Help need help on fitment with new wheels!
Old Jan 24, 2015 | 03:35 AM
jhovanyrod's Avatar
jhovanyrod
So I have a 2010 g37x coupe I'm lowered on elibach springs about a 2" drop I want to go 20x10+25 And 255/35/20 tires would that work or would the front rub?
Old Jan 24, 2015 | 02:41 PM
You've also been posting about 11" rims, which ones are you considering?
The 10" +25 is a much easier fit than the 11s w/ the same offset, you'll be real close w/ the 10" +25, here's a 9.5 +30 running 265s and as you can see the fit is real flush, the 10" +25 would be another 11mm further out on teh rim and the 255 would bring it in a bit but not much, say an overall 8mm further out from Lt8ches' coupe
https://www.myg37.com/forums/brakes-...ml#post3815735
The 11" rims you're asking would be another 12mm out from the 10" so about 20mm further out from Lt8ches.
helloandchau
Oct 6, 2015 05:26 PM
ay37
Sep 15, 2015 08:51 AM
xpcgamer
Sep 7, 2015 07:10 PM
Sylo
Sep 3, 2015 04:44 PM
