So i was asking a couple questions and got a few opinions on this thread half a year ago. I thought i should contribute back to what i ended up going for. So i have a 2011 Infiniti G37xS Coupe. I went with a 19x10+25 square setup and i am currently sitting on Eibach Springs.
Have to say, you nailed it! Glad you went with the +25s all around, what tires specs did you end up with, did you end up running 255/40s?
Those Works are a great look as is everything else you've done
If I run the same setup as Awakence with 275/35 tires, will I need to do any fender modification?
Might send him a PM to verify the tire size he's running, it will be close and that rear bumper bracket may need to be shaved back. Also rolling the front fender edge (like the rear already is) will give you more room up front.
I couldn't find the wheels I like in 19x10.. I am opting for some Enkei RPF1 19x9.5+22 wrapped in Hankook Ventus V12 245/40R19 or something fatter like 255 or 265. What do you think? Any clearance issues?
Great thread! I'm looking at getting some 18 x 8.5 Miro 111's for my Q40 AWD/G37x sedan. I am on the fence in regards to dropping an inch with swift springs...but leaning towards doing it eventually. I don't like the wheel gap, but its functional in deep snow.
It looks like ET35 should be close to flush with 245/45/18's? Or should I go with the ET45 option? I don't want the wheels or tires to poke out past the fenders. I'd rather have them just a bit inside.
Hi Cafasco, I had a very similar setup before on the sedan, 19x8.5 +35 with 245/40/19. It does fit very well. I'm a bit wider and bigger now at 265/40/19 and I still have a solid amount of wheel gap. But tires are practically flush, very little room in front. Maybe 5-10mm in rear? I wouldn't go +45 personally, it would sit way too much inside the fender well.
I'd run 18x9.5 +40 these will be a perfect flush fitment on a 255/45/18 tire, and with a drop they will be about as good as you can get. Check Zahy Matars G or Dembflyr in these builds they're both running 19x9.5 +40 nismo wheels on 255s (this will be the same fit at the fender as the 18x9.5s running 255/45s).
I just wanted to go over/confirm some things before I order everything. I believe you said last time that I'd only need to buy toe/camber bolts for rears, if I drop the 2011 g37xs sedan on swift springs, on 19x8.5 +35 265/40/19s right?
Should I only order the rears and the springs then? Or do you think I'll need front camber/toe kit as well? This is mainly a commuter car that I occasionally push so tire life is somewhat important to me.
Current Nismos
older Nismos
Thanks for the info and photos! Definitely food for thought! A 255/45/18 would help fill in the gap a bit more too. The first photo is perfect look!
265s are pretty wide for an 8.5", did I recommend that setup?
Nope, I asked if you if they would fit in the fender, and you did link stuff about some performance loss because its one size up from manufacturer max but should be fine.
