Ask a Professional Detailer... Brought to you by Detailed Image
Old Apr 23, 2009 | 01:49 PM
  #766
Detailed Image's Avatar
Detailed Image
Auto Detailing Expert
Originally Posted by shiroda
George,
Thanks for the input - I just ordered some additional pads and other miscellaneous goodies. Assuming we don't get snow, I'll start this weekend and let you know how things go.
Thanks for the support
Looking forward to hearing about your results.
George
Old Apr 23, 2009 | 02:34 PM
  #767
WhosUrBuddiee's Avatar
WhosUrBuddiee
The seat in your picture looks EXACTLY like my car. Let me know how the Rejuvenator Oil works. I soaked mine with some Luxol conditioner and it only improved it a little.
I did what George said and put a damp cloth over the area and put it in the sun. About 50% of the cracks disappeard. Only the larger ones are still there.
I ordred a bunch of products from DI, I will let you know how the rejuvinator oil turns out.
Old Apr 24, 2009 | 02:40 PM
  #768
Detailed Image
Glad to hear the cloth trick worked for you. You can keep doing that along with conditioning your leather and can restore it pretty good. Unfortunately some of the cracks may be too deep to repair though.
Greatly appreciate your support
Enjoy your weekend!
George
Old Apr 24, 2009 | 02:41 PM
  #769
pfizzle's Avatar
pfizzle
Is it good get my car waxed more then once a month?
Old Apr 27, 2009 | 07:59 PM
  #770
WhosUrBuddiee
Well today I tried out the Rejuvenator Oil. I just rubbed in in, let it sit for about 5 minutes, then cleaned the leather. Very simple process. It made the majority of them smaller cracks vanish and reduced the visibility of the larger ones slightly. Overall just made the leather look blacker and didn't leave some ugly shine. Pretty impressed overall.
Before
10 Minutes later
Old Apr 27, 2009 | 08:03 PM
  #771
Gamedog's Avatar
Gamedog
Sam Rothstein
Wow not bad.
My seats look your "Afters" do right now minus the cracks. All I have are wrinkles. Maybe after some of this stuff it will make the wrinkles less noticable.
Old Apr 28, 2009 | 05:43 PM
  #772
Detailed Image
Follow this to try to take your results even further. Place a damp cloth over your bolster and let it sit in the sun. This can help tighten the leather and reduce some of the cracks even more. Then reapply the Rejuvenator Oil and let it sit for up to 24 hours in direct sunlight if possible. The combination of time and heat will make your results even better than the quick 10 minutes.
Worth a shot, I think you can reduce the marks even more.
Let me know if you give it a shot. Thanks for sharing your results!
George
Old Apr 29, 2009 | 10:04 PM
  #773
g37mt6's Avatar
g37mt6
Hi George, I just wash my mf towel with tide and it has color bleach in it. (just found out that you can only use Tide free) I did used the towel with the quick detailer spray and i noticed that the paint becomes really dry so i quickly washed my car again and used prewax to clean it out. My question is can the residue from the bleach damage the clear coat on the car?
Old May 2, 2009 | 12:11 PM
  #774
Detailed Image
You should be fine, especially if you took care of the situation as fast as you did. I don't know if it'd have any long term effects on the clear coat if you didn't care for it or continued to use that type of detergent on your towels. If I had to guess, the damages would be pretty slim because I'm sure it'd be more known as a detailing No-No to use products with bleach in it.
To clean out the towels, you can use some distilled white vinegar during the rinse phase of your wash. You can also boil your towels to really release any coating on the fibers and restore your towels as well.
George
Old May 3, 2009 | 02:23 AM
  #775
g37mt6's Avatar
g37mt6
Thank you sir!!!
Old May 3, 2009 | 02:49 PM
  #776
Ivoidwarranties's Avatar
Ivoidwarranties
My friend came over the other day to help clean up my cars for an upcoming car show. He had this DP stuff that he could mix in different concentrations. We used it to wipe down the cars which were freshly detailed but covered in dust and a little dirt. The stuff was better than any quick detailer I have. Do you have anything like that?
Old May 3, 2009 | 05:46 PM
  #777
WhosUrBuddiee
I just bought some Chemical Guys Speed Wipe two weeks ago. Very easy to apply and remove, doesn't streak, smells great and enhances the depth and gloss. It also has some anti-static properties which helps minimize dust build up.
Old May 4, 2009 | 12:42 PM
  #778
brynomon's Avatar
brynomon
Enjoy your weekend!
George
George, I'm experiencing the same cracking as others here. Is there anything I can do other than conditioning the leather tons to avoid this?
Old May 4, 2009 | 02:01 PM
  #779
KLB's Avatar
KLB
George. I wanted to thank you for your help. My lazy old self put the Optimum All-in-One and Wax to use this past weekend and all I can say is WOW! It looked better than the day I picked it up.
I'm sure I will be back for more stuff later. The wife is already asking about her truck, and I find I need a lot more MF towels.
Thanks again for the help.
Old May 4, 2009 | 07:06 PM
  #780
Detailed Image
Thank you sir!!!
Anytime, let me know if there's anything else I can help with.
There are lots of good QD's out there. As WhosUrBuddiee mentioned Chemical Guys Speed Wipe is a great option. Very easy to use, doesn't streak and leaves behind a slick glossy surface. The QD I've been playing with and have been extremely happy with is the Optimum Instant Detailer (OID). The 32oz and 128oz sizes are concentrated so you can dilute to your desired level, like the DP. I don't think you'd be disappointed with either of those. If you liked the DP one, no harm in getting something you know you like either.
Thanks for the recommendation
Regular maintenance and always making sure there is some UV protection on your leather is the best way to prevent the cracking. Also, being cautious on how you enter the vehicle and not sitting directly onto the bolsters helps a lot. If you want a simple 1 step product, consider Poorboy's Leather Stuff.
Glad to hear the products performed to your expectations. If there's anything else I can help with, let me know.
Thank again for your support.
George
