Old Jan 17, 2015 | 04:59 PM
  #61
09BlkObsSdn's Avatar
09BlkObsSdn
Looking at a set of squared 10.5 CVTs ET45 with Eibach drop on a sedan. I am planning on getting 285/30/20 for rear tires and am not sure what size tires I can fit up front without too much stretching. Any suggestions?
Old Jan 17, 2015 | 07:42 PM
  #62
ai3j50's Avatar
ai3j50
Will I have any rubbing issues running 19x9.5 +35 on an X coupe? Lowered on Eibach camber kit in the rear; front kit coming this spring.
Old Jan 18, 2015 | 01:11 AM
  #63
Check Lt8che coupe specs, 9.5 +30 running 265s, you'll be 5mm in from that setup on 265/35/19s so would be a good fit.
https://www.myg37.com/forums/brakes-...ml#post3815735
Old Jan 18, 2015 | 03:23 PM
  #64
ai3j50's Avatar
ai3j50
Lt8che set up is the flush look I am going for but he is running 18's, good to know I will not have issues on 19s. Thanks
Old Jan 18, 2015 | 04:39 PM
  #65
Yep, with the 19s and in that tire size you'll have the same overall diameter and tread block so the fit will be nearly identical.
Old Jan 20, 2015 | 10:49 AM
  #66
ChinkyChoy's Avatar
ChinkyChoy
I believe lt8che also ran 19's at one point. look up his set up with his Work wheels
Old Jan 20, 2015 | 11:09 AM
  #67
Lt8Che's Avatar
Lt8Che
'Cuz Racemod-erator
I ran 20's with the Works. 20x9 +38 245/35/20. Needed 15mm spacers for the rears to bring them flush and kept the fronts a little tucked.
The 18 set-up with the Forgestars is perfect though.
Old Jan 23, 2015 | 02:15 PM
  #68
jhovanyrod's Avatar
jhovanyrod
love this thread
Hey guy I have a 2010 g37x coupe I am lowered on elibach springs little under a 2" drop I'm the market for new wheels looking for a straight concave look I was wondering if 20x11 offset 25 and 245/35/20 tires cause any rubbing or if there would be issuse?
Old Jan 24, 2015 | 03:24 AM
  #69
jhovanyrod's Avatar
jhovanyrod
thread still active? ?
[QUOTE=jhovanyrod;3867334]Hey guy I have a 2010 g37x coupe I am lowered on elibach springs little under a 2" drop I'm the market for new wheels looking for a straight concave look I was wondering if 20x11 offset 25 and 245/35/20 tires cause any rubbing or if there would be issuse?
Old Jan 24, 2015 | 02:44 PM
  #70
[QUOTE=jhovanyrod;3867540]
Check reply here, please only post question once, or bump an old post rather than posting same question over several threads, thanks!
https://www.myg37.com/forums/brakes-...ml#post3867635
Old Jan 30, 2015 | 10:49 PM
  #71
thisISit's Avatar
thisISit
I am looking to get a square set of 20x10s in the spring. I am running eibach prokit with 20mm spacers all round. I'm curious if I could run this wide leaving the spacers on and what a good offset would be. Also could I run a non-stretched tire?
Old Jan 30, 2015 | 11:16 PM
  #72
Without the spacers it's going to be tight, running 10" +35 on 265/30/20 would be about as aggressive as I'd recommend (and no spacers)
Old Feb 15, 2015 | 03:00 PM
  #73
Purist's Avatar
Purist
i'm thinking of going with a 19x10 +22 square setup on my s coupe but don't want any issues with the front.
I'll be running bc coils and both front/rear spc camber kits. any input?
Old Feb 15, 2015 | 07:49 PM
  #74
You'll have to run a stretched tire setup, might check this thread for a square setup w/ similar specs, I know you're not AWD but you'll see more squared setups there~
https://www.myg37.com/forums/g37-cou...37x-coupe.html
Here's a post in that thread that is close to what you're asking
https://www.myg37.com/forums/g37-cou...ml#post3818456
Old Feb 15, 2015 | 09:07 PM
  #75
Purist's Avatar
Purist
hmm, thanks for the links. i found someone running 19x10 +18 with 245/40 and 255/35. Do you think the front will clear if i try and run 255/35 all around on the 19x10?
otherwise I think i'm might end up going with 19x9.5 + 22 F and 19x10.5 +22 R with 245/35 and 275/30 tires. Not sure which setup would work better
