The OFFICIAL "I have a wheel offset / tire fitment question!" thread
Old May 25, 2016 | 12:13 AM
  #1441
Originally Posted by stawskig37x
Could I get them to fit inside the fender and still be able to turn without rubbing? My apologies, I'm a newbie to the form and I tried searching but couldn't find much on 10.5's in the front. This is why I posted in the wheel/offset question thread.
Do the wheels that you want come in offsets that are an easier fit, or is this a used set that you don't have that luxury? Something like a +25 would make your life easier for sure.
Old May 25, 2016 | 12:15 AM
  #1442
Originally Posted by Saltychicken456
I just recently purchased a G37s on 20x10.5 Vossen CV3's and it's rather stanced right now, with stretched 255's and a lot of camber. I want to keep the wheels but don't want the camber, and I'm concerned the wheels are always going to poke out. Is there anyway to suck the rear wheels inboard? There's no spacer, and I don't think machining the hub is a great idea. And if I remember right they are +15 offset. According to the previous owner.
No other options besides the dreaded fender pull.
I'd look for another set of wheels, might be able to find someone to trade that's wanting to go hellaflush.
Old May 25, 2016 | 09:09 AM
  #1443
VenomGT9's Avatar
VenomGT9
tried a vacuum?
Trade the wheels for something better fitting...go with 19s.
Old May 25, 2016 | 09:20 AM
  #1444
Saltychicken456's Avatar
Saltychicken456
Would this forum be a good place to start bartering?
Old May 25, 2016 | 09:24 AM
  #1445
VenomGT9's Avatar
VenomGT9
It's possible...I've seen dreams come true.
Old May 25, 2016 | 09:37 AM
  #1446
Saltychicken456
The car has aftermarket camber arms on it so I'm going to adjust some of it out and add some ride height as well. Maybe try my luck on Craigslist with the wheels first.
Old May 25, 2016 | 10:05 AM
  #1447
VenomGT9's Avatar
VenomGT9
Where are you located Mr. Salty
Old May 25, 2016 | 10:41 AM
  #1448
Saltychicken456
I'm in WA state
Old May 25, 2016 | 11:07 AM
  #1449
VenomGT9's Avatar
VenomGT9
https://www.myg37.com/forums/private...ion-etc-6.html
I've posted many a good wheel deals here...if you don't mind dealing with shipping some kinda far.
If you want to stick with 20s, best option would be a set of CBA/DBA GTR wheels...stock forged by Rays and can be had for 900-1200, keep an eye on the gtrlife forum.
https://www.myg37.com/forums/wheels-...g37-coupe.html
Old May 26, 2016 | 12:53 AM
  #1450
stawskig37x's Avatar
stawskig37x
It's a used set for very cheap, probably gonna have to pass them up this time.
Old May 26, 2016 | 08:54 PM
  #1451
camry90's Avatar
camry90
19X8.5 +38
Old May 27, 2016 | 12:51 AM
  #1452
Looking good^^^Got a side shot?
Old Jun 1, 2016 | 08:41 PM
  #1453
jameswouldgo's Avatar
jameswouldgo
So I just got some wheels 19x9.5 +30 all around. Will these tire sizes be good without any rubbing or modification to the fenders. I got some recommendations to go with 255/35/19 front and 275/35/19 rear or 285/35/19. I'm afraid that they'll be poking out. I have a 08 Coupe RWD and at stock ride height but plan on lowering it with some coilovers in the near future.
Old Jun 2, 2016 | 12:08 AM
  #1454
At stock height the 275s & 285s will poke outside the fender a bit. I'd run the 255s on all four then reevaluate once you drop it. you could always get the wider pair later, but in the meantime you'd have a decent fit and a true 4 wheel rotation available.
Old Jun 2, 2016 | 01:01 AM
  #1455
jameswouldgo
Thanks for the input. I forgot to mention that I am going to run stock wheels until I get the coilovers. Which would you recommend for the rear the 275 or 285?
