that advice too and still no change. The light just stays solid at all times. :-/
Old Apr 23, 2010 | 12:47 AM
  #64
wakeboardr116's Avatar
wakeboardr116
Whats the need for running the ground all the way to the door? Just use some of the metal under there.
Old Apr 23, 2010 | 12:59 AM
  #65
GraphiteG37S
well i tried that too and wasnt positive all the objects under the steering wheel area were fully grounded.
just to be sure i tested the door jam for ground, and i had a long piece of copper wire available so i used that to the door jam.
  #66
GraphiteG37S
It was really that simple to do Wakeboarder?
I dont understand why mine is not working.
Old Apr 23, 2010 | 01:03 AM
  #67
muyrec's Avatar
muyrec
lol im in the same boat as Kverdina. Mines just blinks for a minute then stays on. Tried every single piece of metal down there but it just won't do anything. Though i haven't filled it to the proper psi first. Gonna try that in the morning.
Old Apr 23, 2010 | 01:07 AM
  #68
GraphiteG37S
My light doesnt blink anymore when I start it up LOL, It just constantly stays on right from start up.
Old Apr 23, 2010 | 01:17 AM
  #69
muyrec's Avatar
muyrec
Well Kverdina it seems you are almost there. Check this out.
Just gotta fill it up now.
Old Apr 23, 2010 | 01:38 AM
  #70
GraphiteG37S
I filled all my tires to 37 psi after I did all the wire procedures, so I don't think I'm low. I wonder if the car thinks my tire pressure is too high?? Is that possible.
Old Apr 23, 2010 | 01:47 AM
  #71
muyrec's Avatar
muyrec
hmm could be. Try the original spec (33 psi?).
Old Apr 23, 2010 | 01:58 AM
  #72
GraphiteG37S
I just dropped to 35 psi. Will drive the car tomorrow to work and hope for the best. If that doesn't work I'll drop the psi further, but I've always ran my cars with about 2 psi above factory specs without a problem. Wish me luck.
Old Apr 23, 2010 | 02:19 AM
  #73
You have to completely start over with the tire pressures set as specified. A few things I think you should check if it's not working:
1) I'm stating the obvious here, but make sure you have 4 working sensors in the tires.
2) make sure tire pressures are set exactly like Modme's original post. This seems to be how it learns the individual positions of each sensor.
3) make sure you are putting the wore into the one pin in the harness where the connection is. You should see a tiny piece of metal inside. It's really hard to see, but it looks as if there is only one hole that will make this work.
4) after turning the car to the on position, touch the other end of the wire to a body ground 5 times within 10 seconds. The metal around the OBD port is NOT grounded, it's attached to plastic. Painted metal is no good. I used a bolt head inside the front of the door jamb down low.
5) after touching it 5 times, wait for a couple of minutes. Normally the light flashes for 1 minute then remains solid if there's a TPMS malfunction. If you've succeeded in putting it into learn mode, it will just keep on flashing. After 2 minutes, you know it is learning. Drive off as instructed. It took me 5 minutes of driving for the light to go dark. Now go right away and inflate tires to the proper pressure so the light doesn't come on to indicate that some of your tires are low. I drove about 6 miles home and it didn't come on.
Good luck.
Old Apr 23, 2010 | 02:46 AM
  #74
GraphiteG37S
^thanks BlackBetty definately appreciate the help. I will try the entire process again tomorrow after work and hope for the best. As I
sure you did read, I have tried many time and followed Modems instructions about the proper psi to use for each tire. I still didn't get to leaning mode.
What's more puzzling is that my TPMS light no longer blinks for 60 secs when you first start the car like it used to. It no remains steady lite on from the moment I start the car up. I'm wondering if it will still work for me, or if my TPMS is in some other mode. I've tried what Muyrec suggested about lowering my air pressure and will see what happens on my eay to work in the morning.
Old Apr 23, 2010 | 02:48 AM
  #75
GraphiteG37S
I definately appreciate everyones effort to help and give suggestions to get this issue fixed for me. Thanks.
