GT-R Wheels on G37 coupe
Old Sep 8, 2015 | 12:42 PM
goredcar's Avatar
goredcar
Just wondering if someone has done this and what their experience has been. I am presently on 255-35-19 (rear) on stock wheels and I have major traction issues. I can only go to 275 on stock wheels and I don't think that is enough. I have an opportunity to snag some GT-R wheels, but I have some concerns going to 20's as this will move my rear end ratio in the wrong direction. I make big power after 3K rpm, so I like to get up there fast. Moving to a 305-35-20 will change my ratio (from current) by 8.6%. I could go to a 30 profile and the variance drops to 4.4%, but am concerned that the very narrow sidewall could be make for a harsh ride. Also concerned that the 20's will make my car 1/2" higher
Suggestions?
Old Sep 8, 2015 | 10:15 PM
Suggestions?
Might consider these 370z wheels, lightweight and wide
https://www.myg37.com/forums/private...19-wheels.html
Have you considered drag radials like the Toyo R888
they have them in 265/35/19 front 295 or 30530/19 rear
The 265/305 combo would put you just under 2% smaller than OEM (the 305s being the smallest diameter of the two).
Here's the z wheel specs, and the Nismos are even wider
370Z OEM Wheel and Tire Specs - MY350Z.COM Forums
The GTR rims have similar offsets but only in 20s, both the Z & GTR rims you'd probably want spacers in front.
Old Sep 8, 2015 | 11:01 PM
goredcar's Avatar
goredcar
Good suggestions... thanks. the major problem would be shipping from SoCal to Canada. The drag radials are a cool idea... thanks for that idea as I hadn't really considered it.
Old Mar 22, 2016 | 01:49 PM
PongSanity's Avatar
PongSanity
can the r888 305/30/19 or 295/30/19 fit the rear stock sport G37 wheels?
Old Mar 22, 2016 | 01:52 PM
the93owner's Avatar
the93owner
Those would be extremely wide for the stock wheels, at only 9 inches wide. 275 is the widest you should go for that kind of width. For 295 and 305 you need at least a 10.5 inch wheel for a safe mount.
Old Mar 22, 2016 | 02:27 PM
PongSanity's Avatar
PongSanity
what drag radial would you recommend at 275? the toyo r888 next size down is 265/35/19... I'm currently on 275/35/19 nitto nt05
Old Mar 22, 2016 | 05:49 PM
VenomGT9's Avatar
VenomGT9
Old Mar 22, 2016 | 05:50 PM
VenomGT9's Avatar
VenomGT9
Not my ride but LOVE how it looks!
Team_STILLEN
Future Models
13
Sep 5, 2016 03:13 PM
dAgent
Dec 1, 2015 09:03 PM
james6980
Oct 9, 2015 01:28 PM
joeposter
Sep 8, 2015 04:36 PM
reigle9
Aug 6, 2015 02:45 PM
