finally installed my coilovers (spc front and rears)this weekend..
i have not had it aligned yet.. i am sure it is totally out of whack
19x9.5 +35 et with 245/40/19 tires
after this picture, i adjusted the rears to match the front at 26.5 in height
this is still a good picture even if i dropped it a little more after
i tried to be straight as possible, but like i said,.... i still need an alignment to get everything proper like.
From my stock 225/45/17"
Cambers needed to accompany this 10.5 +38? I need them to fit on all 4's because of the awd
What wheels are you considering? A 17x 10.5" wheel would be very uncommon and a 275/45/17 isn't a tire size that I've seen. As far as width and offset on an AWD sedan w/ in-spec camber I wouldn't run wider than a 9.5 +38 offset on a 245 width tire. If you lower your X and run a bit of camber you could run a bit less positive offset or a 10" wide wheel, or a bit wider tire. A 10.5 +38 won't look right without some work. You CAN run a staggered setup on an X but need to be extra careful w/ tire sizing front to back. There's quite a few that run a 8.5 to9" front on a 245 width tire and a 10 to 10.5 back w/ a 285 width rear, so it can be done, but need to get the sizing right.
vossen cvts 20x10.5
hey guys im ordering my vossen cvts for my g37s rwd coupe im looking at the 20x10.5 squared but not sure on what offset to use for it to be flush with fenders or a little out looking for some advice thanks im stock height right now but looking into tanabe or stance coilovers later on
Have a 2011 G37xS Coupe dropped on Eibach springs (1.9in front and 1.6in rear). I am looking for specs for my summer setup. From reading some of these posts i am thinking 19 x 9.5 + 25mm offset or 19 x 10.5 + 25mm offset. What do you guys think?
[/url]
