Old Aug 8, 2015 | 08:01 PM
  #211
RJ's_G37's Avatar
RJ's_G37
are you lowered? depending on the offset that could poke way too much
im lowered on swifts. no camber kits
Old Aug 8, 2015 | 08:03 PM
  #212
ChinkyChoy's Avatar
ChinkyChoy
need to know the offset to determine if it will fit
Old Aug 9, 2015 | 03:32 AM
  #213
Offset should be stamped inside the wheel, if it's a +40 offset it could also be listed as
ET 40.
Old Aug 10, 2015 | 03:13 PM
  #214
RJ's_G37's Avatar
RJ's_G37
I ended up passing on them.will look at something a little less than 10.5 next time
Old Aug 10, 2015 | 06:58 PM
  #215
Yeah, there's not much room for error going w/ 10.5s all around, let us know what you end up doing or if you have any other setup questions.
Old Aug 12, 2015 | 11:32 AM
  #216
m3clubracer's Avatar
m3clubracer
Originally Posted by RPMaddict
Thank you blnewt. That is precisely what I was hoping for. I feel a ton better now and can make the purchase with confidence. Assistance appreciated. I hope to share my setup soon!
How did this turn out?
Old Aug 13, 2015 | 12:46 PM
  #217
G37xsfun's Avatar
G37xsfun
Anyone here running 19x9.5 all around with 35mm offset? I'm planning on this with my 11X sedan on Swifts, oem camber and 255/40 tires. Any thoughts about clearance issues on the front?
Old Aug 13, 2015 | 01:33 PM
  #218
ChinkyChoy's Avatar
ChinkyChoy
Look at the first post my 2nd set up is exactly what youre asking
Old Aug 13, 2015 | 01:40 PM
  #219
G37xsfun's Avatar
G37xsfun
I saw that but links to pictures are not working. Is the one below the same wheel with spacers? What size tires?
Old Aug 13, 2015 | 01:49 PM
  #220
ChinkyChoy's Avatar
ChinkyChoy
I ll try to fix the broken links later
the volks are 19x9.5 +35 all around
the Works are 19x9.5 +25 all around
The tire size is 245/40 all around for all my set ups.
Old Aug 15, 2015 | 11:36 AM
  #221
cmackin's Avatar
cmackin
Would like to see the pictures of +35 as well.
Old Aug 17, 2015 | 02:19 PM
  #222
ChinkyChoy's Avatar
ChinkyChoy
sorry totally blanked on this thread.
I have been using facebook to share images which doesn't work out so well since they keep changing the address and it breaks the link. I ll save everything to Flickr and relink them tonight
Old Aug 17, 2015 | 03:52 PM
  #223
mcwong153's Avatar
mcwong153
With 19x9.5 +35 all around on a sedan are you still in spec with camber? or do you need camber kit at this point?
Old Aug 17, 2015 | 07:10 PM
  #224
ChinkyChoy's Avatar
ChinkyChoy
not sure cause i installed the camber kit when i installed the coils. My current specs are around -2 in the front and -3 in the rear but thats with +25
working on getting the pix fixed right now
Old Aug 17, 2015 | 07:26 PM
  #225
ChinkyChoy's Avatar
ChinkyChoy
updated first post with new pix
