Rochester's new G
Old Feb 3, 2017 | 01:13 PM
  #1486
Where did you get that little aluminum cover on the top of your dipstick?
Bought that for my old Maxima, in December 2010, from ZeeToyz:
[url=http://www.zeetoyz.com/round-dip-stick.htm[/url]
Just ask him to not etch Z into the side.
Old Feb 3, 2017 | 07:32 PM
  #1487
Had an idea a long while ago, and was re-inspired by that car where I spotted these aluminum hose clamps. He wrapped the curvy piece of plastic on both sides of the back engine bay, by the battery and brakes.
So today I was experimenting with a sheet of CF wrap, from 3M. I found it way too thick to be pliable, and the adhesive barely worked at all... so that was frustrating. Since I couldn't wrap the wrap (LOL) around the edges, I had to use the razor blade. This isn't really a bad photo, but the job isn't perfect, so I'm calling this proof-of-concept, and will have to start over. Probably later this Spring, because it's 20*F today.
I did this indoors, after taking the piece completely apart, degreased, cleaned, dried. And yet the wrap wouldn't stick well. I wonder if I should have roughed up the surface with high-grit?
What do you think? Good, bad, tacky, meh, awesome sauce?
Old Feb 3, 2017 | 07:44 PM
  #1488
Dembflyr's Avatar
Dembflyr
I like it.
I may have to use my leftover vinyl from my interior and try it out myself.
Old Feb 3, 2017 | 07:50 PM
  #1489
hexotic's Avatar
hexotic
DIY Cheapskate/Mod
I like it. Last time I wrapped non smooth plastic like that, I had the same issue. Its not that the adhesive is bad, it's the porous nature of the plastic that makes it a pita. Adhesion promoter solved the problem. Try giving that a shot?
Old Feb 4, 2017 | 12:33 PM
  #1490
3m has a primer that really helps w/ tough contact areas, I had to use it around my little stereo buttons w/ my interior wrap.
For smaller applications like yours 2 or 3 of these little primer sticks should suffice
Sailrite - Fabric, Canvas, and Sewing Machines Since 1969
FWIW I like the look there, nice way to draw just the right amount of attention to that area without being too much.
Old Feb 4, 2017 | 12:40 PM
  #1491
I just now got home after running (driving, LOL) down to PepBoys. Dupli-Color Adhesion Promoter is $14 at Amazon, but under $7 at PepBoys. So I'm going to continue working on this project over the weekend.
Thank you, Brad. That was exactly my intent... enhance and compliment, without becomming a gold tooth. I like how the pattern is in the same theme as the honeycombed center section of the engine cover.
Old Feb 5, 2017 | 02:09 PM
  #1492
Great advice, hexotic!
I took a second pass at this project, this time roughing up the panel with fine-grit, and spraying a few coats of Adhesion Promoter. The vinyl stuck just fine. Then I went over it with the hair dryer and rubbed into it as best as I could. The result is totally acceptable. Better than acceptable, I'm pretty stoked about how it turned out. And this time I went at it expecting to shave with the razor blade. In general, there was just a better comfort zone of improvement over the first attempt.
I've done both panels, cleaned and conditioned the surrounding plastics. Think I'm done with this little project.
And here's a close-up:
Time to order the other hose clamps and play around with that.
Old Feb 5, 2017 | 02:33 PM
  #1493
Nice work there John, glad to hear that extra prep paid off, do you have any other little parts you might try that CF on? I know you're not one to go overboard so I doubt you do, just curious
Old Feb 5, 2017 | 03:14 PM
  #1494
Nope. Not a single thing comes to mind.
I'm pretty much anti-CF... real, vinyl or otherwise. Whatever the appeal is, I just don't get it, and for the most part I find the CF look is pretty tacky. When I started pursuing this idea, I was well-prepared to chuck it.
I think the way people like CF, I have a similar reaction to titanium. But that's about as close as I can get to understanding it.
Old Feb 5, 2017 | 03:27 PM
  #1495
hexotic's Avatar
hexotic
DIY Cheapskate/Mod
turned out fantastic
Old Feb 6, 2017 | 06:52 PM
  #1496
guy from norcal's Avatar
guy from norcal
I like it john.
Old Feb 7, 2017 | 08:38 PM
  #1497
hexotic's Avatar
hexotic
DIY Cheapskate/Mod
Look what you made me do...
Old Feb 8, 2017 | 09:05 AM
  #1498
ShuuraRG's Avatar
ShuuraRG
They do look amazing! I may have to go this route as well!
Old Feb 8, 2017 | 11:21 PM
  #1499
Rubyq60's Avatar
Rubyq60
Dam nice mang.
Old Feb 9, 2017 | 09:36 AM
  #1500
Just to see, I thought I'd try out the P2M clamps at the filters, inside the heat shield. I thought it might look good in red...
...but I was wrong. Sending them back, and getting black.
As my Dad used to say, swing and a miss.
